Drives: 2017 Subaru BRZ
Greddy T518Z Whp
Im making 338whp with greddy t518z with dw 700cc fuel injectors 65c fuel pump
Skuns 2 oil cooler Radium engineering dual catch can Competitive stage 3 clutch with forge flywheel and omni 3 bar map. Is this ok? ![]() ![]() Sent from my SM-G960W using Tapatalk |
| The Following User Says Thank You to j_ros94 For This Useful Post: | JBezugs (05-16-2019) |
#2 |
Not sure what your asking? With knowing fuel type, tuner and PSI... We don't read minds
Sent from my ONEPLUS A5010 using Tapatalk
2013 Series 10 FRS #553
#3 |
Rust bucket enthusiast
This is like holding a lit match under paper. It's only fine until it's not fine. There's no way of knowing if it's too close to the paper until it ignites.
| The Following User Says Thank You to DarkPira7e For This Useful Post: | DaBoBo21 (05-07-2019) |
#4 |
94 pump tuned by sasha from onpoint dyno and he said peak boost was 13 psi
#5 |
Drives: Black BRZ
How many miles have you had on this kit so far with the 338whp tune?
Is this a daily driven car? Any autocross or track days? Are you on the stock motor mounts? Stock Subframe and diff bushings as well? Is it true that this setup actually spools surprisingly quick for what it is? Do you find it kind of falls on its face at redline or does it feel strong all the way? Any regrets on your build so far? Excuse all the abrupt questions but I currently have the biggest hard on for this kit - to me it seems like the best bang for buck. Thanks for posting this up
#6 | |
#7 |
Drives: brz 2017 hksv2
looks good
your radium catch can crank side (on the right, in your picture) seems routed wrong tube tube that comes from the crank should go in the upper hole of the catch can, according to the radium instructions |
| The Following User Says Thank You to tomm.brz For This Useful Post: | j_ros94 (05-26-2019) |
#8 | |
#9 |
That's some solid power!
Do you have a picture of the full curve? |
#10 |
#11 |
Drives: Q5 + BRZ + M796
Have them pull out that useless sound tube too.
#12 | |
#13 |
#14 | |
| The Following User Says Thank You to j_ros94 For This Useful Post: | jflogerzi (05-10-2019) |
| GReddy T518Z Turbo Kit | Richytort | Engine, Exhaust, Bolt-Ons | 4 | 09-01-2017 02:39 AM |
| FS: GReddy T518Z Turbo | Jefffrs | Engine, Exhaust, Bolt-Ons | 2 | 08-15-2014 01:08 PM |
| BRZ GReddy t518z | NOTORIOUS.BRZ | BRZ Photos, Videos, Wallpapers, Gallery Forum | 26 | 04-15-2014 03:15 PM |
| GReddy T518z+Greddy CS GTS Ver 2. Video + pics (not tuned) | NOTORIOUS.BRZ | Engine, Exhaust, Transmission | 21 | 09-24-2013 07:09 PM |
