Drives: BRZ 2020
BRZ take 2-3 seconds to start and feels unresponsive below certain amount of fuel
Hello,
I have an 2015 BRZ, recently i noticed that when the fuel level drops below 3/4 the car cranks for 2-3 seconds and than starting. (It's always starting eventually, never stalled) I've also noticed some performance decrease in when the fuel level below 3/4. The weird thing is that when the fuel is above 3/4 everything's just fine. I took the car to my mechanic and we started a process of cleaning the injectors. He cleaned once, still didn't help so we scheduled to do another cleanup. I really trust him and he's taking car of my car for a while now, but what i don't understand is how is it possible that the issue happens only above certain fuel level (3/4) - if the problem is in the injectors. Any help would be appreciated, Thanks
#2 |
Run it up on a dyno if you can
That will tell you more than a shot gun approach, and may end up cheaper
http://www.ft86club.com/forums/showthread.php?t=133311 I'm only here for the biscuits |
| The Following User Says Thank You to 86MLR For This Useful Post: | Tcoat (07-18-2019) |
#3 |
Drives: 2013 Scion FR-S Series 10
First, try to answer some of the following. I think it will help provide people with some insight.
Any mods? How long have you had the car? I see it is a 2015, but is this a new issue, or did you just buy the car? How old is the battery? - A long crank is usually a sign of a dying battery. Have you replaced the engine air filter? Did the weather change recently and get really hot? Are you running the AC on startup and while driving? Are you running 93 or higher? Did you switch to a different brand of fuel recently? Have you tried unplugging the battery overnight and plugging it back in to reset the car? After clearing up those basics, then I would get into injectors and other stuff. |
| The Following 2 Users Say Thank You to mazeroni For This Useful Post: | soundman98 (07-18-2019), Tcoat (07-18-2019) |
#4 | |
I would think it is a fuel filter issue if it is fine when the tank is full. Could be in the evap system as well though. Edit: and what Maz said!
#5 | |
Drives: BRZ 2020
Thanks for the reply, please see answers above ^ |
#6 |
Wheels for Brains
I think you misunderstood the part about unplugging the battery that @mazeroni mentioned.
Unplug the battery from the terminal and leave it like that overnight. Plug it in in the morning, start the car, and allow it to idle for 10 minutes. This will allow the ECU to relearn the idle and throttle. |
#7 | |
Undisputed El Presidente
Drives: Zenki 37J ZN6
#8 | |
Drives: BRZ 2020
#9 |
If it is related to fuel level I would start with the fuel pump/inspect inside the tank.
| Which packages/models/years came with push start, LED dash/fuel gauge? Heated seats? | Scremin@ATS | BRZ First-Gen (2012+) — General Topics | 11 | 03-25-2019 06:15 PM |
| E85/Flex fuel hard start? | iketiak | Engine, Exhaust, Transmission | 18 | 01-14-2017 08:12 PM |
| Flex Fuel cold start stumble | post_break | Software Tuning | 12 | 04-02-2014 02:40 PM |
| 0-60 in 6.1 seconds? | SUB-FT86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 57 | 01-04-2012 11:14 PM |
