Old 09-21-2019, 10:41 AM   #1
DJ72
Drives: 2013 FRS
2013 Scion FRS engine failure
My 2013 Scion FRS with just 17,000 miles on it, had engine failure after getting the JO2(valve springs) recall. The diagnosis was rod bearing failure due to oil starvation. The cause was a blockage in the oil channels. This car was only ever serviced at a Toyota dealer. This is what caused engine failure in every 2013 Scion FRS that had this recall done. Apparently, the sealant they used for the job, got into the oil and caused the blockage. Toyota is very aware of the issue but has yet to take any responsibility. This does not affect models after 2013. The cost to the owner is between $6,000-7,000. There is a class action lawsuit being put together. It costs the owners nothing. I just want to be reimbursed for the repairs. Below is the lawsuit info.
Carlson Lynch, LLP
carlsonlynch.com
412-253-6359
DJ72 is offline   Reply With Quote
Old 09-21-2019, 06:59 PM   #2
Lonewolf
Lonewolf's Avatar
Drives: Moped
Don't forget to file a complaint with the NHTSA
Old 09-21-2019, 07:02 PM   #3
DJ72
Drives: 2013 FRS
Yes, I did that also. Great point, the more that also share there experience with the NHTSA on the website the better.
Old 09-21-2019, 07:18 PM   #4
Grady
Grady's Avatar
The failure is not Toyota's fault. it is a Dealer warrantable issue.
Old 09-21-2019, 07:20 PM   #5
GrantedTaken
I will never do this recall.
I am surprised people are still doing it after the disaster news
GrantedTaken is offline   Reply With Quote
The Following User Says Thank You to GrantedTaken For This Useful Post:
funwheeldrive (09-22-2019)
Old 09-21-2019, 10:47 PM   #6
DJ72
Drives: 2013 FRS
It not a dealer issue! First of all, a dealer will never acknowledge that the failure was due to there work from the recall. That has already failed for many. Secondly, Subaru sent specific instructions to be very careful when applying the sealant. Toyota had nothing in the recall instructions given to the dealers that instructed them on using the sealant. The vast majority of engine failure after the recall were the Toyota Scions. So, Toyota did instruct the dealers on how to properly handle these recalls. This engine failure is not only costly to the owner but also very dangerous. My son was driving this car.
2013 FRS engine failure at 62k speedy racer Issues | Warranty | Recalls / TSB 38 04-06-2018 07:28 PM
Engine Rod #3 Bent 2013 Scion FRS Brandond15 Issues | Warranty | Recalls / TSB 204 08-27-2016 01:43 PM
2013 scion frs engine scion123 Engine, Exhaust, Bolt-Ons 16 10-13-2014 10:03 PM
direct injector Failure , sand in the engine and on the engine aagun Issues | Warranty | Recalls / TSB 3 05-26-2014 03:46 AM
Will I get a check engine light on if the engine bay has a direct injection failure? Astroboy Engine, Exhaust, Transmission 7 03-29-2014 07:16 PM
