Old 12-11-2018, 12:53 PM   #15
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Originally Posted by Brz_racer View Post
Well you can rule out CV Joint RWD cars do not have them.
Erm ... have you actually had a look?
Sapphireho (12-11-2018)
Old 12-11-2018, 01:09 PM   #16
pakunodafie
Drives: Toyota GT86
Is the car stock? If not, what modifications are there?
Also, has there been any maintenance activities just before this started happening?
Car totally stock, after 90k kms maintenance, same day I got the car I experiencing this issue.
pakunodafie is offline   Reply With Quote
Old 12-11-2018, 01:11 PM   #17
pakunodafie
Drives: Toyota GT86
Did you check the CV joints, like you mentioned?
Is the rear axle nut tight?
Yes all tight, I lift and check the car under there's nothing wrong.
Old 12-11-2018, 01:14 PM   #18
pakunodafie
Drives: Toyota GT86
Originally Posted by BigTuna View Post
Is the exhaust rattling on something?
Exhaust is stock, no rattling. I already reseat them and still. a mysterious sound coming under the car.
Old 12-11-2018, 01:22 PM   #19
pakunodafie
Drives: Toyota GT86
You guys think nothing internal issue here? No CEL, No Codes.
If Internal issue exist ex: Engine / Driveshaft / Gearbox / Drivetrain / Transmission.
Does my car still run smooth? I mean it's still safe to drive?
Cause I'm thinking if Internals are issues here clangking sounds can be noticable at all times and it will stall or a tow truck call. What do you think guys?
Old 12-11-2018, 01:28 PM   #20
Well, from what I hear in your posted video, the sound doesn't sound like it would lead to a life threatening situation.
However, it should be tracked down and fixed.
Old 12-11-2018, 01:29 PM   #21
pakunodafie
Drives: Toyota GT86
And here's another soundclip video, Toyota guys roadtesting my car before they exit in Toyota warehouse they heard something dragging under the car. (tho windows is open so they're not sure if it comes from the car) but I can confirmed 100% that the sound comes from the car and same sound I heard this few times now.
Please check the soundclip and analyze:
(Issue #2 - Sounds like I'm dragging a garbage can)
https://www.dropbox.com/s/volcha118e...4_1_1.mp4?dl=0
(Issue #1 - Metal on Metal Clanging sound)
https://www.dropbox.com/s/6ntx911o8f...1_1_1.mp4?dl=0
Odd sound at 6k RPM dutchman1 Engine, Exhaust, Transmission 25 01-02-2017 05:41 PM
Does this sound deal sound decent ? awhatzable Scion FR-S / Toyota 86 GT86 General Forum 29 11-21-2015 11:02 AM
Drone (Worn Wheel Bearing SOund) Sound From Rear qbzee007 AFRICA 8 11-14-2014 02:04 AM
South Sound Summer Jam 2013 | 8.18.13 | South Sound Speedway RussellM Northwest 13 09-05-2013 10:57 AM
Best sound BAE Engine, Exhaust, Transmission 4 09-30-2012 10:30 PM
