Old 01-13-2019, 08:13 PM   #1
Mdulin
Drives: Scion Frs
Gas pedal shakes a little when i turn the steering wheel right?
Anyone know the cause for this? Just started happening, not affecting how it drives but it j makes the pedal vibrate for some reason.
Mdulin is offline   Reply With Quote
Old 01-13-2019, 08:22 PM   #2
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
What about if you just put your foot on the floor while turning? Try it in different places too. The car is DBW so it is not connected to anything else but some wires.
NoHaveMSG is online now   Reply With Quote
humfrz (01-28-2019)
Old 01-13-2019, 10:36 PM   #3
Brz_racer
Drives: Subaru BRZ
This is some kind of tire or wheel issue that is manifesting itself through the gas pedal. Did you put your foot over the brake to see if it shakes as well when turning?
Brz_racer is offline   Reply With Quote
Old 01-13-2019, 10:48 PM   #4
Mdulin
Drives: Scion Frs
Ive only really noticed it when backing up at an angle slow over my driveway from what i can remember. Maybe on some slow turns too.
Old 01-13-2019, 10:55 PM   #5
Brz_racer
Drives: Subaru BRZ
Check your tire weights maybe one or more has come off
Old 01-28-2019, 07:55 PM   #6
Puttputt7
Drives: 2016 Scion fr-s
my car squeeks when I turn the wheel, not sure if that may be correlated
Puttputt7 is offline   Reply With Quote
Old 01-28-2019, 08:07 PM   #7
If your car has a manual transmission, it could be a bit of clutch chatter being transmitted through the support for the gas pedal -
Maybe the engine is lugging down a bit and shaking the floorboard that is holding the gas pedal - ??
Old 01-29-2019, 07:11 AM   #8
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
There is a rubber seal where the rotating string shaft crosses the firewall, I've seen those start to squeek as the steering turns on various makes and models, and you could be feeling that vibration in the gas pedal, which should be mounted near it.
But some white lithium great spray and try to use the straw to get some in between the rubber seal and steering shaft.
The Following User Says Thank You to RZNT4R For This Useful Post:
humfrz (01-29-2019)
Old 01-29-2019, 12:54 PM   #9
qcbaker
Shitpost Generator v8.6
qcbaker's Avatar
I can hear squeaking when I turn my steering wheel at parking lot speeds, and I can feel the vibration in the gas pedal when it squeaks. Perhaps this is what the OP is experiencing as well?
Originally, I thought it might be low power steering fluid or something, but it isn't a continuous squeak when the wheel is held left or right, so now I think its just something squeaking in the steering column.
Would it be possible to post a pic of where you're saying to spray the grease? I'm thinking of trying this to resolve my squeak but I don't want to spray grease where it doesn't belong.
qcbaker is offline   Reply With Quote
Old 01-29-2019, 02:21 PM   #10
So, did you get that power steering fluid thing out of your head?
Old 01-29-2019, 02:58 PM   #11
qcbaker
qcbaker's Avatar
To be completely honest, I didn't know until just now that the power steering is electric and not hydraulic.
So yes, but not for the reason you think lol.
The Following User Says Thank You to qcbaker For This Useful Post:
humfrz (01-29-2019)
Old 01-29-2019, 09:44 PM   #12
RZNT4R
http://www.ft86club.com/forums/showp...97&postcount=1
Pictured is the gas pedal. To the left you see the steering shaft, the back rubber boot at it's base is stationary and the shaft is greased to slip in it as it turns. You can see this one has green grease showing. get some in there in between the shaft and boot.
If you want, you can peek under the dash while turning the wheel to see if that's the thing making your nose first.
qcbaker (01-30-2019)
rattle, shaking, steering wheel, throttle, vibrate
Aftermarket Steering Wheel + Turn Signal Stalk Relocation pleong Cosmetic Modification (Interior/Exterior/Lighting) 2 01-21-2016 09:30 AM
Steering wheel issue---left turn lighter than right turn!!! xingxingtjf Issues | Warranty | Recalls / TSB 12 10-14-2015 07:47 PM
FS: Works bell steering wheel hub, buddy club seat rail, momo steering wheel in Socal mtsui Interior Parts (Incl. Lighting) 5 08-11-2015 01:15 AM
Pedal and Steering wheel Lock Up The86Ghost Issues | Warranty | Recalls / TSB 11 05-16-2014 10:28 PM
"From the first turn of the steering wheel, this car needs to be fun and special" Matador Scion FR-S / Toyota 86 GT86 General Forum 15 12-26-2009 08:54 PM
