Old 12-10-2018, 09:13 AM   #15
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
Originally Posted by pgranberg11 View Post
So what's left that still needs to be developed? The oil pan solution, shifter solution, and the pnp motec?
our mock up oil pan is being jigged up and the first production piece is being built so we can final test fit before making a run of them
shifter is after the header, which is very close now
first harness is in production and we should have it soon. most of the hard work is already done as far as the oem integration goes since its similar to our 2j/ls package.
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
The Following 2 Users Say Thank You to spitfire481 For This Useful Post:
Draco_PR23 (12-11-2018), pgranberg11 (12-10-2018)
Old 12-10-2018, 09:15 AM   #16
spitfire481
Drives: 2JZ FRS
Originally Posted by Yardjass View Post
Subscribed because this is gonna be cool.
So stupid question. What's that barb coming out the back of the motor near the heater barbs that come out of the firewall? Looks like kind of a tight fit and a potential problem without a more custom solution.
crankcase vent. nice thing about the honda motors is that almost everything billet exists already. I have seen a few press in 90 degree fittings to replace that straight one with
MoTeC
Build Thread
@spitfire481
Old 12-10-2018, 04:06 PM   #17
Evil Rocky
Drives: FRS
I am so excited for this!! I am going to buy the mounts hopefully right after xmas
Evil Rocky is offline   Reply With Quote
Old 12-10-2018, 04:23 PM   #18
Icecreamtruk
Drives: Track preped NA FRS
The more time passes, the more I like this. I just hope my current engine will last enough for this project to be finished, so I can move straight into it!
Icecreamtruk is offline   Reply With Quote
Old 12-10-2018, 05:12 PM   #19
gtengr
Drives: 2017 BRZ
Originally Posted by spitsnaugle View Post
Just guesstimating here-
I recall hearing the FA20 engine trans combo being around 485lbs according to vorslag.
The K series and trans weighs in at 402lbs according to the k series forum.
With some other mods it could make for a nice super-light car.
There was some back and forth on this in the other thread with some sources. The K24A1 with stock header, starter, and alternator (no trans/flywheel/clutch/AC/cat in the header) is ~283 lbs on a scale.
gtengr is offline   Reply With Quote
The Following User Says Thank You to gtengr For This Useful Post:
venturaII (12-11-2018)
Old 12-13-2018, 11:47 AM   #20
Pure Automotive
Pure Automotive's Avatar
Drives: 2013 FRS Whiteout
Originally Posted by Cubix View Post
Will there be an option to use stock transmission in the future?
No, we decided to not even go that route because the stock trans is garb.. not reliable . I have people with bone stock FA20s that have synchro issues, and Its not worth the R&D to make a plate and everything in my opinion.
Pure Automotive is offline   Reply With Quote
The Following 3 Users Say Thank You to Pure Automotive For This Useful Post:
funwheeldrive (12-13-2018), Jyn (02-10-2020), Sportsguy83 (12-13-2018)
Old 12-13-2018, 02:57 PM   #21
Joesurf79
Joesurf79's Avatar
Drives: 2016 White Pearl BRZ Premium
Okay - questions for the source:
1) With the Motec kit will it be possible to retain ABS, Factory Tach, and fuel level?
2) Who produces the adapter kit to mate the S2000 trans to the K24?
Understanding that this is an FT86 forum and not a Honda site, there are many who have experience with both platforms. I am not one however. So I ask:
3) I have heard hearsay that 250 hp is possible N/A with a factory K24 bottom end. Is that reliable? I mean dead-stone, lap after lap, beat on it, road course car reliable?
4) What is involved in making that kind of power? Will a set of Cams / head porting / headers / tune get you there?
Thanks guys!
Joesurf79 is offline   Reply With Quote
The Following User Says Thank You to Joesurf79 For This Useful Post:
Icecreamtruk (12-13-2018)
Old 12-13-2018, 03:18 PM   #22
Code Monkey
Drives: Subaru BRZ
^ Uh, oh.
Code Monkey is offline   Reply With Quote
Old 12-13-2018, 03:22 PM   #23
Joesurf79
Joesurf79's Avatar
Originally Posted by Code Monkey View Post
^ Uh, oh.
Hahahahah! Hey man, FI on a 12.5:1, direct injected, bloated, too heavy, too far forward motor just doesnt sit well with me
A lighter larger, farther back na motor with same power...very tempted
The Following 2 Users Say Thank You to Joesurf79 For This Useful Post:
Code Monkey (12-13-2018), Icecreamtruk (12-13-2018)
Old 12-13-2018, 03:59 PM   #24
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Yes all are retained with the Motec package.
The Following 3 Users Say Thank You to Sportsguy83 For This Useful Post:
Icecreamtruk (12-13-2018), Joesurf79 (12-13-2018), surfwaxsmitty (12-14-2018)
Old 12-13-2018, 04:14 PM   #25
Icecreamtruk
Question, which motor is the one used in the swap exactly? Im sorry im a complete clueless guy outside of this particular car. From all I read about honda Kseries, there are a couple of k24 but all of them seem to make anywhere from 130 to 180hp, is it just possible to get like 60-100hp out of these engines in NA form?
I basically just want to know the engine code so I can look up a bit more in the details of perf parts for it and local prices of used engines around here. Preparing for the future basically.
Old 12-13-2018, 05:00 PM   #26
PulsarBeeerz
Drives: JRSC BRZ SOLD
I would think the K24A2 but keep in mind you need a K20 RSX type S head to make decent numbers. It's a 200hp motor stock. Speed Academy on YouTube did a K24 swap with a 240 a few months back.
PulsarBeeerz is offline   Reply With Quote
The Following User Says Thank You to PulsarBeeerz For This Useful Post:
Old 12-13-2018, 05:19 PM   #27
BertoFT
Drives: 13 FRS Firestorm
I'm also ignorant when it comes to Honda's. I know my way around a car, but I don't have the time or tooling to rebuild a junker. 4Piston seems reputable, and a built engine for 8k doesn't sound too expensive. You can at least read into their exploits to get an idea as to what mods get you power.
This is what I'm looking at:
http://www.4pistonracing.com/k24-340...omplete-engine
"*The high flow CNC cylinder head and high lift camshaft allow this engine to accelerate its 340hp aggressively beyond 9000 rpm."
Sent from my SM-G9600 using Tapatalk
BertoFT is offline   Reply With Quote
The Following User Says Thank You to BertoFT For This Useful Post:
Old 12-13-2018, 05:23 PM   #28
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Are the S2K transmissions that much more robust than ours? I'd thought they were somewhat related in design, and so would be in the same ballpark for overall strength. Keeping our transmission would simplify things somewhat...no shifter rework or custom driveshaft needed, etc. Plus, aren't you using an adapter plate for the S2K transmission to the K motor anyways..?
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
Pure Auto's Swap Compilation Thread - 2JZ and LSX ! Pure Automotive Engine Swaps 29 01-10-2018 02:20 AM
SwapYour86.Com Pure Automotive 2JZGTE Billet Intake Manifold For 2JZ FT86 Swap Pure Automotive Engine Swap 0 12-01-2017 12:57 PM
SwapYour86.Com Pure 2JZ MoTeC Plug & Play Wiring For FT86 !! Pure Automotive Engine Swap 0 12-01-2017 12:49 PM
SwapYour86.Com Pure LSX MoTeC Plug & Play Wiring For FT86 !! Pure Automotive Engine Swap 0 12-01-2017 12:23 PM
Pure Auto's 2JZ Swap Thread - The DRAGFRS Pure Automotive Engine Swaps 153 06-20-2016 07:33 PM
