Old 12-20-2018, 07:03 PM   #533
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
I wouldn't count on them doing all sorts of free extra work no matter if the part has to come off anyway. They will receive very little from Subaru for doing the work and are not going to throw away money on doing extra work on 400,000 cars. Doesn't hurt to ask though since individual dealers may be fine with it. Just don't get all pissy if they say no since they are a business and do have to make money the same as any other.
Oh I planned on paying for some level of labor. Just hopefully it's not just book time! I'LL GET PISSY IF I WANT, I'M ENTITLED TO FEELING. Friggen @Tcoat trying to oppress me..
The Following 2 Users Say Thank You to DarkPira7e For This Useful Post:
Tcoat (12-20-2018), Ultramaroon (12-20-2018)
Old 12-20-2018, 07:15 PM   #534
ermax
ermax's Avatar
I wanna know why the end links are getting replaced lol
Must be planning to go out the bottom rather than the top. I saw someone say they will be recharging the AC but if you go out the bottom I hardly see a need to evacuate there AC. Who knows.
The Following User Says Thank You to ermax For This Useful Post:
Tcoat (12-20-2018)
Old 12-20-2018, 07:32 PM   #535
DarkPira7e (12-20-2018), gravitylover (12-21-2018)
Old 12-20-2018, 08:08 PM   #536
n0thing
Drives: Subaru BRZ
it's from the top, and only the automatic asks for the swaybar/link to be dropped
n0thing is offline   Reply With Quote
Old 12-20-2018, 08:39 PM   #537
BRZnut
Drives: BRZ DGM Limited
As these get done it would be great if we could have a separate thread (maybe a sticky?) where we can post our experience with the repairs..good or bad.
The Following User Says Thank You to BRZnut For This Useful Post:
Old 12-20-2018, 11:11 PM   #538
n0thing
Drives: Subaru BRZ
basically remove engine, timing chain cover, chain, valve cover, cams, rocker arms, valve springs
doubt i can upload the whole document, but feel free to ask questions
Old 12-20-2018, 11:40 PM   #539
reeves
This recall actually makes me feel grateful my '13 BRZ got t-boned (and totaled) last month . Especially since I've been revving to 8K rpm the past 4 years & 65K miles. Makes me wonder how much more punishment the 'defective' valves springs could handle?
I'd do it all over again if I could. But maybe I'll buy a '15 & up BRZ this time around.
Old 12-20-2018, 11:44 PM   #540
Maybe the requirement is to have refrigerant at the ready for contingency.
Old 12-21-2018, 09:33 AM   #541
ermax
ermax's Avatar
Why touch the endlinks? The manual doesn't say anything about touching the end links even on the auto.
Old 12-21-2018, 09:34 AM   #542
ermax
ermax's Avatar
I have a question, are the cam subassemblies coming off or are they cheating and removing cam caps to get the cams off?
Old 12-21-2018, 10:32 AM   #543
n0thing
Drives: Subaru BRZ
not sure why, the next step says "REMOVE AUTOMATIC TRANSMISSION ASSEMBLY COUPLING BOLTS AND NUTS (FOR AUTOMATIC TRANSMISSION)"
removing the cam caps
keep in mind that technicians may deviate from the published technical instructions to save time, so for example, the swaybar/endlinks may not get touched at all
The Following 3 Users Say Thank You to n0thing For This Useful Post:
ermax (12-21-2018), Tcoat (12-21-2018), Ultramaroon (12-21-2018)
Old 12-21-2018, 10:47 AM   #544
ermax
ermax's Avatar
Okay so they are contradicting the original service manual which specifically says NOT to remove the caps before removing the subassembly for risk of warping the head. They must have come up with new untorquing steps to allow them to remove the caps without removing the subassembly first without causing warpage. This would be a HUGE time saver.
Thinking about this some more, this would make valve lash corrections much easier because you don't have to clean up and reapply packing seal other than the little bit that is on the caps and valve cover. At some point this revision to the instructions needs to go public.
@n0thing, do you know if these instructions are on TIS yet?
The Following 2 Users Say Thank You to ermax For This Useful Post:
Old 12-21-2018, 11:24 AM   #545
n0thing
Drives: Subaru BRZ
@ermax as in regular shop manual for camshaft removal? it still shows removal of cam sub-assembly first, then caps
The Following User Says Thank You to n0thing For This Useful Post:
Tcoat (12-21-2018)
Old 12-21-2018, 12:04 PM   #546
Somebody really needs to post the TSB instructions!
If anybody has them but does not want to be linked to them just PM them to me and I will do it.
If they have been posted and I missed them I would truly appreciate a pointer.
Broken Valve Spring sybrite Engine, Exhaust, Transmission 45 11-02-2018 05:20 AM
Valve spring swap rcmf5525 Engine, Exhaust, Transmission 6 05-19-2018 04:12 PM
Jrsc replacement diverter valve issue Brzxton Forced Induction 6 12-08-2017 10:39 AM
GSC FA20 Valve Spring Kits MAPerformance Engine, Exhaust, Transmission 41 07-20-2015 11:22 AM
Skunk2 Dual Valve Spring and Titanium Retainers limitedblkwrx Engine, Exhaust, Transmission 0 01-05-2015 12:12 AM
