#1219 |
Drives: 14 FRS Monogram, 05 Mazdasped Miata
Flip-flopping between E85 and 93
Ironically I have an E85 station a stone's throw from my house, but the next closest one is more than 50 miles away. Instructions that came with the OF T say not to leave it in a hot car. My car is black and lives in Florida. It would be easy enough to flash it back to 93 if I can't find any E85, but if the tablet won't survive those conditions, that takes away an option.
Question two, and tell me if this is silly, how do you handle the transition if you drive up with a nearly empty tank of 93 and fill with E85. Do you just flash it there at the station and be on your way? Vice versa with alcohol to 93? |
#1220 | |
86
In regards to question 1, some people keep a jerry can of E85 at home just in case. In regards to question 2 @steve99 has some very useful posts in his sig detailing everything you need to know and more but the answer from his post is; http://www.ft86club.com/forums/showthread.php?t=67310 Precautions As you have no flex fuel sensor you need take a couple of precautions when changing from petrol to E85 or the other way around.
#1221 | |
#1222 | |
Drives: 2016 Subaru BRZ
He set an appointment up with me, and over about an hour got my tablet restored, the new tunes loaded, and verified with me that it was all correctly flashing. Tablet works great now, exactly as intended! Thank you so much, OpenFlash, this is great stuff I feel confident recommending. |
#1223 |
Drives: 2014 ASPHALT FR-S MT
If I have a 2014 car and I’m getting 2019 fa20 long block if I switch over the harness from that 2014 that blew to the new one my tune should still work right ?
#1224 |
Drives: UK GT86
There are various sensors that will need changing too, there's likely a post somewhere on here.
.: Stealth 86 :.
#1225 |
Drives: FT86
Bunch of stuff needs swapping
https://www.ft86club.com/forums/show...0&postcount=22 Other drama is while the ecu and current tune in ecu will get the 2017 engine running, the tuning required to run the 2017 engine is a lityle different to the earlier motors, about ,4 degrees less timing. And you cannot simply flash the 2017 rom as its not compatable and car wont start. You will need to tweak the tune to run well with the 2017 motor |
#1226 | |
Ok that’s not that bad the guy said he also put the cam gears are they different design from the 13 on the the 17 block was that necessary or can it be addressed with oft tables ? Sent from my iPhone using Tapatalk |
#1227 |
Drives: FT86
Yeah its certianly possible the cam phasers are different not sure
#1228 |
Drives: 2018 Toyota 86
it gives me a calibration code and the read and wright are grey and can’t do anything, i have a 2018 toyota 86 wondering if the newer cars can’t work with the oft unless you do something on the computer to make it work i’m not sure
#1229 |
Drives: FT86
Ok if read button went grey, it read your stock ecu ok.
The read is grey as oft doesnt have your ecu calid in its onboard database. Go to ecu info under tuning, find you ecu calid be somethung like ZA1JN10C Then go to the openflash support site and downliad tune files for your cakud then upliad to rablet anf flash https://support.openflashtablet.com/support/home Your specific issue https://support.openflashtablet.com/...talling-my-oft |
#1230 |
Drives: 2017 toyota 86
Open flash tablet v2
Im really curious on whats going on
After the tablet read my ecu, the “write” option is no longer grey. And i clicked it and there was already 3 maps. Stage 1....... stage 2...... stage 2..... Is that normal for the v2? It like downloaded the maps by itself. Can someone please help me or tell me whether its normal or no |
#1231 | |
Drives: 2013 WRB BRZ
#1232 |
Drives: 2020 BRZ tS
So I have a few questions about OFT and Headers:
I've heard the OFT Catted Header tune was designed around the FT86 Speed Factory Header. Is this true? Does it play well with any other Headers on the market? What about their Catless tune? Which available Headers does it work best with? Thank you, kindly. |
| WTB: Open Flash Tablet | TOZER | Canada Classifieds | 3 | 07-05-2015 07:13 PM |
| Open Flash Header & Open Flash Tablet | Calavera | Engine, Exhaust, Bolt-Ons | 9 | 05-11-2015 08:27 PM |
| FS: open flash headers / open flash tablet - SOLD | alanhung85 | Canada Classifieds | 12 | 02-10-2015 02:08 PM |
| FS: Open Flash Tablet (OFT) | mex2309 | Engine, Exhaust, Bolt-Ons | 1 | 10-29-2014 02:49 PM |
| Open flash tablet. | cooldandani | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 02-22-2014 07:14 PM |
