Old 11-07-2019, 01:57 AM   #1
jhalagian
Drives: 2015 brz
Rear Camber RCE Yellow
Recently installed RCE Yellows along with Whiteline Upper Control Arm bushings. After install the Rears were sitting at -2.8/-3.1. The tuner shop was able to dial it back to -1.7/-1.8. As this is my DD is like to get the rear back to -1.0 or as close as possible. I wanted to see what the best course of action would be.
Not sure if there are any other bushings I could get to help or if I need an LCA. Appreciate the feed.
jhalagian is offline   Reply With Quote
Old 11-07-2019, 05:20 AM   #2
Jpembry
Drives: 2019 Subaru BRZ Series.Gray
Surprised bushings helped you dial out that much! You will need LCA’s to dial out anymore but honestly it isn’t necessary. 2* of negative camber isn’t going to really hurt you. Make sure your toe is in spec, or even zero it out of you are concerned about tire wear, as that has way more influence on wear than camber.
Jpembry is offline   Reply With Quote
Old 11-07-2019, 07:44 AM   #3
jhalagian
Drives: 2015 brz
Toe is fine. Made sure to dial 0 front and I believe the rear is like 1/16 or 1/32. Thank you.
Old 11-07-2019, 09:44 AM   #4
wparsons
wparsons's Avatar
I'd just leave the rear camber as it is, factory spec is -0.5 to -2 in the rear.
flickr
Old 11-07-2019, 10:08 AM   #5
Racecomp Engineering
Those are the adjustable upper control arm bushings?
-1.7/-1.8 is honestly good.
- Andrew
Old 11-07-2019, 10:55 AM   #6
ZDan
ZDan's Avatar
Drives: '23 BRZ
Ditto, -1.8 degrees rear camber is fine, preferable to less, even for street-only IMO
Old 11-07-2019, 11:47 AM   #7
jhalagian
Drives: 2015 brz
- Andrew
That is correct. Do you still recommend that with a S/C build. Primarily the reason I was trying to dial out a little more. Thanks
Old 11-07-2019, 12:47 PM   #8
Tristor
Tristor's Avatar
I'd say that trying to even it out to -1.8/-1.8 and then run more camber up front to compensate so it doesn't cause understeer. You shouldn't see accelerated tire wear or any issues with that amount of camber in the rear. See if you can get -2.5 or so in the front off some camber bolts.
Tristor is offline   Reply With Quote
Old 11-07-2019, 04:02 PM   #9
wparsons
wparsons's Avatar
Unless it's a drag race car, it's good as it sits.
flickr
*FREE alignment* with Purchase and install of Front Camber / SPL Rear Camber Arms! Corner3garage Southern California 188 04-24-2015 01:10 PM
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! Corner3garage Mechanical Maintenance and Tools 6 10-31-2013 03:40 PM
17x9 +42 & 245/40 w/ RCE yellow and maxed camber bolts jeebus Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 23 09-30-2013 10:25 AM
RCE Yellow spring kit, should I get the camber bolts? jflogerzi Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 07-20-2013 07:36 AM
