Old 04-16-2019, 04:21 PM   #57
007BRZ
007BRZ's Avatar
Drives: 2017 BRZ Yellow Spec Ed 1of500
Rattle Recently started in Neutral while in Idle
Believe what you will, good luck finding a solution.
Rattle Recently started in Neutral while in Idle on my 2017 BRZ, but I just installed a Complete ACT HD Clutch kit with the new OEM TOB with the new grease that does not dry out and burn up and a Perrin Transmission support block and a Perrin Fork. My idle goes down to 800 and it's there. I'm removing the Perrin Block (which lets you hear every gear shift in the cabin) and having my tuner (James Martin) correct my idle.
The ACT HD clutch has a light weight fly wheel and I knew there was probably going to be some chatter, especially for the first 1000 miles.
I am sure that nothing is lose in the clutch
Will see if this makes it go away.
007BRZ is offline   Reply With Quote
Old 03-01-2021, 04:21 PM   #58
gpvecchi
gpvecchi's Avatar
Any updates on this? Mine started doing the same...
I noticed that many people with this issue have Motul oil...
Cold start question retrosmiths Scion FR-S / Toyota 86 GT86 General Forum 106 11-15-2016 03:14 PM
Cold start up popping noise Weeber Issues | Warranty | Recalls / TSB 51 09-23-2016 01:54 PM
backfire at cold start FreaQshoQ Scion FR-S / Toyota 86 GT86 General Forum 15 10-16-2013 07:21 AM
White Smoke cold start up in Cold Weather (turbo cars) whitefrs Forced Induction 17 09-25-2013 06:05 PM
MT, neutral 15-10mph slowing, ratcheting noise bcj Engine, Exhaust, Transmission 7 04-18-2013 01:33 AM
