Old 03-23-2019, 09:41 PM   #1
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Off throttle resonance at ~2900rpm
If I go off throttle at 3000rpm and slow down, around 2900 rpm, i get a strong resonance/vibration from the engine. Happens in different gears and only off throttle. Definitely from the engine compartment. This is after the recall. It didn't do this before the recall. Ideas? The video I have doesn't really capture the sound well.
Old 03-23-2019, 10:42 PM   #2
Maybe the throttle body chattering ? -
Old 03-24-2019, 03:10 AM   #3
mswbrz
mswbrz's Avatar
Drives: 2013 brz limited / galaxy blue
Take it back before shit blows
mswbrz is offline   Reply With Quote
Old 03-24-2019, 11:23 AM   #4
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Then I don't know what we're supposed to guess at.
Could be a heat shield on the exhaust manifold, but since the engine was just apart for a procedure that we know is problematic, can we really play it off lightly like that?
Go back to the dealer that did it.
Old 03-24-2019, 11:48 PM   #5
EAGLE5
Dismember
EAGLE5's Avatar
I will go back. No heat shield as there is a header. The vibration is from in front, not underneath. I've heard exhaust rattles. This is an engine vibration.
Old 03-24-2019, 11:56 PM   #6
Engine mount installed upside down? Somebody here discovered that after noticing the engine was crooked.
Loose?
Old 03-25-2019, 12:40 AM   #7
soundman98
ProCrastinationConsultant
soundman98's Avatar
i suspect a faulty turboencabulator.
Grady (03-25-2019)
Old 03-25-2019, 01:03 AM   #8
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Don't lift. Problem solved. #QuitBeingAPu$$y
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
The Following 3 Users Say Thank You to Stang70Fastback For This Useful Post:
EAGLE5 (03-25-2019), maslin (03-25-2019), soundman98 (03-25-2019)
Old 03-25-2019, 08:03 AM   #9
BRZnut
Drives: BRZ DGM Limited
I would guess an issue with the motor mounts. Drive it with a tech at the dealer and see what they think.
Old 03-29-2019, 12:07 AM   #10
Learn how to drive it yet?
Old 04-01-2019, 03:57 PM   #11
toast
Drives: 14 BSP Edelbrock BRZ
I don't know how they pull the engine - do they leave the transmission attached?
What happens if you push the clutch pedal in during the resonance? If it is only when the engine is connected to the driveshaft they could have not lined up the driveshaft back to its original orientation on the diff.
toast is offline   Reply With Quote
Old 04-01-2019, 05:34 PM   #12
EAGLE5
Dismember
EAGLE5's Avatar
It's at the dealer right now. Foreman did a ride with me and heard the sound. He seemed to think it's an exhaust rattle, but they have techniques to figure it out.
Putting the clutch in would kill the sound because the revs would immediately drop. There's no way to stay at 2900 rpm with no clutch in and no gas.
Old 04-03-2019, 10:42 PM   #13
EAGLE5
Dismember
EAGLE5's Avatar
Well, I went in for the odd sound off throttle at 3000rpm. They did a bunch of listening and found a crack on my aftermarket header that I'd asked them to swap out during the original work but they hadn't done. Anyway, the car is great now, with no weird noises. Purrs like a kitten. Also no oil leaks anymore thanks to their work. So I'm happy. One Toyota of Oakland. The best service adviser ever is there, Chase. Super happy to work and stick with him.
Just a little more to add. I think they may have cracked it while removing the header to do the engine work. However, I can't blame them. This EL Borla has been through a lot, including several different owners.
Resonance at around 70 MPH? Subie Issues | Warranty | Recalls / TSB 136 05-04-2017 03:11 AM
Perrin exhaust resonance Leland Engine, Exhaust, Transmission 12 03-19-2017 09:47 PM
Something of a Whirring noise coming from resonance tube after trd intake install? Waffles Issues | Warranty | Recalls / TSB 4 03-15-2014 11:35 PM
Intake resonance pipe? tranzformer Engine, Exhaust, Transmission 20 12-05-2011 05:09 AM
