| CANADA Canada |
#29 |
Drives: 2013 WRB BRZ 6MT
It's still a bit early for me at 65000kms and just under 6 years but I've got valve spring recall service coming up next month so I'm getting my plugs done at the same time, only being charged parts. Glad that I won't have to worry about it for another 7-8 years at least with 0 trouble and added expense to myself.
#30 | |
Drives: 2015 Scion FRS - Raven
#31 |
Benched 86lb
Drives: Ultramarine FR-S
Plugs from Toyota: $136
Local shop to do the work: $449 Getting this done in the winter on the same day we get high winds and 1.5ft of snow: priceless. Prices in CAD, after tax. |
#32 |
Drives: Black on Black on Black
Valve spring recall
28$ a plug no labor yassssss |
#33 |
Drives: frs 2015
oil in the spark plug recess after 98000km! I just did mine myself; watching videos and reading what everyone else has done was great. I used an old rubber gas line to screw the plugs in (like I saw in a video) and had a towel stuffed in there to stop tools from falling down. A bolt did actually end up falling down but I used a boroscope camera to find and pick it up with a magnet. I also wanted to check out the inside of the cylinders and noticed there is oil in the spark plug recess. What’s the deal with that? It’s not an easy job. I wouldn’t recommend anyone try it without a bunch mechanical skills, correct tools, patience, and you have at least a six pack of you favorite beer!. Would the oil leak be a warranty thing?
#34 | |
Oil is probably from a leaking valve cover gasket, you could try for warranty repair on it but they'll probably fight hard. IIRC you have to pull the engine to replace the "gasket" (sealant I believe).
#35 |
Drives: 2014 FR-S
#36 |
Drives: Fr-s
Loosening the motor mounts and jacking the engine per each side will help you get to the hard reach areas, makes taking the spark plugs out very easily.
#37 | |
$112 without labour, $99 with. Guaranteed they priced the wrong car for the service with labour. They'll correct it when you show up, and expect it to be at least $500 with parts.
#38 |
Drives: 2014 FR-S
I'm going to ask to sign the paperwork before they start the work, but yeah I'm sure she quoted the wrong car, but I even specified "Even for an FR-S?" and she was quick to say yes.
#39 | |
I'm sure they'll catch it before getting you to sign it. IIRC it's like 5 hours of time, and they won't have booked things properly for the day without accounting for that.
#40 |
Drives: 2014 FR-S
Will still test my luck. Worst case I cancel and change it on my own as I was planning to anyway.
#41 |
Drives: Black frs
Made a deal with one of the dealership mechanic to do it at his house on the side. $140 for labor and I provided the spark plugs. paid $87 for the spark plugs on eBay.
#42 | |
Did you ask him about getting his cost on parts too? Might've been a bit cheaper, I forget what the markup is like on the plugs.
| Spark Plug Removal Tools | JimmyMac | Engine, Exhaust, Transmission | 28 | 07-15-2016 12:25 AM |
| Spark Plug Time !!!! | RFB | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 11-24-2014 08:46 PM |
| Spark plug replacement and P0301 errors | Jacques Blom | AFRICA | 1 | 12-23-2013 05:04 PM |
| Spark plug question | Wilsonk227 | BRZ First-Gen (2012+) — General Topics | 19 | 07-03-2013 01:57 AM |
| Spark plug type and heat | ft86-UAE | Engine, Exhaust, Transmission | 4 | 06-10-2012 11:21 AM |
