Old 07-31-2019, 02:52 PM   #1
mitama
I just lost 1 pcs of adhesive weight on the wheel
Hi Guys,
I just lost 1 pcs of adhesive weight on a wheel.
and this 1 pcs should weigh about 11/5 lb (which is about 1kg).
Will this affect my wheel balance?
Should I do wheel balancing??
mitama is offline   Reply With Quote
Old 07-31-2019, 02:55 PM   #2
Vital
Drives: 2015 BRZ
Originally Posted by mitama View Post
Hi Guys,
Yes, its possible it will affect the balance. I had this happen in my older car and i had a lot of vibrations at highway speeds. Once i get it balanced again it had no issues.
Old 07-31-2019, 03:09 PM   #3
ActionMaxon
Professional Auto Fixer
ActionMaxon's Avatar
Drives: 2016 Oceanic FR-S as Designed
2 pounds of weight is an absurd amount. Something is wrong.
Work Hard. Play Hard.
2016 Oceanic
ActionMaxon is offline   Reply With Quote
The Following User Says Thank You to ActionMaxon For This Useful Post:
Leonardo (07-31-2019)
Old 07-31-2019, 03:18 PM   #4
mitama
Actually I was wrong.
It was only a 0.5 OZ for 1 pcs?
It looked exactly like this:
https://www.coyoteaccessories.com/wh...weights/10006b
Do you think it will affect the balance?
Old 07-31-2019, 03:22 PM   #5
ActionMaxon
Oh ok. That's much more reasonable. Yes it will effect balance. You may not feel it if its a rear wheel. Front you likely will.
2016 Oceanic
Old 07-31-2019, 03:44 PM   #6
mitama
wow... even if it's only about 0.03 lbs??
I should get one then..
Old 07-31-2019, 03:49 PM   #7
ActionMaxon
Yeah half an ounce doesn't seem like much but you'll feel it.
A couple weeks back I noticed an imbalance in my front wheels. (Stock wheels). I could feel the vibration around 62 MPH. Much over or under and I didn't really notice it. I checked all 4 and only the right front was off, and only by .5 oz.
2016 Oceanic
Old 07-31-2019, 03:58 PM   #8
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Wheels get balanced for a reason. Take it to a wheel shop and have them re-balance it. If you clean your wheels with a brush or pressure washer, maybe try to avoid the wheel weights when doing so.
Old 07-31-2019, 04:00 PM   #9
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Re-balance wheels, ask for sticky weights.
Current DD: M235i
8RZ is offline   Reply With Quote
Old 07-31-2019, 04:40 PM   #10
It brought a really funny picture to my mind!
soundman98 (08-01-2019)
Old 07-31-2019, 04:50 PM   #11
evomike
Drives: frs
i don't balance my rear wheels on my frs and don't feel it at all, one little sticky like that on the rear wont be at all noticeable.
evomike is offline   Reply With Quote
Old 07-31-2019, 04:52 PM   #12
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
you could go to harborfrieght and pick up these wheel weights and slap on the one that is missing. https://www.harborfreight.com/1-2-ha...hts-67226.html
SuperTom is offline   Reply With Quote
18" TRD Wheel Weight? mattyice Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 04-12-2021 10:36 AM
Help! Lost Wheel Lock Key DonAngeloDM Northern California 4 04-28-2016 03:10 AM
Lost wheel lock nut - what to do next? Trikle Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-17-2015 01:55 PM
Wheel weight, will I notice it? Re~Mix Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 01-09-2014 03:29 AM
Wheel weight.. does it Matter? karma003 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 64 08-22-2013 11:24 PM
