Old 03-15-2017, 03:36 PM   #1
Leland
Drives: BRZ JDL uel headers oft Perrin 2.5
Perrin exhaust resonance
I have a Perrin 2.5" resonated exhaust and it is overall very good. I do, however get a low frequency resonance between around 2700 and 3200 rpms that is more intrusive than any other rpms. Is this experienced by others with the Perrin? I have no other exhaust modifications. Thank you for your thoughts.
Leland is offline   Reply With Quote
Old 03-15-2017, 03:47 PM   #2
wparsons
wparsons's Avatar
I find mine is most boomy around 2000-2500rpm, 2.5" resonated cat back and their 2.5" catted front pipe.
flickr
Old 03-15-2017, 07:58 PM   #3
00NissanNinja
The Thread Lurker
00NissanNinja's Avatar
Drives: '14 BRZ, '17 GTI, MT09
+1
00NissanNinja is offline   Reply With Quote
Old 03-15-2017, 09:09 PM   #4
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
It's like that for most of the exhaust I think
Old 03-15-2017, 11:13 PM   #5
umpadupa
umpadupa's Avatar
Drives: 94 civic hatch, Whiteout frs
they are actually a really tame exhaust. if it bugs you, maybe try the HKS front pipe
umpadupa is offline   Reply With Quote
Old 03-15-2017, 11:26 PM   #6
Leland
...........one thing I forgot to mention, it seems to be intermittent. Meaning that most of the time it is insignificant. Other times less so. What would an HKS front pipe offer?
Old 03-16-2017, 02:42 AM   #7
tyler_win_photo
tyler_win_photo's Avatar
He's probably referring to the HKS front pipe with dual resonators. Although not guaranteed, it might help with that drone you're experiencing.
tyler_win_photo is offline   Reply With Quote
Old 03-16-2017, 10:54 PM   #8
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
I have a Perrin 3" resonated. I get the resonance around 2500 RPM and causes my rear deck to buzz.
The solution I've found is to gas the car harder and keep the RPMS in the 3000 RPM range and it goes away. It's more apparent with the AC on for me. You can also turn on the music louder or crack a window to increase some background noise.
N1rve
Old 03-18-2017, 04:02 PM   #9
dys586
Drives: 2013 Subaru BRZ Premium
Try checking if everything is tightened to spec. My friend and I both have Perrin 3", and his exhaust was a little louder/had resonance compared to mine until he retightened it.
dys586 is offline   Reply With Quote
Old 03-19-2017, 06:33 PM   #10
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
It could be how much throttle is applied. I know mine seems more boomy when I am barely on throttle but still accelerating a bit and it is around the RPM range. More gas solves it
Old 03-19-2017, 06:41 PM   #11
bfsnail
bfsnail's Avatar
I used to have the same problem. I fixed it by getting a turbo and a nameless 3" catted and resonated front/over pipe. Maybe try that and see if it goes away?
bfsnail is offline   Reply With Quote
Old 03-19-2017, 07:04 PM   #12
Silver Cervy
*Some really cool title*
Silver Cervy's Avatar
Running a 2.5 with a JDL header and I only hear drone when I'm in cruise control on the highway. Otherwise it is very tame and does what I want it to do.
Silver Cervy is offline   Reply With Quote
Old 03-19-2017, 08:47 PM   #13
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
What is your header and overpipe? What did you use for gaskets?
Old 03-20-2017, 09:06 AM   #14
Leland
I have tried adjusting and tightening things a couple of times. The vee bands had come slightly below original torque settings.
Because of the intermittent nature of the resonance this is most likely. And the interesting thing is since I started this post this there has been virtually no instance of the resonance. Perhaps it was struggling with the change of seasons and has settled again?
Resonance at around 70 MPH? Subie Issues | Warranty | Recalls / TSB 136 05-04-2017 02:11 AM
FS: Perrin 3in Catback Exhaust, Perrin 3in Front Pipe, Perrin Overpipe SOLD johnb831 Engine, Exhaust, Bolt-Ons 13 05-21-2015 05:27 PM
Something of a Whirring noise coming from resonance tube after trd intake install? Waffles Issues | Warranty | Recalls / TSB 4 03-15-2014 10:35 PM
Intake resonance pipe? tranzformer Engine, Exhaust, Transmission 20 12-05-2011 04:09 AM
