| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
I just lost 1 pcs of adhesive weight on the wheel
Hi Guys,
I just lost 1 pcs of adhesive weight on a wheel. and this 1 pcs should weigh about 11/5 lb (which is about 1kg). Will this affect my wheel balance? Should I do wheel balancing?? |
#2 |
Drives: 2015 BRZ
Yes, its possible it will affect the balance. I had this happen in my older car and i had a lot of vibrations at highway speeds. Once i get it balanced again it had no issues.
#3 |
Professional Auto Fixer
Drives: 2016 Oceanic FR-S as Designed
2 pounds of weight is an absurd amount. Something is wrong.
Work Hard. Play Hard.
2016 Oceanic |
| The Following User Says Thank You to ActionMaxon For This Useful Post: | Leonardo (07-31-2019) |
#4 |
Actually I was wrong.
It was only a 0.5 OZ for 1 pcs? It looked exactly like this: https://www.coyoteaccessories.com/wh...weights/10006b Do you think it will affect the balance? |
#5 |
Oh ok. That's much more reasonable. Yes it will effect balance. You may not feel it if its a rear wheel. Front you likely will.
2016 Oceanic |
#6 |
#7 |
Yeah half an ounce doesn't seem like much but you'll feel it.
A couple weeks back I noticed an imbalance in my front wheels. (Stock wheels). I could feel the vibration around 62 MPH. Much over or under and I didn't really notice it. I checked all 4 and only the right front was off, and only by .5 oz.
2016 Oceanic |
#8 |
Rust bucket enthusiast
Wheels get balanced for a reason. Take it to a wheel shop and have them re-balance it. If you clean your wheels with a brush or pressure washer, maybe try to avoid the wheel weights when doing so.
#10 |
It brought a really funny picture to my mind!
| The Following User Says Thank You to Tcoat For This Useful Post: | soundman98 (08-01-2019) |
#11 |
Drives: frs
i don't balance my rear wheels on my frs and don't feel it at all, one little sticky like that on the rear wont be at all noticeable.
#12 |
Drives: C5, GT-86, '24 Colorado TrailBoss
you could go to harborfrieght and pick up these wheel weights and slap on the one that is missing. https://www.harborfreight.com/1-2-ha...hts-67226.html
| 18" TRD Wheel Weight? | mattyice | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 04-12-2021 10:36 AM |
| Help! Lost Wheel Lock Key | DonAngeloDM | Northern California | 4 | 04-28-2016 03:10 AM |
| Lost wheel lock nut - what to do next? | Trikle | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 03-17-2015 01:55 PM |
| Wheel weight, will I notice it? | Re~Mix | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 01-09-2014 03:29 AM |
| Wheel weight.. does it Matter? | karma003 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 64 | 08-22-2013 11:24 PM |
