CANADA Canada
Old 04-16-2015, 11:04 PM   #15
Wilso
"Patience young Padawan"
Drives: 2017 Crystal White BRZ
So the switch on the inside of the trunk isn't pressed? That's the only issue I've ever run into with the trunk when I pressed it by accident
Wilso is offline   Reply With Quote
Old 04-17-2015, 10:09 AM   #16
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
Bet its the touch pad switch failure. I see it quite commonly on older Equinox/Orlando/Terrains at work with the same symptoms.
BRZZZZZZZZZZ is offline   Reply With Quote
Old 04-17-2015, 11:32 AM   #17
What ever it was was fixed 2 years ago!
Old 07-14-2019, 08:58 PM   #18
Regular
Drives: 2017 BRZ
So hate to bring this back after 4 years, but now MY17 trunk is experiencing this problem...
Valet button is off.
Release on the dash and button on the trunk does not work.
When I hit the button on the fob, it makes the beeping noise, but trunk stays still as a rock.
Any suggestions?
Regular guy... Not so regular car
Regular is offline   Reply With Quote
Old 07-14-2019, 11:11 PM   #19
Jordanwolf
Rice King
Jordanwolf's Avatar
Any suggestions?
Use deadly force.
Glorious Honda.
Jordanwolf is offline   Reply With Quote
Old 07-15-2019, 10:04 AM   #20
wparsons
wparsons's Avatar
Any suggestions?
Can you hear the click of the release mechanism too, or just the beep?
flickr
Old 07-15-2019, 10:07 AM   #21
Regular
Drives: 2017 BRZ
Just the beep. Mechanism seems to be the thing that’s not releasing
Old 07-15-2019, 01:04 PM   #22
Push down firmly on the lid while activating the lock. I had a twig get in between the lid and the car body that put too much force on the latch for it to release. Had to put a fair bit of weight on the lid to relieve the pressure so it would work.
Bring by the house and I will lean on it for you.
Old 07-15-2019, 01:30 PM   #23
Jordanwolf
Rice King
Jordanwolf's Avatar
Originally Posted by Jordanwolf View Post
Use deadly force.
Glorious Honda.
The Following User Says Thank You to Jordanwolf For This Useful Post:
wparsons (07-15-2019)
Old 07-15-2019, 01:34 PM   #24
Regular
Drives: 2017 BRZ
Use deadly force.
All right. I'll just give'r
Old 07-15-2019, 01:39 PM   #25
Old 07-15-2019, 01:41 PM   #26
If you still can't get it you may have to go in through the back seat and use the manual release.
Old 07-15-2019, 01:52 PM   #27
Jordanwolf
Rice King
Jordanwolf's Avatar
Do be cautious not to push in the middle of the trunk as you'd probably dent it. Pretty sure I've slightly dented my door by leaning on it while washing.
Glorious Honda.
Old 07-15-2019, 01:53 PM   #28
Jordanwolf
Rice King
Jordanwolf's Avatar
The key IS the manual release. What you're suggesting is a life hack.
Glorious Honda.
Raven down! Mechanical failure :( rasec29 Issues | Warranty | Recalls / TSB 151 10-08-2013 11:25 AM
BC Coilover failure in the past phenom86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 10-25-2012 05:07 PM
BRZ Limited Electronic Trunk Release diirk Electronics | Audio | NAV | Infotainment 4 09-17-2012 11:42 AM
Ringland Failure? iLuveKetchup BRZ First-Gen (2012+) — General Topics 9 01-30-2012 12:25 PM
A pessimist's take on sales success / failure Mess11 Scion FR-S / Toyota 86 GT86 General Forum 137 11-24-2011 01:10 PM
