Old 03-21-2019, 12:49 PM   #15
Originally Posted by JIM THEO View Post
Those are the part numbers for the standard BRZ Showas, according to parts.subaru.com 20310CA240/250 and 20365CA220 are the part numbers for the Sachs, I am still searching those of the springs:
https://buyee.pixnet.net/blog/post/2...%AB-zc6-brz-st
@Tcoat you are right US tS is probably the correct term.
The part numbers in the links that Norcal provided will be the STi springs to go with the dampeners.
Old 03-21-2019, 04:30 PM   #16
norcalpb
norcalpb's Avatar
In the US, the Ts springs are black.
But I have a sneaking suspicion that they are pink overseas.
Also people should never order directly from parts.subaru.com. Always google the part number and you will find distributors up to 40% below msrp. Subarupartsdepot.com, subaruparts.com are examples.
Old 03-21-2019, 05:26 PM   #17
JIM THEO
Drives: BRZ 2018
I asked the same on tS thread and took answers they are pink as in the link I posted above, JDM ones are pink.
Anyway a friend sent me a chassis number and confirmed what part.subaru.com mentions, of course I am not going to buy them directly from them, they are recently available in Europe where I buy at wholesale prices.
Thanks all for your answers, the correct part numbers in case someone is interested:
Front shock left (Sachs) 20310CA250
Front shock right (Sachs) 20310CA240
Rear struts (Sachs) 20365CA220
Coil springs front 20330CA260
Coil springs rear 20380CA270
JIM THEO is offline   Reply With Quote
Old 03-21-2019, 06:06 PM   #18
norcalpb
norcalpb's Avatar
Thanks for compiling that. So do you think the springs you are going to order are going to be pink or black?
Old 03-21-2019, 07:08 PM   #19
J1Avs
Drives: 2018 BRZ tS
US BRZ tS springs are most certainly pink:
Also, while snapping the pic, I can confirm the front left shock is: 20310CA250
J1Avs is offline   Reply With Quote
Old 03-21-2019, 07:26 PM   #20
norcalpb
norcalpb's Avatar
Nice. That’s why I ask these questions because some of the STi stuff is hard to figure out.
Now for my next question, are these the same springs as B2010CA000 which is sold as a set of 4? These are the ones that lower the car “10mm”.
https://www.subarupartspros.com/sku-...SABEgLBjfD_BwE
I never noticed a ride height difference between the PP package BRZ and the Ts, but that could be because it’s literally only 10mm.
Old 03-21-2019, 07:58 PM   #21
J1Avs
Drives: 2018 BRZ tS
That I’m not sure of.
But the tS comes with 18x7.5in wheels wrapped in 215/40/18/ while the PP comes with 17x7.5 in 215/45/17. That might be enough to screen with the eyes a bit.
You would think they would be exclusive, but then they would have likely been something called out as exclusive to the tS like the flexible v-bars and draw stiffeners
Old 03-22-2019, 03:09 AM   #22
JIM THEO
Drives: BRZ 2018
That was also my question but US tS springs are harder 15% front 8% rear compared with basic model while B2010CA000 are only about 8% front (I don't know by how much rear), tS are two different part numbers for front and rear while the above pinks are one for the set.
Plus the tS have the classic color dots that Subaru - depending of hardness - marks it's springs with, while the US pinks haven't.
Only if/when I order them I can tell you for sure!
Old 03-22-2019, 05:55 AM   #23
JIM THEO
Drives: BRZ 2018
Just found a video that confirms tS has pink springs with dots that look different from the B2010CA000:
Old 03-22-2019, 09:27 AM   #24
It is exactly what you posted way back in post #7.
Thank YOU.
Old 03-29-2019, 04:13 AM   #25
JIM THEO
Drives: BRZ 2018
And just found the JDM >MY17 BRZ tS springs/shocks part numbers, does anybody know the differences on springs from the US ones?
20310CA240 (shock absorber front RH)
20310CA250 (shock absorber front LH)
20330CA260 x2 (coil spring front)
20365CA220 x2 (shock absorber rear)
20380CA260 x2 (coil spring rear)
Old 03-29-2019, 07:42 AM   #26
TachyonBomb
Drives: 06 Evo GSR SE, 17 Series Yellow BRZ
Hks g-series
https://www.kamispeed.com/products/h...-86-subaru-brz
Showa Tuning Evolution
https://frsport.com/showa-tuning-v04...8aAklSEALw_wcB
Bilstein B6, Bilstein B8, Bilstein JDM STI BRZ Stuts (the silver ones)
JDM STI BRZ Pink Spings
All the above seems like it would be easier more cut and dry as to what the final product your purchasing actually is.
Also if you need a Ts vin number just look them up on used car sites like autotrader, car guru or true car. Every dealership lists a used cars vin number. Contact a dealership for parts with whatever vin number you find.
Lastly I think the US frs/86 trd springs which are made by eibach which is in Southern California would technically fall under the designation of a “USDM” Part Or Spec lol. So I believe there is a novel asterisk to place in your “USImport” argument señor Tcoat.
TachyonBomb is offline   Reply With Quote
Old 05-16-2019, 12:01 PM   #27
TiminAZ
Drives: 2018 BRZ TS
So is my set of 4 tS shocks and springs worth selling? 400 miles on them.
2018 BRZ tS #282 of 500 DELICIOUS TUNING Edelbrock FI, E-85 Flexfuel, DeatschWerks pump and injectors, SpeedFactory ceramic UEL, Invidia R400 cat-back, ACT HD street clutch and flywheel, TEIN Flex Z coilovers, Stance wheels, Michelin Pilot Sport 4
TiminAZ is offline   Reply With Quote
Old 05-16-2019, 12:17 PM   #28
Vital
Drives: 2015 BRZ
Yes someone will want them
'13 BRZ USDM vs EU Spec leevanf BRZ First-Gen (2012+) — General Topics 27 07-07-2017 04:09 PM
FS-USDM Red TOMS Cards2323 Exterior Parts (Aero, Lighting, Etc.) 9 10-26-2015 02:54 PM
FT: JDM Clear Tom's to JDM or USDM Red Tom's Kit523 Canada Classifieds 3 09-23-2015 08:56 PM
WTT usdm tails *KID* ASIA 0 01-16-2013 10:48 AM
