Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
09-10-2019, 04:14 PM | #29 | |
09-10-2019, 05:23 PM | #30 |
For daily duties you may need to block off some/all of the oil cooler.
Even wirh a thermostat closed, a certain percentage of oil still passes through the cooler.
http://www.ft86club.com/forums/showthread.php?t=133311 I'm only here for the biscuits |
09-10-2019, 05:28 PM | #31 |
Drives: 2017 Toyota 86
So,is the Ned oil cooler kit the same thing..As the Forester XT part # 21317AA070 and #21311AA170 Minus the hoses and clamps?
09-10-2019, 06:21 PM | #32 |
Drives: 2017 toyota 86
Yeah a 180f t-stat has 10% flow until 160f then gradually opens until fully open at 180f, but i believe what mike was saying is the oem sensor is post filter/cooler and is then only reading temp after its been cooled. So I could easily be at 190f coming out of engine but oem sensor is reading 170f going back to oil pan. With 0w20 im just not going to worry about it once oem sensor reads 160f ill full send. Maybe ill tap a line pre cooler someday to test it.
09-10-2019, 06:34 PM | #33 |
Into the sump?
If the sump is between 95-115° C "rule of thumb" says your good to go. Max prefered delta between coolant and oil is 10° C I believe Oil is best performance wise at 100-110°C, again, rule of thumb Not sure about this whole 0w20 oil thing, I've only ever used 5w30, but my climatic conditions may differ from you Have fun playing
09-10-2019, 06:49 PM | #34 | |
The Following User Says Thank You to CSG Mike For This Useful Post: | alphasaur (06-11-2020) |
09-10-2019, 08:48 PM | #35 |
Years of asking questions at the track, at the shops and running a R33 and a MX5 is all I've got.
There's alot of speed shop stuff on google as well IRT delta, prefered temps and other groovy oil stuff, good engineering principles and the basics are easy to find, also have a look at heavy industry, alot of information there IRT oil temps/lubrication/pressure I've followed these "rules of thumb" over the years and they have served me well. I'm happy for anymore info you have IRT oil temps and/or control, it's always fun learning I've come from a Nissan RB background where trying to control oil is the nemesis of every owner who tracks their car
09-10-2019, 09:22 PM | #36 |
FYI, our owners manual. It does say in next section a heavier weight oil can be used in extreme conditions. For DDing, especially with a oil cooler ill stick to the recommended weight.
09-10-2019, 10:24 PM | #37 |
Drives: JRSC BRZ SOLD
This is true, I purchased the kit for 2017+ models for my MY13 BRZ. Fits just fine. It was on clearance for $460 couldn't pass it up.lol
09-10-2019, 10:36 PM | #38 | |
I care not for fuel economy either I'm sticking with 5w 30 and I change it every 5k km Opinions may vary
09-11-2019, 02:33 AM | #39 |
Drives: 2017_86 2016_frs 2007_335i
i am using the 0w20 mutol eco engine oil,
going to try the 0w20 v300 soon. and 10-30 in all year long -10 to 0 in winter. ocean weather people say the v300 may need change early but i change the oil every 5000km or bit more if a track day close obd2 will come tmr hopefully and the oil cooler probability on next month i got one trackday at end of this month. will keep my eye on it and take some pic to share.
YouTube Video:http://www.youtube.com/channel/UCBXFeelPFI8XzGese8Eug-g
ins:zayliu.jiayu Build Journal:http://www.ft86club.com/forums/showthread.php?t=136068 "if in doubt flat out" |
09-11-2019, 03:03 AM | #40 | |
Same for your coolant temp Any idea where you get your temp and pressure readings from yet? Data is always nice to look at
09-11-2019, 05:22 AM | #41 | |
for sure there is oil temp and coolant but dont know about oil pressure tho hopefully i will find it all just by the app from the obd2 and harry's laptimer
09-11-2019, 07:23 PM | #42 | |
temp after 1 min temp after 30mins daily drive let me know any data i should keep my on eye on it
Similar Threads | ||||
SOLD - RacerX Oil Cooler with Auto Transmission Cooler and Temp Gauge | tws98 | Engine, Exhaust, Bolt-Ons | 0 | 05-28-2019 10:50 PM |
Oil Cooler Options for 2017 Manual BRZ 86 | TofuJoe | Engine, Exhaust, Transmission | 12 | 09-21-2017 11:26 PM |
2017 BRZ and Perrin Oil Cooler Install | JSube | Tracking / Autocross / HPDE / Drifting | 18 | 04-29-2017 07:49 AM |
