Old 01-02-2019, 12:48 PM   #15
E'sFR-S
Drives: 2013 FR-S Manual
Any fix to this?? I have the same issue. Suspension feels fine a speed. Just pops in my driveway.
E'sFR-S is offline   Reply With Quote
Old 04-16-2019, 07:50 AM   #16
maicolp
Drives: toyota gt86 1st edition
same here... sounds like cluncks and cracks when going slow on paved roads and over bumps. i can even feel the vivration thru my feet
maicolp is offline   Reply With Quote
Old 04-16-2019, 08:15 AM   #17
steve99
Drives: FT86
Likely rear deck crwaking noise , their is TSB out on that
Old 04-16-2019, 08:24 AM   #18
ermax
ermax's Avatar
The EPS is also known to clunk and rattle at slow speeds over small bumps like road reflectors. There is a rubber bushing that couples the motor to the worm gear that falls apart. This part isn’t sold separately for our car but Toyota sells it for several of their other cars. It’s $4 and easy to install. I wrote a DIY on installing the part. When I get to a computer I will dig up the link and update this post.
Old 06-04-2019, 05:09 PM   #19
will86
Drives: Orange GT86
Hi guys - does my video below sound similar to your issue?
Did you find out what it was in the end?
https://photos.app.goo.gl/XC7hRS3o3EScou1y5
will86 is offline   Reply With Quote
Old 06-11-2019, 09:27 PM   #20
JBezugs
Good Job Subaru!
JBezugs's Avatar
Drives: '24 CX-50 Meridian
Bump as it sounds like I'm having the same noises. Mostly from the rear of the car/underneath the centre console.
JBezugs is offline   Reply With Quote
Old 06-12-2019, 01:35 PM   #21
will86
Drives: Orange GT86
Mines defo from the front, strange
Sent from my Pixel 3 XL using Tapatalk
Old 07-08-2019, 06:44 PM   #22
bottle
Any updates on this? I'm also having similar noises but unable to find out the source. Front passenger side for me.
bottle is offline   Reply With Quote
Old 07-09-2019, 03:48 AM   #23
will86
Drives: Orange GT86
Mine was fixed by greasing the front anti roll bar
Old 07-09-2019, 11:26 AM   #24
JBezugs
Good Job Subaru!
JBezugs's Avatar
Honestly, I think the source of my rattle is my exhaust moving around. I switched to an extended hanger on one side of the muffler to level out the tips in the rear, and my rattle/creak under the centre and rear of the car has gotten a bit worse.
Not sure how to keep the exhaust from moving around, I’ve only had this issue since a few months after switching to a JDL 4-2-1 EL header.
Old 07-22-2019, 12:07 AM   #25
toast
Drives: 14 BSP Edelbrock BRZ
I'm getting the same noise on the driver side, stock struts on RCE yellow springs. Started a couple months ago with a single pop when backing up and turning out of my driveway. It is now several quick pops when in reverse and then a couple again when moving forward, all with the wheel cranked pretty hard. I checked sway bar end links on both sides, went so far as to remove one endlink and drive around that way. No change. I replaced the driver side strut top hat today. No change.
This is the first time I've seen someone suggest the sway bar itself needs to be lubed - I can't rule that out since I never disconnected both end links, the bar still would have been moving around. Going to try that next.
Simulating turning by putting a low profile jack under the tire doesn't result in the clicking. I think it requires suspension movement with different loads on each side along with steering turns.
I'll update after lubing up the sway bar mounts.
toast is offline   Reply With Quote
Old 09-12-2022, 01:41 AM   #26
robbiehhhh
Drives: 2017 BRZ 2004 Evo VIII
Hey mate,
Sorry to revive
Did you manage to fix it?
robbiehhhh is offline   Reply With Quote
Old 09-14-2022, 10:08 AM   #27
toast
I wound up pulling the sway bar mounts off and relubing to fix it. Permanent fix was adding a zerk fitting to each mount and squirting lube in each spring.
pooping noises
"Popping" noises going over bumps vividracing Suspension | Chassis | Brakes -- Sponsored by 949 Racing 27 04-15-2015 03:29 PM
Unexplained noises ap5512 Issues | Warranty | Recalls / TSB 1 02-13-2015 11:48 AM
Weird noises mamamiaellis Issues | Warranty | Recalls / TSB 4 05-30-2014 05:17 PM
various noises abutterman Issues | Warranty | Recalls / TSB 0 10-23-2013 01:26 AM
