Old 12-22-2018, 07:48 PM   #29
Cal3000
Drives: Panda FR-S
My battery just died and I have this issue. I had the car for 6 years so far and the mechanical key doesn't work. I turned so hard that the key started to twist. It's jammed. I had to enter from the trunk to get in the car.
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
242whp/197ft-lb on Mustang Dyno (91 octane water)
284whp/223ft-lb on Mustang Dyno (E85)
Cal3000 is offline   Reply With Quote
Old 12-23-2018, 12:30 PM   #30
gravitylover
The old style key hole in the door turns the opposite direction than you'd expect to unlock. I found this out the hard way when my doors were frozen shut last winter and almost bent the key before I thought to turn it the other way.
The Following User Says Thank You to gravitylover For This Useful Post:
Brink (12-23-2018)
Old 12-23-2018, 01:12 PM   #31
JD001
JD001's Avatar
Drives: Subaru BRZ
Originally Posted by ashtray View Post
I leave my car untouched for weeks and never have trouble starting it. BRZ Limited. 7,000 miles in nearly 3 years, so you can tell how many times it sits for weeks without being started. Original battery. No issues.
Aftermarket stereo or camera or lighting etc can have a phantom draw.
It's only time before you get touched with the dreaded dead battery.. I was in the same boat as you.. my car's battery died about 2years in, changed under warranty. The new battery so far doing okay but it too has died as I don't use my car much..
Old 12-23-2018, 02:50 PM   #32
That is because there is no mechanical activator. Even the "key" just throws a switch and activates a solenoid.
Cal3000 (12-23-2018), Ultramaroon (12-23-2018)
Old 12-23-2018, 09:12 PM   #33
Cal3000
Drives: Panda FR-S
Wow, interesting. I did not know that. Might as well not have a key slot at all. What's the point if it's not fully mechanical? lol
Old 12-23-2018, 09:19 PM   #34
I forgot about that very important detail. Wow.
Old 12-24-2018, 08:57 AM   #35
gravitylover
That's kinda f'd up, turning a key should move mechanical bits not activate a solenoid. I had to go in through the trunk once when I couldn't open the doors enough to get in because a couple of brodozer guys thought it would be funny to park 2" away. It SUCKED I made myself feel better though when I pulled 2 of the valve cores out of the stems on their 38" mudders after realizing they had no spare tires.
Old 12-24-2018, 12:06 PM   #36
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
I think Toyota is generally backwards compare to other brands. My gf's RX300 is the same.
BTW when I first got the car I tried the BRZ mechanical key on the door and trunk and it took some finesse but I eventually got it to work. The key will no longer bend after the initial try.
It feels mechanical to me. Are you guys sure it's just a solenoid? The inside door lock pulls 2 cables as I've taken the door cards off before to see that.
krayzie is offline   Reply With Quote
The Following 2 Users Say Thank You to krayzie For This Useful Post:
gravitylover (01-03-2019), Ultramaroon (12-24-2018)
Old 12-24-2018, 02:28 PM   #37
Yeah, I just checked. It's mechanical.
Guess I didn't forget anything.
krayzie (12-24-2018)
Old 12-24-2018, 06:01 PM   #38
UMMMMM the reason I thought it was electronic was because YOU said it was a while back.
Old 12-24-2018, 06:27 PM   #39
That was the Camry. It is.
Old 12-24-2018, 06:42 PM   #40
Well you shouldn't talk about other cars here. It confuses us!
Old 12-24-2018, 07:58 PM   #41
It was in Reno, dufus.
Old 12-24-2018, 08:30 PM   #42
Well you shouldn't talk to me in person it just confuses us.
Dead battery technoid BRZ First-Gen (2012+) — General Topics 17 03-17-2016 05:17 PM
Dead battery Mikeez Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 33 08-07-2015 10:58 AM
Dead battery!?! Hoahao Issues | Warranty | Recalls / TSB 5 02-23-2015 05:06 PM
BRZ LTD battery drain issue, can't stop open door beep DoomsdayJesus Issues | Warranty | Recalls / TSB 9 02-06-2015 07:05 PM
Is there any know that how to open the truck when the battery is dead?????? wilson0326 Scion FR-S / Toyota 86 GT86 General Forum 31 07-06-2013 10:24 PM
