Drives: Frs
need help!!! tire rubbing sawybar and frame
Hi, I just installed my MCA red series coilovers.
I got tire rubbing the sway bar and frame on the front. My car is running stock rim ,225/45/17 re71, stock height, -3 camber front. Running stock rim, should not rubbing. Anyone has same issue? any advice? Thank you. |
#2 |
Country Boy 4 Life
I would add a spacer or decrease the amount of camber you have. Bolt on spacers are easy to install, will flush up your OEM wheels, and will not modify your car permanently. I'd suggest 25mm front and 30mm rear.
Then, Get an alignment!
I LIKE TIRES! |
| The Following User Says Thank You to Leonardo For This Useful Post: | strat61caster (07-30-2019) |
#3 |
Drives: 2017_86 2016_frs 2007_335i
the stock size is 215 45 17 and u running on a 225 45 17
first of all that wrong, i dont think it will help with the extra 10mm and it is just too much camber either less offset wheel or less camber if u really wanna a wider tires buy yourself a new set of wheels and calculate the number on the https://www.wheel-size.com/size/scion/fr-s/2016/ i am on the stock suspension rpf1 17x8 +45 re71r 245 40 17 going to install the camber bolt in next week and alignment planning set it -1.5 in front, and see if it rubbing anything
YouTube Video:http://www.youtube.com/channel/UCBXFeelPFI8XzGese8Eug-g
ins:zayliu.jiayu Build Journal:http://www.ft86club.com/forums/showthread.php?t=136068 "if in doubt flat out" |
#4 |
Benz Tech
Drives: 2017 BRZ Premium
You started a second thread with the exact same title hoping for magical different answers?
You have high offset wheels, wide tires and a ton of camber. Fix one or all and it won't rub. This isn't hard to understand. https://www.ft86club.com/forums/showthread.php?t=135992 |
| The Following 3 Users Say Thank You to maslin For This Useful Post: |
| LCA and Tire rubbing | Andyxin | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 03-30-2019 09:16 PM |
| Tire Rubbing Fender Liner Help | Pizzachicken | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 20 | 12-04-2018 09:59 AM |
| will this wheel and tire combo fit with stock suspension without rubbing? | Andreasbrz14 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 9 | 05-23-2017 04:25 PM |
| Help with tire size please! Too much rubbing | Itssrayyxd | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 12-15-2016 06:24 PM |
| Tire rubbing sound, Please Help | dco107 | Scion FR-S / Toyota 86 GT86 General Forum | 6 | 01-11-2013 10:05 AM |
