Old 12-21-2018, 03:23 PM   #547
ermax
ermax's Avatar
Originally Posted by n0thing View Post
@ermax as in regular shop manual for camshaft removal? it still shows removal of cam sub-assembly first, then caps
The cam is bolted to the subassembly not the head. If you unbolted the subassembly then you wouldn't need to unbolt the cam caps. I agree with Tcoat, we need the actual instructions because it seems no one actually understands how this engine fits together.
Old 12-21-2018, 03:41 PM   #548
Syche
Syche's Avatar
Drives: 2013 Black FR-S 6A
I guess I dodge a bullet on this one guys LOL
Originally Posted by 22R View Post
Now get off your Mom's computer and go wash the BRZ she bought you.
22R
Syche is offline   Reply With Quote
Old 12-21-2018, 04:19 PM   #549
n0thing
Drives: Subaru BRZ
Yes, if you unbolt the cam subassembly from the head, the cams come up together as well. But you'll need to clean and reseal the cam subassembly to the head during installation. Perhaps that's a step they wanted to avoid?
n0thing is offline   Reply With Quote
Old 12-22-2018, 09:06 AM   #550
ermax
ermax's Avatar
I know what the original service manual says. I am trying to understand what the recall instructions are asking for.
Do the “new” instructions ask for A or B:
A: remove the cam caps and leave the subassembly bolted to the head.
B: unbolt the subassembly from the head
As I said before, option A would save hours of time because it avoids most of the packing seal but risks head warping. Option B is what the original manual tells you to do.
Old 12-22-2018, 10:46 AM   #551
n0thing
Drives: Subaru BRZ
recall instructions ask for A
The Following 2 Users Say Thank You to n0thing For This Useful Post:
ermax (12-22-2018), RallySport (12-31-2018)
Old 12-25-2018, 12:08 PM   #552
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Some insider information. In Japan the work will not be done at the dealers place as in normal recalls, but in 8 service factory centers nationwide (2 places in Gunma prefecture, Tokyo, Iwate, Tochigi, Aichi, Shiga, Ehime ). The recalled vehicles will be transported from the dealer to the service factories for the work. Therefore it'll cost about one week per vehicle.
Old 12-25-2018, 01:43 PM   #553
Muaddib
Mentat
Muaddib's Avatar
Drives: 2013 Scion FRS 6MT
I don't think we will get that kind of service in North America.
Muaddib is offline   Reply With Quote
Old 12-25-2018, 02:32 PM   #554
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
You'd want them to transport your vehicle on a carrier to a facility and then back to you after doing the recall work? I say no thanks, I'll keep it close to me where I can be assured dopes other than the ones close to me aren't handling it. Much easier to go after someone for unsavory practice in person than remotely if it came to that
Old 12-25-2018, 04:18 PM   #555
RZNT4R
Professional Mechanic
Drives: 2017 86 6MT Oceanic
Must be planning to go out the bottom rather than the top. I saw someone say they will be recharging the AC but if you go out the bottom I hardly see a need to evacuate there AC. Who knows.
I don't think I've ever opened up an AC system to pull a subaru engine. I just pull the compressor aside, if there's not enough slack in the lines to just put it on the strut tower, it's proper to just hook it out of the way under the hood with a bungee cord.
About the cam caps vs carrier housing:
The service manual indicates
37. REMOVE CAMSHAFT HOUSING SUB-ASSEMBLY RH
NOTICE:
Do not remove the intake and exhaust camshafts first as it may cause a deformation of the cylinder head sub-assembly.
41. REMOVE CAMSHAFT HOUSING SUB-ASSEMBLY LH
NOTICE:
Do not remove the intake and exhaust camshafts first as it may cause a deformation of the camshaft housing sub-assembly LH.
My issues with this is:
- It's already contradicting itself.
- A cylinder head stands little chance of getting warped by the flimsy lower cam housing should the upper housing the removed in place: the head is still bolted to the block
- The upper camshaft housing will undergo the same stress, should it be separated on or away from the engine: I'll flop around just as much.
- The lower camshaft housing has more chance of remaining straight if it stays bolted to the already flat and stiff cylinder head that's already bolted to the flat and stiff crankcase.
Old 12-26-2018, 09:00 AM   #556
ermax
ermax's Avatar
I agree on most cars but on the Twins the lines have to be very severely bent to clear the engine when going out the top. I was able to pull it off and so have many others but if I was a dealer I would avoid the risk of destroying the lines. The manual calls for evacuating the AC and I'm sure that is how they would do it.
I agree with you on this point. The wording is a little confusing. I think they were talking about the heads though. My logic is that there is no such thing as a "cylinder head sub-assembly" on this car. There is a head and a "camshaft" housing sub-assembly.
It isn't the flimsy subassembly that warps heads, it's the valve springs that warp the heads. I don't think it would be an issue unbolting caps first if a correct sequence was laid out by the engineers. This just isn't the way they originally intended it to be done.
No it doesn't because the springs are not in the picture once the subassembly is removed.
Old 12-26-2018, 09:06 AM   #557
ermax
ermax's Avatar
Cars are safely transported all the time. I'd rather have my car transported to a team of guys that are dedicated to this specific task and know they did it right. I'm not saying the local dealer would mess it up but I think the odds would be better with a dedicated team.
The Following User Says Thank You to ermax For This Useful Post:
humfrz (12-26-2018)
Old 12-26-2018, 09:37 AM   #558
RZNT4R
Since it's 2 cylinders per bank, there's a "zero lift range" where the valve springs are completely unloaded, it's easy to have the whole valvetrain unstressed for disassembly on the engine.
Old 12-26-2018, 09:38 AM   #559
ermax
ermax's Avatar
That's a great point!
Old 12-26-2018, 10:36 AM   #560
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
I really doubt they're unloaded at any point in time. That would make for a very rattly valvetrain.
Broken Valve Spring sybrite Engine, Exhaust, Transmission 45 11-02-2018 05:20 AM
Valve spring swap rcmf5525 Engine, Exhaust, Transmission 6 05-19-2018 04:12 PM
Jrsc replacement diverter valve issue Brzxton Forced Induction 6 12-08-2017 10:39 AM
GSC FA20 Valve Spring Kits MAPerformance Engine, Exhaust, Transmission 41 07-20-2015 11:22 AM
Skunk2 Dual Valve Spring and Titanium Retainers limitedblkwrx Engine, Exhaust, Transmission 0 01-05-2015 12:12 AM
