| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Drives: Black 2015 FRS
Studs for a 5mm spacer & original stud length
Hey so my wheels are 18x8.5 +48 in the front so I have 5mm spacers so they don't rub. The thing is the stock studs are barely hanging on so I wanted to get some extended ones for the front so I didn't have to worry about that becoming a problem. I've looked around at other threads and couldn't find anything so I figured I'd make one. I wanna know how long the stock studs are and which extended studs I should get, since the ones I've found are all gonna be way too long. I'd assume that I only need studs 5mm longer than the stock ones since that's how big the spacers are. My spacers didn't come with any studs so that doesn't help.
Thanks |
#2 |
Drives: LS Swapped Scion FRS = 440HP
You need ARP part number: 100-7729
ARP 100-7727 (no nose) and 100-7728 (rounded nose) are the same thread length as stock. Also 100-7716 works (for WRX), but its even longer than 100-7729 |
| The Following User Says Thank You to spitsnaugle For This Useful Post: | DarkPira7e (03-24-2019) |
#3 |
I see that they're about 20mm longer than the stock ones, my spacers are only 5mm, is this gonna be a problem?
#4 |
Drives: 2014 GT86
Not if with open ended or long enough lugnuts.
#5 |
Drives: Crapcan
https://www.frsport.com/nismo-40222-...ds-240sx-s14-f
I run these. With my stock wheels and a 5mm spacer I can use the stock lug nuts. With my track wheels, no spacer, and closed ended lugs they still fit no problem. |
| The Following User Says Thank You to NoHaveMSG For This Useful Post: | MrSkubi (03-21-2022) |
#6 |
Senior Misanthrope
Just get some muteki sr48s with the ARP 100-7729 and you're good. Personally I use 100-7716, which are the longer ones, but it doesn't matter either way.
#7 |
Country Boy 4 Life
Gorilla close ended lug nuts will work too.
I LIKE TIRES! |
#8 |
Drives: 2018 BRZ Limited Perf Pack
Bumping this rather than make a new thread.
Gah! Studs make no sense to me. That being had... forgive me, I've been buried in VWs for 20+ years. Is it relatively simple to pop them out and replace them? I'm having trouble finding a low offset wheel that I like so it looks like I may need spacers, which apparently will require longer studs for anything greater than 3mm? Are studs available that have enough thread to run stock wheels and also not stock (thicker PCD section) wheels?
www.atomicalex.com
2018 BRZ Limited Perf Pack 6MT, a couple of motorcycles, and a stick shift station wagon |
#9 |
Drives: 2017 BRZ PP , 2005 Saab 97X
yes, take off the rotor, smack the face of the studs with a hammer and they'll pop out th eback. to press them in youll need to position the new stud in the hole, and add a few nuts for spacing and a sacraficial lug nut and then tighten down. the knurls in the new stud should be seated perfectly in the hub
the rears are a bit more lengthy as youllk have to deal with the drum parking brake. and it requires more tear down but its the same processs |
| The Following User Says Thank You to Clutch Dog For This Useful Post: | atomicalex (03-24-2019) |
| broke a stud today and have a few questions about lugs and studs | Breadman | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 11-29-2018 01:34 PM |
| Stud trimming with spacer question | MyNameIsCacauate | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 35 | 10-23-2017 10:55 AM |
| spacer, stud clearance on rota GRA | balci | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 03-24-2017 05:54 PM |
| Sheared/Siezed ARP stud (after having 3 stock studs strip) | Kostamojen | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 75 | 01-30-2016 10:44 PM |
| ARP studs with one stock stud | finch1750 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 09-17-2014 07:11 PM |
