| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Drives: '14
Empty reservoir. Confused as to what coolant I should use
2014 FRS. I noticed that my coolant reservoir is completely dry and have noticed it being like that for a while. I understand that it is an overflow tank and being low level is good, but It is completely DRY. My temps are normal though, but having that low of a coolant level is concerning.
What fluid should I go with? I’ve done my fair share of research but I’ve been hearing different fluids. I live in Chicago so it can get very cold in winters, so I don’t think using distilled water would be good. I am not sure what kind of coolant the previous owner used, but I’m pretty sure it’s the OEM fluid and have never been changed. Can someone supply me with the part number for the fluid I should use so I can just purchase if, top off and be done with this? Also, I’ve noticed that some coolant fluids are a 50/50 mix, while others are a concentrate. Which one should I use?!? This is really frustrating me more than it should.. Thanks ![]() Sent from my iPhone using Tapatalk |
#2 | |
Drives: 2015 BRZ
https://www.amazon.com/Genuine-Subar.../dp/B007NLOZAU |
| The Following User Says Thank You to Vital For This Useful Post: | kev0 (02-22-2019) |
#3 | |
Drives: '14
Sorry for the newbie questions.. |
#4 |
Drives: 2015 BRZ
Yes, doing it while engine is cold is fine. First open the radiator cap and check to see if you can actually see the coolant. Once you open it you should clearly see it at the top if its low fill it to the top. Then you can add some to the overflow i would just fill it a little above the Low marker. Coolant expands when its heated so you don't need too much in the overflow reservoir
#5 |
Drives: 2015 BRZ
@kev0 out of curiosity whats the mileage on your car? I know the manual says to flush the coolant at 100K miles...
#6 | |
Drives: '14
| The Following User Says Thank You to kev0 For This Useful Post: | Vital (02-22-2019) |
#7 |
Drives: '13 BRZ
You want Subaru "super coolant." Any dealership will carry it. It's blue.
| The Following User Says Thank You to tobin For This Useful Post: | Vital (02-22-2019) |
#8 |
Drives: 2015 BRZ
ah ok i think you should be fine with topping it off for now. Also, i forgot to mention if you do end up filling coolant in the radiator leave the cap off and turn on your car and let it get to temperature this will let out all the air it will start to bubble. Once the bubbling goes away you should be set. You can use this video as a guide.
[ame]https://www.youtube.com/watch?v=IxxNg9Z1ldw[/ame] |
#9 | |
Drives: '14
#10 |
Drives: 2015 BRZ
| OMG coolant reservoir bone dry! | qqzj | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 19 | 10-29-2017 10:35 AM |
| *SOLD* Cusco Coolant Breather Tank Water Reservoir Air Remover Bubble | hirollaz | Engine, Exhaust, Bolt-Ons | 10 | 04-25-2016 12:33 AM |
| Coolant loss - Void Warranty/ Edit: coolant flush question | BRZach | Engine, Exhaust, Transmission | 15 | 01-02-2016 09:21 PM |
| Brake fluid reservoir empty | cab33 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 11 | 07-16-2015 10:04 PM |
| Black Flakes in Coolant Reservoir?? | John Rambo | Issues | Warranty | Recalls / TSB | 7 | 07-15-2015 06:58 PM |
