Old 03-01-2019, 04:51 PM   #981
I think you have taken Ultra's comment out of context. He was responding to someone else saying why not use a short block for the recall.
It did start out that way but then I kept typing. Meant to respond yesterday but there were so many words. I'll try again tonight.
Old 03-01-2019, 06:04 PM   #982
AkaJabari
Drives: Scion FR-S, Scion tC
Going on almost 2 months now with my car still in the shop for this recall. Turns out the tech that did my short block replacement after a spun bearing didn't clean up properly and there was some metal circulating that scored all four cams. They owned up to it and are replacing everything under warranty along with a cracked timing cover though I did have to get corporate involved. Last heard on 28 Feb is that they are waiting on the timing cover and some seals (back ordered) before they can button it back up.
Needless to say its this whole process has been quite the ordeal. The 1st month they had me in a Camry and I'm currently driving one of the new Rav-4s. I think maybe next week I'll try out a 4Runner...
AkaJabari is offline   Reply With Quote
The Following User Says Thank You to AkaJabari For This Useful Post:
Magoo (03-02-2019)
Old 03-01-2019, 08:19 PM   #983
xjohnx
Grip>Slip
xjohnx's Avatar
anyone here have the recall work refused due to mods installed? my dealer won't do it unless i pay them $650 to remove and reinstall my mods, which is insane. It's got an sprintex SC and flex fuel kit. So they'd be disconnecting the same 6 bolts to remove the intake manifold and disconnecting the same two fuel lines to remove the motor whether the car was stock or modified.
I'm working with corporate and have opened an NHTSA investigation as their instructions state, but wondering if anyone else has had any experience like this that can help offer advice?
NYNOMAD (03-04-2019)
Old 03-01-2019, 10:06 PM   #984
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
There is a whole thread about this in the FI section. Yes people are having to remove mods like this.
Old 03-02-2019, 01:20 AM   #985
xjohnx
Grip>Slip
xjohnx's Avatar
Got a link? I'm only seeing the one from the guy whose motor blew after the recall.
Old 03-02-2019, 01:50 AM   #986
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
http://www.ft86club.com/forums/showthread.php?t=132418
Old 03-02-2019, 06:07 PM   #987
Teseo
Drives: frs
Go to another dealer
Old 03-02-2019, 07:08 PM   #988
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
shiumai is offline   Reply With Quote
Old 03-04-2019, 02:43 PM   #989
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
Originally Posted by DandoX View Post
I thought I would share my experience. I dropped my car off on Tuesday at Longo Toyota in Ca. I spoke with the tech doing the work (Jason) let him know Im extremely fond of this car. I got a free rental '19 Camry which was larger than I expected and extremely boring to drive around. I picked up my car Thursday, and the car appears to be running fine with no issues so far. I drove about an hour home in traffic, car ran fine. The tech also did a good job with the aftermarket engine strut bar and MCB which didn't add any additional cost or issues.
Overall I have had a pleasant experience, I will report back if anything goes wrong in the next couple weeks.
my car had 80k at the time of the recall.
I suggest to all getting the recall done to also get a physical paper stating you did the recall, that way in case the dealership fails to notify the DMV you don't have to jump through hoops for proof of the recall completion.
Follow up update, I put around 80 miles on her since the recall, everything appears to be running properly. No odd sounds or issues. I just changed the oil yesterday to get that 0W-20 out of there and replace it with 0W-40, and she feels just like she used to. I'll update again once I get roughly 500-600 more miles.
DandoX is offline   Reply With Quote
Old 03-04-2019, 02:50 PM   #990
DandoX
Senior gif poster
DandoX's Avatar
Originally Posted by ermax View Post
I went through my pictures from when I had mine out and I don't have many good pictures showing the packing. This is about the best I have:
Is this a picture of what the engine seal looks like from the outside from the factory or after the job was done?
I had my recall done and I have some of that sealer around the entire seem all the way down.
Old 03-04-2019, 03:12 PM   #991
microSDHC
microSDHC's Avatar
Drives: '13 FR-S 6AT (Argento)
My engine looked like that after the J02 recall work. It didn’t look like that from the factory. As long as it’s not blocking some passage inside, it should be good. But how will I ever know? Time will tell... it’s been over 1k mi for me and no problems yet. /me knocks on wood
microSDHC is offline   Reply With Quote
Old 03-04-2019, 03:15 PM   #992
xjohnx
Grip>Slip
xjohnx's Avatar
Everyone keeps saying (and taking at face value) that the car "has to be stock." Has actually anyone seen this policy in writing anywhere? If so, I'd LOVE to see the source. I don't think it has a leg to stand on legally. This ain't warranty work. It's NHTSA Mandated.
https://www.safercar.gov/staticfiles...ecalls-FAQ.pdf
I've got an investigation opened with the NHTSA as their literature instructs.
Not my monkeys, not my circus.
Old 03-04-2019, 03:39 PM   #993
ermax
ermax's Avatar
From the factory.
The Following User Says Thank You to ermax For This Useful Post:
DandoX (03-04-2019)
Old 03-04-2019, 03:58 PM   #994
maslin
Benz Tech
Drives: 2017 BRZ Premium
The Subaru document says exactly the opposite of "must be stock".
"• Contact the SOA Techline immediately to review any concerns believed to be impeding or preventing proper completion of this recall. There should be very few if any cases where this would be necessary. A severe example of an impediment would be if the wrong specification engine is found to be installed. Nearly all aftermarket modifications can be worked around or removed to allow valve spring replacement to proceed.
• Contact the SOA Claims Team should removal and / or reinstallation of these customer modifications require significant additional time."
maslin is offline   Reply With Quote
The Following User Says Thank You to maslin For This Useful Post:
Dadhawk (03-04-2019)
Broken Valve Spring sybrite Engine, Exhaust, Transmission 45 11-02-2018 05:20 AM
Valve spring swap rcmf5525 Engine, Exhaust, Transmission 6 05-19-2018 04:12 PM
Jrsc replacement diverter valve issue Brzxton Forced Induction 6 12-08-2017 10:39 AM
GSC FA20 Valve Spring Kits MAPerformance Engine, Exhaust, Transmission 41 07-20-2015 11:22 AM
Skunk2 Dual Valve Spring and Titanium Retainers limitedblkwrx Engine, Exhaust, Transmission 0 01-05-2015 12:12 AM
