Drives: FRS 2013
AC not blowing any cold air
Hello all,
I have a 2013 FRS with about 150k km on the odo, and the AC has stopped working. It was working fine last year during the summer, blew ice cold AC instantly the button is pressed, and now it blows ambient temp. So far I've checked all fuses, and swapped the horn and AC relays to no effect. When I press the AC button, the AC compressor does start to spin and both front fans turn on as well. However, there is no cold air regardless of how long I wait nor how fast I'm driving. I've checked all lines and there doesn't appear to be any damage. The exposed part of the condenser in the grille is a little beat up from road debris and bugs, but nothing major. Any tips? |
#2 |
Yep, I suggest you take your car into a shop and have them check for leaks in the system and recharge with refrigerant.
humfrz |
| The Following 7 Users Say Thank You to humfrz For This Useful Post: | Dadhawk (05-30-2019), DarkPira7e (05-30-2019), jcw99 (07-26-2021), maslin (05-31-2019), reeves (05-30-2019), soulreapersteve (05-31-2019), soundman98 (05-31-2019) |
#3 | |
Drives: frs
The easiest fix is AC Pro, it does work, again, assuming you don't have any leaks. I' ve used it on lexus rx and it worked great. But i would do it the correct way with AC manifold and vacuum pump. All can be rented from auto zone. Wear goggles and gloves if you're going to mess with ac system. |
#4 |
Professional Mechanic
Drives: 2017 86 6MT Oceanic
NO NO NO NO NO NO NO NO
That junk is just shoveling the cost forwards and amplifying it. 1: To properly service, nevermind diagnose, an AC system you're going to need a machine to recover what's in the car, a vacuum pump, a refrigerant scale, a set of gauges and an oil injection gun. An AC refilled with junk in a can will never work as well one that's been properly serviced. 2: To properly leak test a system you're going to need some nitrogen at about 200 PSI and a bottle of soapy water or a high sensitivity ultrasonic mic, or if you're unlucky, some AC dye and a UV lamp if it's a really small leak (like I had to find today on a '12 civic) 3: Any workshop that tests incoming cars with a refrigerant identifier will spot the leak sealants in junk like acpro and instead of paying for just a quick leak test and a service, now you'll be paying for a condenser and a complete system flush before any diagnostic gets done. Modern condensers use extremely fine conduits that get clogged by leak sealers. 4: Refrigerant with stop leak in it is considered contaminated and has to be sequestered and destroyed. 5: Most shops with an automatic service machine will refuse to work on something that has stop leak in it because it gums up the solenoid valves. Would you DIY your fridge? just take it to a shop, the amount of equipment and expertise needed to do this well is not negligible, and the cost of mucking it up yourself can get astronomically high. |
| The Following 12 Users Say Thank You to RZNT4R For This Useful Post: | Grady (05-30-2019), gravitylover (06-02-2019), humfrz (05-30-2019), jcw99 (07-26-2021), maslin (05-31-2019), Razorlor (06-01-2019), RToyo86 (05-31-2019), soulreapersteve (05-31-2019), soundman98 (05-31-2019), Teseo (05-31-2019), theadmiral976 (05-30-2019), Ultramaroon (05-31-2019) |
#5 |
Do you even need A/C up there in Toronto?
Never been there myself... just curious how warm it actually gets there. |
#6 |
Drives: 2013 Scion FRS
Ooh pm me a price I have not been able to play my Jethro Tull Collection for years
#7 |
Drives: Scion FR-S
Listen to RZNT4R!!!
There’s a couple reasons why your AC doesn’t work. Taking it to a shop that can recover what refrigerant is left can tell you if there’s any missing but as well it will tell you the pressures of the compressor. If the compressor isn’t within operating spec, then it’s the compressor. If you are missing refrigerant then you will spot a leak either noticeable or not. Start from the compressor and follow both AC lines all the way to the firewall to see if there’s any leaks , if no leak is found, you can put die into the system when you recharge it and it will show once it leaks. Another possibility can be that your blower motor isn’t turning on as well. Best advice, Go to a reputable place you can trust. I’m a mechanic at a dealership and I recommend people to go to people who know what they are doing over anything. Sometimes that means even going to the dealership. But in my opinion it might be more money going to the dealership, but they will fix your problem. Another piece of advice is that you can always have them diagnose it, and then do the fix yourself. |
| The Following 2 Users Say Thank You to jaime3 For This Useful Post: | humfrz (05-31-2019), soundman98 (05-31-2019) |
#8 |
| The Following 2 Users Say Thank You to humfrz For This Useful Post: | gravitylover (06-02-2019), jcw99 (07-26-2021) |
#10 |
#11 |
Benz Tech
Drives: 2017 BRZ Premium
#12 |
The lowest I have seen on my dash is -40C.
The highest I have seen on my dash is +40C.
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | gravitylover (06-02-2019), maslin (05-31-2019) |
#13 |
| The Following 2 Users Say Thank You to Fast13FRS For This Useful Post: | gravitylover (06-02-2019), humfrz (05-31-2019) |
#14 |
| AC Blowing Hot Air on everything but LO | pooyab | Issues | Warranty | Recalls / TSB | 13 | 12-31-2024 09:06 PM |
| Air blowing out of vents with AC/fan off??? | StraightOuttaCanadaEh | Issues | Warranty | Recalls / TSB | 16 | 07-11-2017 10:57 PM |
| Anyone Else? Hearters Blowing when off. | Kiske | Issues | Warranty | Recalls / TSB | 7 | 04-09-2014 06:22 PM |
| How cold is your a/c blowing? | jermyzy | Issues | Warranty | Recalls / TSB | 68 | 08-18-2013 04:29 PM |
| Supra Blowing Up | radroach | Off-Topic Lounge [WARNING: NO POLITICS] | 2 | 07-21-2013 10:14 PM |
