Old 04-09-2019, 12:43 AM   #15
Originally Posted by PandaSPUR View Post
Interesting find... So if I keep my foot on the clutch longer (i.e. keeping the contacts together) then I can let that energy pass between the contacts without the arc, thus increasing the longevity of the switch?
Exactly. Try standing on the clutch until after the starter quits on its own.
jcw99 (04-11-2019), PandaSPUR (04-10-2019)
Old 04-09-2019, 10:19 PM   #16
geraldjust
Drives: MR2, Sliver BRZ
I from my testing it seems like it lets go the starter very quickly though the ST cut relay. But delays around 2 seconds to let go the ST relay. So if you wait more than 2 sec should reduce the arching.
Always looking to tinker with something..
geraldjust is offline   Reply With Quote
The Following User Says Thank You to geraldjust For This Useful Post:
Old 04-10-2019, 12:40 AM   #17
Oooo... check that out. I see what you did there. Thanks for doing that test!
Yeah, NVM the starter motor cut. Wait at least two Mississippis.
Old 04-10-2019, 01:56 AM   #18
geraldjust
LOL if worse come to worse add a reverse diode next to the relay coil in the circuit it will cut any spike in voltage. it will stop any voltage from arching though the contacts.
Old 04-10-2019, 01:59 AM   #19
Yup. Outside the scope of this thread, though.
Shame on Toyobaru for cheaping out there. That's some weak sauce.
Old 04-10-2019, 10:28 PM   #20
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
Thanks guys, 2 seconds does sound like longer than what I'd normally wait before letting go of the clutch.
Hopefully this solves my freaking switch issues. I was expecting the switch to be dirty and covered in dirt, salt and corrosion when I opened it up. Seeing it nearly spotless threw me off.
Old 04-11-2019, 12:26 AM   #21
I'm surprised it doesn't happen more often. Aren't all the BRZs PB start? 0.o
Old 04-11-2019, 01:08 AM   #22
PandaSPUR
PandaSPUR's Avatar
Not all, only the limited trim. And I guess I just have bad luck. Plus I sucked at trying to replace the switch myself until I got the thin wrenches.
Old 04-11-2019, 01:17 AM   #23
Well, unless there's a secret diode in the relay it all falls into place. It's super tight up there. I hope you don't ever have to do the job again.
Old 07-19-2023, 07:07 PM   #24
dynarun55
Drives: 2015 midnight blue limited edition.
Bumping this thread. I have a 2015 limited as well, and this starting problem just started for me. Was it the clutch switch ? As in, did the new clutch switch solve all the problems you were having ? Or was it something else ?
dynarun55 is offline   Reply With Quote
Transmission or Clutch Taking a dying? Cal3000 Engine, Exhaust, Transmission 8 07-27-2016 06:58 PM
BRZ Limited Keyless FOB Battery Dying? rapidcars BRZ First-Gen (2012+) — General Topics 4 09-14-2015 08:10 PM
FS: Unichip, USB cable, 2 tune selector switch, Clutch switch BII302 Engine, Exhaust, Bolt-Ons 6 04-13-2015 08:06 PM
My battery keeps dying mynameis940 Issues | Warranty | Recalls / TSB 22 03-01-2015 12:52 AM
Clutch Switch Bypass OmarGC Engine, Exhaust, Transmission 20 01-01-2015 10:41 PM
