Old 12-20-2018, 01:46 PM   #519
Dake
Dake's Avatar
Late to the party, but just got a call from the dealer that sold me my FR-S to check if I was still the owner.
They said they don't have the parts in yet, but will notify me when they do so I can bring it in.
Forgive me since I'm sure it's been asked already (easy to miss in 37 pages), but is this a motor-out situation on a boxer? I'm wondering if I should go ahead and have them do the spark plugs while they're in there.
Dake is offline   Reply With Quote
Old 12-20-2018, 01:49 PM   #520
Originally Posted by meadowz06 View Post
I have the valve spring recall information from Toyota. Different parts for automatics and manuals.
Interesting. The springs themselves? o.0
Old 12-20-2018, 02:33 PM   #521
n0thing
Drives: Subaru BRZ
AUTOMATIC
SU003-08061
SPRING-VALVE EG KIT
1
*The kit above includes the following parts.
Part Description
Part Number
Qty
Drawing
Individually Packaged Parts
Inner Compression Spring
SU003-07325
16
Fig.2_30
Fuel Delivery Pipe No.2
SU003-00342
1
Fig.2_21
Cylinder Head Cover Gasket
SU003-00280
1
Fig.2_27
Cylinder Head Cover Gasket No.2
SU003-00281
1
Fig.2_28
Front Stabilizer Link Assembly
SU003-00394
2
Fig.1_11
Nut (Stabilizer Link)
SU003-04506
4
Fig.1_12
Nut (Exhaust Manifold)
SU003-02872
6
Fig.1_6
A1 kit
Bolt (Cowl Brace)
SU003-02821
2
Fig.1_1
Nut (Cowl Brace)
SU003-02885
6
Fig.1_2
Bolt (Body Mounting Cushion)
SU003-02801
6
Fig.1_9
SU003-02816
2
Fig.1_10
B kit
C kit
D1 kit
Spark Plug Tube Gasket
SU003-06775
4
Fig.2_29
Crank Shaft (Timing Chain or Belt Cover) Oil Seal
SU003-02180
1
Fig.2_17
Exhaust Manifold to Head Gasket
SU003-01111
2
Fig.1_5
C kit
Oil Pan Drain Plug Gasket
SU003-02159
1
Fig.1_8
Crank Shaft Pulley O-ring
SU003-02190
1
Fig.2_16
Timing Gear Case Lower O-ring
SU003-02186
1
Fig.2_24
Timing Gear Case Upper O-ring
SU003-02183
3
Fig.2_25
Oil Level Dipstick Guide O-ring
SU003-00306
1
Fig.2_15
O-ring (Vacuum Pump)
SU003-02184
1
Fig.2_23
Chain Tensioner O-ring
SU003-02185
1
Fig.2_26
O-ring (High Pressure Pump)
SU003-02187
1
Fig.2_22
Fuel Injector Seal (No.2)
SU003-00324
2
Fig.2_18
Fuel Injector Grommet
SU003-00317
2
Fig.2_19
Fuel Injector O-ring (No.2)
SU003-00335
2
Fig.2_20
O-ring (Discharge Hose)
SU003-A0025
1
Fig.1_3
D1 kit
Throttle Body Gasket
SU003-00316
1
Fig.1_4
Radiator Drain Cock Packing
SU003-01196
1
Fig.1_7
Clip (Under Cover)
SU003-02984
4
Fig.1_13
Clip (Under Cover)
SU003-02989
9
Fig.1_14
Clip (Wire Harness)
SU003-06476
3
Fig.2_31
Clip (Wire Harness)
SU003-06475
4
Fig.2_32
MANUAL
SU003-08062
SPRING-VALVE EG KIT
1
Part Description
Part Number
Qty
Drawing
A1 kit
B kit
C kit
D1 kit
SU003-07325
16
Fig.4_24
SU003-00342
1
Fig.4_16
SU003-00280
1
Fig.4_21
SU003-00281
1
Fig.4_22
SU003-02872
6
Fig.3_6
A2 kit
Bolt (Cowl Brace)
SU003-02821
2
Fig.3_1
Nut (Cowl Brace)
SU003-02885
6
Fig.3_2
B kit
SU003-06775
4
Fig.4_23
SU003-02180
1
Fig.4_12
SU003-01111
2
Fig.3_5
C2 kit
SU003-02159
1
Fig.3_8
SU003-02190
1
Fig.4_11
SU003-02186
1
Fig.4_18
SU003-02183
3
Fig.4_19
SU003-00306
1
Fig.4_10
SU003-02185
1
Fig.4_20
SU003-02187
1
Fig.4_17
SU003-00324
2
Fig.4_13
SU003-00317
2
Fig.4_14
SU003-00335
2
Fig.4_15
SU003-A0025
1
Fig.3_3
D2 kit
SU003-00316
1
Fig.3_4
SU003-01196
1
Fig.3_7
Clip (Under Cover)
SU003-02984
4
Fig.3_9
Clip (Wire Harness)
SU003-06476
3
Fig.4_25
Clip (Wire Harness)
SU003-06475
4
Fig.4_26
n0thing is offline   Reply With Quote
The Following User Says Thank You to n0thing For This Useful Post:
Ultramaroon (12-20-2018)
Old 12-20-2018, 03:11 PM   #522
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
From what I can tell it's just the differences between the motors require different things to be replaced it seems (gaskets, nuts, etc)
Old 12-20-2018, 03:12 PM   #523
finch1750
finch1750's Avatar
I wanna know why the end links are getting replaced lol
Old 12-20-2018, 03:35 PM   #524
They're anticipating cutting off rusty parts for the sake of expediency, or just normal wear.
Old 12-20-2018, 03:48 PM   #525
finch1750
finch1750's Avatar
Makes sense given I had to cut one of mine off lol
Old 12-20-2018, 04:02 PM   #526
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Wonder if it'd be much to have them replace spark plugs while they're in there...
Old 12-20-2018, 04:27 PM   #527
n0thing
Drives: Subaru BRZ
the plugs are removed during the process, so you should only pay for the part.
Old 12-20-2018, 04:43 PM   #528
DarkPira7e
DarkPira7e's Avatar
Yeah seems likely. I wonder what else could be upgraded/ replaced...
Old 12-20-2018, 05:01 PM   #529
I wouldn't count on them doing all sorts of free extra work no matter if the part has to come off anyway. They will receive very little from Subaru for doing the work and are not going to throw away money on doing extra work on 400,000 cars. Doesn't hurt to ask though since individual dealers may be fine with it. Just don't get all pissy if they say no since they are a business and do have to make money the same as any other.
Old 12-20-2018, 05:06 PM   #530
n0thing
Drives: Subaru BRZ
it pays 12.5 (manual) or 13.8 (auto), that's less than FRM lol
Old 12-20-2018, 05:08 PM   #531
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Well doesn't that just sound totally reasonable... I Hope that you receive this level of customer service.
But, from my experience with local dealerships: They will charge for ANYTHING & EVERYTHING not covered under the recall.
I expect them to try and charge me for any additions. (like the spark plugs)
My dealership sucks: they ran my bumper into the curb last time I left my car with them. Then parked it so close to a wall that I didn't see the scrape on the passenger side till later that day. (I wondered why my car was parked funny; guess I should have checked it out better before driving off)
I called and they basically told me to prove it didn't happen after I left.
I LIKE TIRES!
Old 12-20-2018, 05:36 PM   #532
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
Thats so shady, I would never go back to that stealership. The few times I took my car to the stealership I was pissed they had to adjust every single part of the driver seat. Seat up down, back tilt, forward and back, then go and adjust the damn steering column. WTF they drove it like 40 feet from the garage to where I was standing, they did not test drive it. This was for those free oil changes when new.
I'm so not thrilled about taking my car in for this recall. I saw someone posted claiming that in some documentation they have if the spring where to fail then it would have likely done so in the first 3k. I asked to please post that image and still waiting.
DandoX is offline   Reply With Quote
The Following User Says Thank You to DandoX For This Useful Post:
Leonardo (12-20-2018)
Broken Valve Spring sybrite Engine, Exhaust, Transmission 45 11-02-2018 05:20 AM
Valve spring swap rcmf5525 Engine, Exhaust, Transmission 6 05-19-2018 04:12 PM
Jrsc replacement diverter valve issue Brzxton Forced Induction 6 12-08-2017 10:39 AM
GSC FA20 Valve Spring Kits MAPerformance Engine, Exhaust, Transmission 41 07-20-2015 11:22 AM
Skunk2 Dual Valve Spring and Titanium Retainers limitedblkwrx Engine, Exhaust, Transmission 0 01-05-2015 12:12 AM
