#99 |
Drives: Subaru BRZ
Raised the rear 1/4" and got an alignment today. Opted for 1/16" toe in both front and rear.
#100 |
Senior Misanthrope
#102 |
Drives: 2013 Scion FRS
How do you like the Ferrodo's? I see you use them quite often. I've got a set of ds2500's but I feel like they won't cut it for the upcoming track season.
#103 | |
Drives: Subaru BRZ
| The Following User Says Thank You to Code Monkey For This Useful Post: | Takumi788 (04-09-2019) |
#104 | |
Drives: 2023 BRZ
I think the 2500 is a good dual-purpose beginner pad, but that's about it. It is certainly a compromise, as it is a dual-purpose pad. But it is less compromise than others, IMO.
Director of Rocky Mountain 86CUP
#105 | |
#106 | |
Drives: Subaru BRZ
You could try it, may work just fine. I run the DS1-11 both front and rear, the fronts last me 4-5 weekends, I am on 4th set now. The rears I put in at 1,189 miles, I am at 16,xxx now, 19 hpde weekends and they are worn less than half way. Last edited by Code Monkey; 04-09-2019 at 12:38 PM. |
#107 |
Drives: 2023 BRZ
Clearly different compounds work with different cars. I wonder what you would think with them on an 86.
#108 |
Drives: Subaru BRZ
#109 | |
I noticed that on both the front and the rear you run slightly more camber on the left side than the right side, is there a reasoning behind not have a zeroed out cross-camber? |
#110 | |
Drives: Subaru BRZ
In the rear, I have UCAs and camber is adjustable in about half a degree increments so I am stuck at what it is. In the front, with my weight in the car the front left is actually -3.7 so I can live with -3.7 and -3.6. Last edited by Code Monkey; 04-09-2019 at 08:17 PM. |
#111 | |
I hadn't thought about how weight might affect it. I guess that's true that even if you were to get them exactly even on a rack, if your weight isn't in the vehicle they'll be off again. That's good to think about. I'm headed to Austin all day tomorrow to finally get my car corner weighted and a track alignment, so I'll make sure to ask that they do the alignment adjustments with driver weight in the car. |
#112 |
Drives: 2022 GR86
| Berzerk's 2017 CWP 'Slow and Steady' Build Thread | Berzerk | Member's Car Journals | 12 | 07-24-2017 04:57 PM |
| Rodie's slow '13 FR-S build | rodie | Member's Car Journals | 0 | 06-14-2015 08:05 PM |
| Slow Progression FRS Build | dgerny | Member's Car Journals | 1 | 04-15-2014 06:48 PM |
| Tkalz slow build! | Tkalz | Member's Car Journals | 15 | 10-13-2013 05:35 PM |
| Slow Build by Jooks | jooks | Member's Car Journals | 4 | 07-03-2013 10:53 PM |
