Old 12-31-2018, 05:44 PM   #575
tomm.brz
Drives: brz 2017 hksv2
Originally Posted by NCtoBRZ View Post
You missed it... they are clearly listed...
Listed are port injectors seals
ermax (12-31-2018)
Old 12-31-2018, 09:50 PM   #576
slizoth
slizoth's Avatar
Drives: 2013 WRB Subaru BRZ
Originally Posted by incriminati View Post
I'm in the date range, but my vin is 60XXXX. Am I understanding this right that it's not affected?
The car was manufactured in 9/2012.
Let me know if you do get notified, I haven't and I'm also in the 60XXXX range.
slizoth is offline   Reply With Quote
Old 12-31-2018, 09:55 PM   #577
slizoth
slizoth's Avatar
Originally Posted by Bonburner View Post
I'm in the school of thought that the Only reason Toyobaru would ever spend the astronomical amount of money on a recall, is if it was a serious problem.
I think I've seen one person say he was driving and his engine spontaneously shut down. Luckily for him he was safe but steering was seriously difficult bc shut down the electronic steering?
Negative, while the car is rolling it's not very hard to move the steering wheel w/o power steering. Parallel parking though, that'll give you a nice workout.
Old 12-31-2018, 10:11 PM   #578
Muaddib
Mentat
Muaddib's Avatar
Drives: 2013 Scion FRS 6MT
Originally Posted by ka-t_240 View Post
Not sure if I missed it, but are direct injector seals on that list? If not, I will have to ask them to change those when they have the car apart.
I am guessing only two forward ones are replaced.
Muaddib is offline   Reply With Quote
Old 12-31-2018, 10:13 PM   #579
Muaddib
Mentat
Muaddib's Avatar
If you look carefully. It is the high pressure injectors. They will remove the high pressure pump as well.
Old 01-01-2019, 01:28 AM   #580
ermax
ermax's Avatar
valve spring issue?
The Teflon DI seals are not replaced according to the parts lists in this thread so far. The seals that go bad are SU003-00322. There is no need to touch the DI if you aren’t pulling the head.
Old 01-01-2019, 05:53 AM   #581
tomm.brz
There is the high pressure pump. But those are port injectors
Old 01-01-2019, 01:20 PM   #582
ka-t_240
13,14,15 in the pictures are the only fuel injector seals I see, they are all port injector related.
ka-t_240 is offline   Reply With Quote
Old 01-01-2019, 01:30 PM   #583
ka-t_240
SU003-00322 is on the DI system correct? Was trying to look, but its not coming up good on my phone. Have to look better on a computer at the parts breakouts.
Just figure, seems to be lots of people with what I was thinking was DI seals going out, so want to make sure to replace those while the car is apart.
Old 01-02-2019, 12:34 AM   #584
ermax
ermax's Avatar
Yes, those are the DI seals everyone talks about. The recall will not require those to be removed so if you want them to replace them they are going to charge you. The seals are only $3 but they are easy to damage. I had no problems replacing mine but I used the tool referenced in the ND Miata manual rather than the FRS manual. It’s much easier to use than the Toyota tool. I only bought 4 seals and all 4 went on without drama and only took about 15mins. The techs at Toyota told me they went through 12 before they got the hang of it.
Old 01-02-2019, 03:31 PM   #585
ka-t_240
You did them in 15 minutes with car all together?
I do have access to the Subaru tool. Probably some other stuff that would work as well.
Old 01-02-2019, 03:52 PM   #586
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Cross post, but did it just to track the issue... I haven't received a letter yet from Toyota, but my local dealership just called me directly to schedule the work. Unfortunately I missed the call and am waiting for a callback now...curious what info will come out of this..
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
Old 01-02-2019, 04:18 PM   #587
ermax
ermax's Avatar
No just the seal install. The injectors were already out and cleaned up. 15mins was the time it took to remove the old seals and install new ones. If you read around here you will find people saying they destroyed a bunch of them and took hours to do (just the seals). I think the key to it being so easy for me was the Miata tool is way better than the Toyota/Subaru tool. It comes with a tool for placing the seal on the install tool which is where most people have a problem.
Old 01-02-2019, 06:01 PM   #588
Oh, my, a tool for the tool - what will be required next -
Broken Valve Spring sybrite Engine, Exhaust, Transmission 45 11-02-2018 05:20 AM
Valve spring swap rcmf5525 Engine, Exhaust, Transmission 6 05-19-2018 04:12 PM
Jrsc replacement diverter valve issue Brzxton Forced Induction 6 12-08-2017 10:39 AM
GSC FA20 Valve Spring Kits MAPerformance Engine, Exhaust, Transmission 41 07-20-2015 11:22 AM
Skunk2 Dual Valve Spring and Titanium Retainers limitedblkwrx Engine, Exhaust, Transmission 0 01-05-2015 12:12 AM
