Old 01-24-2015, 02:10 AM   #113
killboy
killboy's Avatar
Drives: 1FRS, 1 BRZ, 2S2000s, Evo8, Dak.R/T
Originally Posted by post_break View Post
Has anyone been able to get the seat belt chime to turn off? I don't know how to send that command.
I don't know if it's possible with Scangauge, but I turned mine off using the Carista app on Android (gotta pay the $20 in-app one time fee) connected to a $10 blue tooth OBD-II scan port. Lets you tinker with a lot of factory defaults, like DRL on/off, single button press to unlock all doors, arm/disarm beep volume, etc.
Sorry if that's not the answer you're looking for, just thought it might help.
killboy is offline   Reply With Quote
Old 02-26-2015, 09:51 AM   #114
nalc
Drives: 13 BRZ Limited 6MT GBS
Having some issues with mine and wondering if anyone else has dealt with something similar. I set it up with the codes for oil temperature and it was working fine for a few days but then stopped working. There is no number displayed for oil temp now. I did a reset and that didn't help, I blanked out the x gauge and made a new one with the correct codes and that didn't help, I disconnected the scangauge and drove around for awhile and reconnected it and that didn't help either.
One thing I noticed at the same time as it initially broke was that the default display for water temperature changed from "deg F WT" to just "LWT", but it has since changed back.
nalc is offline   Reply With Quote
Old 11-01-2015, 07:01 PM   #115
Lonewolf
Lonewolf's Avatar
Drives: Moped
Still looking for anyone with an aeroforce scan gauge installed to give impressions/pics...
Old 01-18-2016, 07:36 AM   #116
Deep Six
Deep Six's Avatar
Drives: 2013 FRS / 2013 427 Vert
Originally Posted by NickFRS View Post
Figured out oil temp + boost....
Rocking
Oil Temp ~~~ ~~~ Boost
Water Temp ~~ ~~ Intake Temp ( want AFR to replace intake temp )
Code for boost ??
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor
2016 Audi TTS APR Tuned
Deep Six is offline   Reply With Quote
Old 01-29-2016, 06:56 AM   #117
Deep Six
Deep Six's Avatar
Originally Posted by AZFA20 View Post
I figured out AFR on it.
Been testing it for several weeks now. The only issue is that the refresh rate on the ScanGuage is pretty slow for a PID of this nature but it works perfectly fine so long as you are not tuning with it. It is a good way to keep an eye on it if something were to go wrong.
Also keep in mind the AFR on these vehicles is pretty innacurate below 11.2:1 with the factory wideband so anything you see below that should be taken with a grain of salt. This is perfectly fine but just something you need to be aware of. The gauge will really not see anything below 10.8:1 and should not be used for tuning but rather general monitoring. I have datalogged the ScanGauge with EcuTek for comparison and other than the speed of display its good to go. I will post the codes later. I just don't happen to have them on me at the moment.
My current display setup for reference is Boost, AFR, IAT, and Oil Temp. The only PID I really wish I could figure out is the KR (knock retard). Other than that the ScanGauge is a great option that is super cheap compared to competition for general monitoring.
Could you post up the codes for boost please?
[SIGPIC][/SIGPIC]
Old 08-06-2016, 10:34 PM   #118
malubawla
poor man's evora
malubawla's Avatar
Drives: Turbod BRZ
poor mans' P3 Gauge
malubawla is offline   Reply With Quote
Old 04-07-2017, 03:51 PM   #119
VVT4ME
VVT4ME's Avatar
Drives: 2014 Scion FR-S
So all I need to get things like air fuel and oil temp is get a scangauge and use these codes? Does the scangauge come with everything I need?
VVT4ME is offline   Reply With Quote
Old 06-08-2017, 01:56 PM   #120
cat94
Drives: '17 86
Originally Posted by pkny View Post
Working code for FR-S/BRZ/86:
Code:
Gauge                          Unit           TXD                  RXF                      RXD      MTH                      Note
Oil temp                       C         07E02101       010702E80324     3008    00010001FFD8    Required FW 4.05 or higher
Oil temp                       F         07E02101       010702E80324     3008    00090005FFD8    Required FW 4.05 or higher
Precise Fuel Level         %         07C02129       046105290000     2808    000100010000    Faster refresh rate
Precise Fuel Level    US Gallons   07C02129       046145290000     2808    052900640000    Faster refresh rate
Precise Fuel Level       Liters      07C02129        046145290000     2808    01F4000A0000    Faster refresh rate
Seat Belt Beep Query               07C021A7        046115A70000     2808    000100010000   C0 for stock, 00 for disable
Seat Belt Beep Disable              07C03BA700    047B15A70000     2008    000100010000   Should return 0000. Replace '00' in the TXD with 'C0' to go back to stock.
Relative Throttle Position      %           07E00145            044185450000         2808     03E800FF0000
Absolute Throttle Position     %           07E00147            044185470000         2808     03E800FF0000
Fuel Pressure                     PSI         07E00123            046105230000         2810     006400450000
Fuel Pressure                    MPa         07E00123            046145230000         2810     000100010000
Attachment 28549 is the list of supported standard (mode 01) PID for 86/BRZ/FR-S. This list is created from the Wiki’PID, and I highlighted the ones that are supported by our cars.
Here is an example of how to make use of the doc I created:
From the Xgauge cansf list, the short Term Fuel Trim Bank 1 has the TXD 07E00106. The 01 (07E00106) is the mode #. The 06 (07E00106) is the PID. Now look at the doc I attached. It shows the PID 06 is supported, which means that xgauge code works on our cars. The PID 07, On the other hand, is not highlighted on the list. That means the Short Term Fuel Trim Bank 2 is not supported.
Thank you Andery for finding the PID and torque’s code for oil temperature. Without him, I don’t think I can get the oil temp for xgauge.
Is anyone aware if these codes are the same on MY17s?
cat94 is offline   Reply With Quote
Old 07-09-2017, 11:09 PM   #121
Nosreves
Drives: 2017 Toyota 86 Raven
My oil temp isn't working. Just showing a - 39 for both C and F. 2017 86, the seat belt beep disable is working though
Nosreves is offline   Reply With Quote
Old 12-15-2018, 05:54 PM   #122
86TOYO2k17
Drives: 2017 toyota 86
I’m having he same issue on a 2017 86.
I got AFR and auto trans temp working fine. Boost and coolant temp work fine. Just need that oil temp to work.
Any find a working code for 2017+ ?
Old 12-16-2018, 08:07 AM   #123
22R
22R
22R's Avatar
Drives: 2012 Camry SE 2017 Toyota 86
I could never get the oil temp to work on my 2017 86 either ???
22R
22R is offline   Reply With Quote
Old 02-25-2019, 04:21 PM   #124
86TOYO2k17
Scangauge sent me a datalogger to get some codes for the 2017 86 auto, although i am sure most should work for MT and possibly the BRZ.
Description TXD RXF RXD MTH NAME Notes
Air to Fuel Ratio (#) 07E02104 056146040000 4010 006408B80000 A/F
Ambient Temp (°F) 07E02101 032100000000 3008 00090005FFD8 AMB
Battery Current (Amps) 07E02144 032580000000 4010 0140007DB1E0 AMP
Battery State of Charge (%) 07E02145 03218000000 3810 000100010000 SOC
Catalyst Temp Bank 1 Sensor 1 (°F) 07E02105 046105050000 3810 00090032FFD8 C11
Engine Oil Temperature (°F) 07E02101 032500000000 4808 00090005FFD8 EOT
Battery Temperature Estimate (°F) 07E02145 056106450000 4010 0009000AFFD8 BAT
Fuel Pressure (High) (PSI) 07E02101 032400000000 4010 001D00140000 FPH
Fuel Pressure (Low) (PSI) 07E02101 032500000000 2810 001D00140000 FPL
Fuel Pump Duty (%) 07E0213A 032100000000 3010 000A06670000 FPD
Injector Timing (microseconds) 07E0213C 032100000000 1810 000100010000 INJ
Current Gear (#) 07E02122 056106220000 3808 000100010001 GER
Transmission Fluid Temperature (°F) 07E12182 046105820000 2808 00090005FFD8 TFT
Engine Torque (ft-lbs) 07B02105 032100000000 2011 001703E80000 TRQ 4.51+
Old 03-28-2019, 09:50 PM   #125
maslin
Benz Tech
Drives: 2017 BRZ Premium
Lifesaver. Works beautifully on my 17 BRZ. Thanks!
maslin is offline   Reply With Quote
Old 12-26-2022, 11:11 AM   #126
nissanfanatic
nissanfanatic's Avatar
Drives: 2023 BRZ
I am sorry for bumping such an old post, but I figure if anyone does know this would be the most convenient place for others to find in the future.
Anyone happen to get oil temp working on 2022+? I've tried both of these for Fahrenheit with no joy...
Code:
# Edit to add also tried this one from here: https://www.gt86ownersclub.co.uk/threads/ultragauge-finding-oil-temperature-as-custom-gauge.19764/
Thanks!
Edit:
I ended up finding this thread: https://www.ft86club.com/forums/showthread.php?t=147905 . Seems like it may just be limited data available through OBD2 without making requests via SSM. Thanks to @timurrrr and @DocWalt for the work and documentation.
nissanfanatic is offline   Reply With Quote
FT-86 low temp THERMOSTAT ft86-UAE Engine, Exhaust, Transmission 52 08-30-2016 03:46 PM
A/C Oil/Water temp gauge Exhaust Scion FR-S / Toyota 86 GT86 General Forum 16 02-07-2013 01:19 PM
Engine oil temp now available in Torque App Yruyur Engine, Exhaust, Transmission 8 02-03-2013 10:52 PM
exterior temp. gauge off? Rayme CANADA 8 01-23-2013 09:06 PM
Simple Oil Temp. Gauge Sportsguy83 Cosmetic Modification (Interior/Exterior/Lighting) 4 01-19-2013 08:25 PM
