Old 09-14-2019, 01:11 AM   #15
soundman98
ProCrastinationConsultant
soundman98's Avatar
Originally Posted by mswbrz View Post
I got more baking soda than Minnesota
Transporting that across state lines is asking for a cavity search!
Old 09-14-2019, 01:12 AM   #16
soundman98
soundman98's Avatar
Originally Posted by GrantedTaken View Post
I zoomed in and saw the entire top of the battery it wet.
I would just replace the battery.
I had a tire that was low on air once. I replaced the car.
Old 09-14-2019, 01:42 AM   #17
ZionsWrath
Thanks
ZionsWrath's Avatar
NSFW
[ame]https://www.youtube.com/watch?v=Fx0Bkdz3VCk[/ame]
Old 09-14-2019, 02:07 AM   #18
mswbrz
mswbrz's Avatar
Drives: 2013 brz limited / galaxy blue
mswbrz is offline   Reply With Quote
Old 09-14-2019, 07:52 AM   #19
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
So basically just get battery cleaner at the nearest parts store for guaranteed results.
Old 09-15-2019, 02:53 AM   #20
Get some nitrile gloves, safety glasses, and wear some shitty old clothes. Take out that battery and hose down the whole area carefully so it doesn't spray around. Use more pressure once it's rinsed. soak the battery bracket and fasteners in fresh water. Scrape off the corroded shit remembering that it is saturated with sulfuric acid. Rinse often. Don't spread it around and don't kick up any dust.
Now rinse off the battery and wipe it down. Check the electrolyte levels per the owner's manual. It still applies.
humfrz (09-15-2019)
Old 09-15-2019, 03:33 AM   #21
I can't believe that YOU, of all people, forgot to tell him wear a respirator -
Old 09-15-2019, 03:37 AM   #22
Ya, go ahead and spray all those nasty, volatile organics around OR use a natural substance (baking soda) - your call, OP -
Grady (09-16-2019)
Old 09-15-2019, 02:41 PM   #23
The initial wetting is to prevent kicking up dust. Same goes for cleaning up rodent droppings.
humfrz (09-15-2019)
Old 09-16-2019, 04:59 PM   #24
norcalpb
norcalpb's Avatar
I used baking soda to clean my battery terminals. It was a mess would not recommend.
The Following User Says Thank You to norcalpb For This Useful Post:
RZNT4R (09-16-2019)
Old 09-16-2019, 08:39 PM   #25
Ya, well, just go ahead and spray sulfuric acid laced water all over the engine compartment - then wonder why the battery platform dissolves over time and then the battery falls out of the engine compartment -
Old 09-16-2019, 08:41 PM   #26
You don't apply it with a broom, silly -
norcalpb (09-16-2019)
Old 09-16-2019, 08:53 PM   #27
Obviously, most of you people didn't live in the shadow of the Great Depression!
We just didn't run into town to buy store bought stuff every whipstitch. We used what was available, like baking soda. After a box of baking soda (used for cooking) was partially used, the half used box was put in the bathroom to use for brushing our teeth. After it got too hard for that it was put in the ice box to absorb odors.
THEN, after it was all full of odors, it was used to neutralize battery acid.
SMH - at the spoilt generations.
Baldoak (06-27-2022)
Old 09-16-2019, 09:53 PM   #28
Ya, well, just go ahead...
You really are damaged goods, aren't you.
Decep (09-24-2020), humfrz (09-16-2019)
Should I consider battery corrosion protection on the brand new car? Busybee Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 19 04-27-2019 07:39 PM
Leaf buildup behind front wheels Borvor Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 8 02-26-2019 08:13 PM
Carbon buildup Qwimby1 Scion FR-S / Toyota 86 GT86 General Forum 46 08-10-2018 01:32 AM
Anti-Corrosion (ACF-50 vs Corrosion Block) nico_rsx Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 2 12-02-2017 03:57 PM
Buildup under spoiler GuyMcThunderJnk Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 4 06-12-2016 04:37 AM
