Old 07-21-2019, 09:16 PM   #29
Snitko13
Drives: brz
Originally Posted by Grey86 View Post
I think you've damage the o2 sensor while changing the exhaust, they can be very sensitive, with a slight knock they can be faulty. but still doesn't explain why the car shuts off right away since you can run fine with only one.
long shot but are all the grounds connected? have you accidentally swapped any plugs, or accidentally have the o2 sensors cables swapped around ?
i did think that i accidentally swapped the o2 sensors as well so when i tried to switch them, one of the sensors wasnt even long enough to connect to the harness so my guess is i have them installed the right way
Snitko13 is offline   Reply With Quote
Old 07-21-2019, 09:18 PM   #30
Snitko13
Drives: brz
i dont have the tester but will get one tomorrow and see if they are actually bad
Old 07-21-2019, 09:33 PM   #31
Grey86
Grey86's Avatar
Drives: Tornato grey 86
Could be another long shot, but have you tried putting the oem headers and fp back on and then turning the car back on ? when i swapped out my exhaust i only did the cat back and ran like that for a week or two so the ecu can adjust properly, maybe having too much change all of a sudden could be upsetting the ecu ?? i know you can swap the entire thing out and should run perfect right away but something seems to be upsetting the ecu?
Grey86 is offline   Reply With Quote
Old 07-21-2019, 09:43 PM   #32
Snitko13
Drives: brz
thats also a possibility and will try that out tomorrow and see. who knows
Old 07-21-2019, 10:14 PM   #33
I wonder if this isn't the result of using the wrong kind of anti-seize. They say it destroys o2 sensors.
If this is really a thing, I wonder how much it takes. Just spitballing here.
Old 07-22-2019, 12:57 AM   #34
Snitko13
Drives: brz
ive never heard of that but i did use the anti sieze that came from tomei with my headers
Old 07-22-2019, 01:07 AM   #35
That totally negates my concern. I think that particularly the copper stuff does something weird when it heats up and vaporizes.
BRZ wont start in hot weather! Coop Issues | Warranty | Recalls / TSB 3 06-28-2018 06:24 PM
INSTALLED TURBO, CAR WONT START Nightflo Forced Induction 23 06-23-2018 10:26 PM
Car wont start? Anyone else? ScionFrsFan Issues | Warranty | Recalls / TSB 150 06-09-2017 10:35 PM
car wont start after tune JesseTheFlash Software Tuning 7 12-17-2014 01:43 PM
Car Wont Start Up HELP !!*** ScionFR-S Issues | Warranty | Recalls / TSB 20 11-28-2013 02:01 AM
