#15 |
Exactly. Try standing on the clutch until after the starter quits on its own.
#16 |
Drives: MR2, Sliver BRZ
I from my testing it seems like it lets go the starter very quickly though the ST cut relay. But delays around 2 seconds to let go the ST relay. So if you wait more than 2 sec should reduce the arching.
Always looking to tinker with something..
| The Following User Says Thank You to geraldjust For This Useful Post: | PandaSPUR (04-10-2019) |
#17 | |
Yeah, NVM the starter motor cut. Wait at least two Mississippis.
#18 |
LOL if worse come to worse add a reverse diode next to the relay coil in the circuit it will cut any spike in voltage. it will stop any voltage from arching though the contacts.
#19 | |
![]() Shame on Toyobaru for cheaping out there. That's some weak sauce.
#20 |
PandaPandaPandaPandaPanda
Drives: 2015 BRZ Limited CWP
Thanks guys, 2 seconds does sound like longer than what I'd normally wait before letting go of the clutch.
Hopefully this solves my freaking switch issues. I was expecting the switch to be dirty and covered in dirt, salt and corrosion when I opened it up. Seeing it nearly spotless threw me off. |
#21 | |
#22 |
#23 |
Well, unless there's a secret diode in the relay it all falls into place. It's super tight up there. I hope you don't ever have to do the job again.
#24 |
Drives: 2015 midnight blue limited edition.
Bumping this thread. I have a 2015 limited as well, and this starting problem just started for me. Was it the clutch switch ? As in, did the new clutch switch solve all the problems you were having ? Or was it something else ?
| Transmission or Clutch Taking a dying? | Cal3000 | Engine, Exhaust, Transmission | 8 | 07-27-2016 06:58 PM |
| BRZ Limited Keyless FOB Battery Dying? | rapidcars | BRZ First-Gen (2012+) — General Topics | 4 | 09-14-2015 08:10 PM |
| FS: Unichip, USB cable, 2 tune selector switch, Clutch switch | BII302 | Engine, Exhaust, Bolt-Ons | 6 | 04-13-2015 08:06 PM |
| My battery keeps dying | mynameis940 | Issues | Warranty | Recalls / TSB | 22 | 03-01-2015 12:52 AM |
| Clutch Switch Bypass | OmarGC | Engine, Exhaust, Transmission | 20 | 01-01-2015 10:41 PM |
