Old 02-22-2019, 02:23 PM   #939
ka-t_240
Originally Posted by DarkPira7e View Post
Yeah good thought. Updated!
I'm going to leave the template blank and include my own entry separate
I deal with tracking work orders/failures/warranty all day. So this topic is my 8-5.
(not on Subarus)
ka-t_240 is offline   Reply With Quote
The Following User Says Thank You to ka-t_240 For This Useful Post:
Ultramaroon (02-26-2019)
Old 02-27-2019, 10:39 AM   #940
FRS13_
FRS13_'s Avatar
Drives: 2013 Scion FRS 6-speed
Just dropped off the FRS at Toyota for the recall, will update when it's done.
They gave me a TUNDRA! Haha it's kinda big.
Sent from my SM-G892A using Tapatalk
FRS13_ is offline   Reply With Quote
Old 02-27-2019, 01:42 PM   #941
Rican_D
Rican_D's Avatar
Drives: Asphalt FR-S
Dropped mine off yesterday. They gave me a Camry for a rental. Let's see how long they take..
Sent from my Pixel 2 XL using Tapatalk
Rican_D is offline   Reply With Quote
Old 02-27-2019, 09:32 PM   #942
Teseo
Drives: frs
Why they dont give us a short block instead? It will cost less on long term rather than screwing up perfectly running engine
Old 02-27-2019, 11:01 PM   #943
Would need to be a full engine. Problem is in the heads. They should be shipping crate engines to the dealers and rebuilding the cores.
I'm pretty sure that's how Honda dealt with their failed first attempt at a five-speed automatic.
humfrz (02-28-2019), Teseo (02-27-2019)
Old 02-27-2019, 11:10 PM   #944
Rican_D
Rican_D's Avatar
This actually would be a better more reliable solution. Quicker turn around time and tech wouldn't have to worry about screwing up the spring install.
Old 02-27-2019, 11:16 PM   #945
Penny-wise and pound-foolish. Epic fail.
Teseo (02-27-2019)
Old 02-27-2019, 11:25 PM   #946
Magoo
Magoo's Avatar
I still haven't heard back from the Dealership, nor Toyota Corporate since yesterday. In that time, I think I was able to sleep ~5hrs due to stress.
I just wish that I didn't have to drive this fucking Sienna rental every day. Such a mom-car.
Magoo is offline   Reply With Quote
Old 02-27-2019, 11:43 PM   #947
I'm really sorry. Even though I'm passing on it, I can't help but cringe at how it has been panning out exactly as I had feared. I wish I was wrong.
ermax (02-28-2019)
Old 02-27-2019, 11:44 PM   #948
Teseo
Drives: frs
Women will think you are a family man and that is porn to some
The Following User Says Thank You to Teseo For This Useful Post:
Magoo (02-28-2019)
Old 02-28-2019, 03:21 AM   #949
ORrooster
Drives: Your FR-S like he stole it.
No way - not cost effective. Manufacturer's don't stay in business doing 'shotgun' repairs and replacing massive, expensive components without cause. Even if they had predicted that they would have issues like they seem to be having now post-repair, it would have just been more in-depth training etc. Particularly with such a small failure rate pre-repair and the extremely low chance that an unavoidable accident and resulting litigation would follow. And, these motors should not be wiping out bottom ends or spinning any bearings after only valve spring replacement. I am very interested to see what Toyota and Subaru end up determining is the cause of these failures. From where they stand now, it should be on the dealer as far as I can see and I'm sure that is Corporate's take on it too. They're in the clear so deal with the dealer. Built heads would be a more reasonable option but again... engines should not be failing.
Automatic transmissions are totally different. A 'clean space' is required for rebuilding. Special tools, seal sizers & installers, etc.would have to be prepared and shipped to every dealer. Selectable shims and/or snap rings for clutch packs and final drives would all have to be kept in stock to be efficient. Training. The design of the training course. A facility to train in (exist) but any dealer not within short range would be sending techs to school (already do).
If you think people are having problems with getting this FA20 together correctly the first time... train an entire workforce on automatics that has never done anything but external repairs to them start rebuilding them in facilities not equipped to do so.
ORrooster is offline   Reply With Quote
Old 02-28-2019, 04:28 AM   #950
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I think you have taken Ultra's comment out of context. He was responding to someone else saying why not use a short block for the recall.
I have a spare motor that came out of an FRS. It was gone through by a tech at a Toyota dealership that pulled it from a wreaked car, plasti-gauged the rod bearings, did a comp and leak down, and then reassembled. The amount of sealant used on the timing cover and oil pan is excessive and I will be pulling it back apart. If that is representative of what is happening during the recall work then I could understand how there might be many assembly issues. I should post pictures of it.
The Following 3 Users Say Thank You to NoHaveMSG For This Useful Post:
ermax (02-28-2019), Teseo (02-28-2019), Ultramaroon (03-01-2019)
Old 02-28-2019, 07:22 AM   #951
ermax
ermax's Avatar
valve spring issue?
Please do post pictures. I’m kind of curious to see the kind of slop job they are doing on the packing.
Just sitting here thinking. There is one oil gallery near the edge of the timing cover that could get blocked. Its far enough away from the edge that you would need to get fairly carried away with the packing to reach this gallery but if you miss placed the cover and then slid it into place it very easily could cover that gallery. The recall instructions instruct you to use a new SST which are 4 long guide posts that are just threaded studs that go in all 4 corners that are used to prevent you from miss aligning the cover. The original repair manual doesn’t include this SST. Seems Subaru predicted this as a trouble point and developed a tool. Perhaps the dealers aren’t buying this tool or maybe aren’t using it.
That cover is large so it’s hard to watch both ends for alignment while placing it. When I did mine I had someone help me. I explained how critical it was to get it 100% aligned without shifting after contact before we started to place it. You really don’t want to place it and then shift it even 1mm into place. Shifting it means smearing the packing out of place.
The Following 2 Users Say Thank You to ermax For This Useful Post:
NoHaveMSG (02-28-2019), Teseo (02-28-2019)
Old 02-28-2019, 07:55 AM   #952
bfrank1972
Drives: 2013 FR-S Argento
Lol, minivans are awesome! Embrace it. Maybe you could pick up some side jobs carting kids around
Sent from my SM-G965U using Tapatalk
Broken Valve Spring sybrite Engine, Exhaust, Transmission 45 11-02-2018 05:20 AM
Valve spring swap rcmf5525 Engine, Exhaust, Transmission 6 05-19-2018 04:12 PM
Jrsc replacement diverter valve issue Brzxton Forced Induction 6 12-08-2017 10:39 AM
GSC FA20 Valve Spring Kits MAPerformance Engine, Exhaust, Transmission 41 07-20-2015 11:22 AM
Skunk2 Dual Valve Spring and Titanium Retainers limitedblkwrx Engine, Exhaust, Transmission 0 01-05-2015 12:12 AM
