| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
nenber
bleeding
hi
is there any real advantage by doing clutch/brake bleeding with pressure?(like someone to press the brake pedal/clutch pedal)instead of just open the nipple and let it bleed itself. |
#2 |
Time
| The Following 3 Users Say Thank You to swarb For This Useful Post: |
#3 |
nenber
as i thought.
thanks |
#4 |
Thanks
I tried gravity bleed and gave up after 30 minutes. Might be fine if you can leave the car sit for a while.
#5 |
A getto trick is to use a large syringe matched to a vacuum line hose that fits tight on the nipple.
Connect syringehoseatron-lossen nipple-suck fluid- tighten nipple-empty syringe and go again. I've done this a few times, never had a issue.
http://www.ft86club.com/forums/showthread.php?t=133311 I'm only here for the biscuits |
| The Following 3 Users Say Thank You to 86MLR For This Useful Post: |
#6 |
nenber
#7 |
That's pretty much how I bleed mt bike hydro brakes. Down and dirty - done.
#8 | |
Drives: BRZ 2018
But it needs good bleeding, 100-200kms of driving and bleeding again as to replace all the old brake fluid. |
#9 | |
Drives: FRS 2013
Wow, will have to try this next time |
#10 | |
nenber
Sent from my SM-G960F using Tapatalk |
#11 |
Drives: BRZ 2018
| The Following User Says Thank You to JIM THEO For This Useful Post: | Legend@wheels (12-19-2018) |
#12 |
Drives: 2016 Subaru BRZ
Get a scan tool that does ABS bleed, problem solved. Cheapest one on Amazon is around $225.
#13 |
Drives: BRZ 2018
4-5 times the cost of new good brake fluid while labor is quite cheap locally...
#14 |
nenber
| brake bleeding, air in abs? | Grip Ronin | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 13 | 11-22-2018 08:34 PM |
| Bleeding Air through TPMS | GarStar | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 05-05-2015 03:14 PM |
| My Car is bleeding! | Ec1990 | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 5 | 04-01-2014 11:31 AM |
| Speed Bleeding time away | developer | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 12-31-2012 08:07 PM |
| Brake bleeding order? | ubersoph | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 08-10-2012 08:13 AM |
