| Software Tuning Discuss all software tuning topics. |
Drives: 2013 Scion FRS
EcuTek not reading engine codes?
So I have a CEL and thought I'd use my ecutek cable to see if it could tell me what code it was. Plugged in and software needed to be updated, So I updated. Detected vehicle and ran the Vehicle DTC Tool.
The following is what it showed me: "Performing DTC Operations on... Reading DTCs... OBD Error during reading DTCs: No Response to ODB Request End of DTC Operation Any thoughts? |
#2 | |
Drives: FT86
Thaat look like no connection to obd port. Check obd cavle plugeed in all the way to obd port Check you have ignition full on not jist accessory but engine stopped. Also see if ecutek will do logging or a query ecu. Looks more hardware issue to me |
#3 |
Drives: brz 2017 hksv2
but strange that it detected correctly the vehicle then
| The Following User Says Thank You to tomm.brz For This Useful Post: | snowdog (05-10-2019) |
#4 |
Took it in to the auto parts store and tried their CEL reader.
P0390 P0391 Do you think this is tied to the tune or something else? I would still like to know if others have had ECUtek DTC problems |
#5 |
if they read CEL than as steve said is something about your personal cable not doing goood connection or messed up drivers in your Windows, not tune related
#6 |
The OBD connecters are well known to be flaky and give intermittent connections. In one case I was forced to buy a cable extender to complete a read and write.
#7 | |
Drives: FT86
I have 3 ecutek kits 2 cables and blutooth, never had a problem reading dtc from any brz\86 |
| The Following User Says Thank You to steve99 For This Useful Post: | snowdog (05-11-2019) |
| Lean engine codes p0171 | zackegle | Issues | Warranty | Recalls / TSB | 23 | 03-14-2022 01:17 PM |
| ECUTek Cable not reading OBDII Anymore | Cal3000 | Software Tuning | 16 | 08-29-2019 12:28 PM |
| Can Ecutek disable diagnostic codes? | Kiske | Software Tuning | 3 | 05-16-2015 05:05 AM |
| Reading codes for TPMS | B-R-Z | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 15 | 03-31-2015 02:04 PM |
| Check engine light on but no codes!?!? | midnight23 | Engine, Exhaust, Transmission | 9 | 08-01-2014 12:20 PM |
