Alignment Spec Recommendations
Hi all,
I'm working getting another alignment for my car and I'm new to all of this, so I was looking to see if you had any suggestions given my current setup: Lowered on Eibach Sportline Springs: ~1.4 inch drop all around Vorsteiner V-FF 108s: 18x9.5 +40 Michelin Pilot Super Sports: 245/35/18 I currently have some slight wheel poke in the front -- I will be installing SPC camber bolts in the front along with SPC lower control arms in the rear before getting my alignment today. This setup would mostly be for daily driving aside from a handful of AutoX's each year. If you have any suggestions at all, I'd appreciate it. Thanks in advance! |
| The Following User Says Thank You to junior-subie For This Useful Post: | steel86gt (08-05-2019) |
#2 |
Drives: '13 FRS - STX
Maximum camber the bolts can give you up front without rubbing the strut with zero toe, -1.5ish degrees of camber in the back with 1/16" toe in rear (about 0.15 degrees toe in total iirc)
| Alignment recommendations | Geese1 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 40 | 07-22-2018 09:03 PM |
| Recommendations for alignment in Bay Area | Surj_brz | Northern California | 9 | 06-09-2017 12:26 PM |
| Need alignment spec recommendations | 8RZ | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 13 | 05-10-2017 09:53 PM |
| Alignment recommendations for my setup? | sqd | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-19-2016 01:33 PM |
| Recommendations for alignment in Socal | anewprelusion | Southern California | 18 | 01-13-2014 02:36 PM |
