#491 | |
Drives: 13 FR-S, 90 Honda ED6, 07 TBSS
#492 |
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
#493 | |
As far as compensation, many techs work as "independent contractors" with the dealership and are paid rates based on either the "book rate" for a repair or other agreement. If the manufacturer sets an hourly rate for the work, that is likely what the tech will be paid based on, which could be less than a retail customer rate. I'm basing this off some limited experience as I have family members who are in the "dealership" business but it could obviously vary.
#494 | |
| The Following User Says Thank You to frsty_86 For This Useful Post: | Dadhawk (12-03-2018) |
#495 |
Drives: GTS 86 auto
A couple of years ago I had the hose off the throttle body off and noticed a slight build-up & cleaned it out (from memory I think I used a cotton bud moistened with acetone). I do not have it listed as a routine maintenance in my Toyota service coupon book. I will write it in. "Cleanliness is next to godliness"
GTS86 Auto (Australia)
#496 | |
Drives: 2012 GT86 Dark Grey
its free for the customer, the dealer is compensated for around 12 to 13,5 hours. I have the recall maintenance manual so I can check if you guys would like. I dread this recall as my car is also affected. Currently on 197K Kilometers (122K miles) and it drives like a dream, no issues at all, no oil leaks, nothing.. I'm afraid that once the work is done something will be wrong |
| The Following User Says Thank You to Crydo For This Useful Post: | humfrz (12-05-2018) |
#497 | |
Rust bucket enthusiast
#498 | |
When I will get this done I want to have it on record that the dealer agrees that everything is currently fine, get them to sign a document of agreeing that its not leaking, take them for a test drive, etc etc. If the car does start to have issues I will at least have something to fall back on..... if they agree to my terms that is |
#499 | |
![]() humfrz |
#500 |
Initial G
Drives: 13 FR-S, 15 BMW 228i
I've got 78k miles on mine and I'm about to install the Edelbrock SC. I'm more worried that the dealer techs won't do a good job and the engine will grenade after the SC goes on, and it will be my problem then.
The car runs great right now, no odd noises or issues. If it DOES blow up and I didn't do the recall, well at least I can build the block and turn up the boost... lol.
2013 FR-S
2015 BMW 228i |
#501 |
Drives: Asphalt FR-S
How does this affect blown engines...?
Any thoughts on how Toyota will treat me? My stock engine grenaded at around 80k and now I have a refurbished engine installed by a dealership for approx 10k out of my own pocket because Toyota refused to provided assistance (they never said why) but presumably because I was past warranty. As mentioned here this problem is not simply worse case scenario the engine stalls...
#502 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
Would depend on if the replacement engine falls within the recall - by VIN number.
If not a VIN recall, you should be in the clear. For that problem, anyway.
"I gotta rock." -- Charley Brown |
#503 |
The first go around my VIN was not part of the recall.
Then the recall check sites went down and didn't work. The recall sites are back up and now IT IS part of the recall. So yeah, just a heads up for everyone to check again, even if it said you're not affected the first time. https://www.subaru.com/vehicle-recalls.html https://vinrcl.safercar.gov/vin/vinLookup |
#504 |
Yep I'm on the official list now too.
| Broken Valve Spring | sybrite | Engine, Exhaust, Transmission | 45 | 11-02-2018 04:20 AM |
| Valve spring swap | rcmf5525 | Engine, Exhaust, Transmission | 6 | 05-19-2018 03:12 PM |
| Jrsc replacement diverter valve issue | Brzxton | Forced Induction | 6 | 12-08-2017 09:39 AM |
| GSC FA20 Valve Spring Kits | MAPerformance | Engine, Exhaust, Transmission | 41 | 07-20-2015 10:22 AM |
| Skunk2 Dual Valve Spring and Titanium Retainers | limitedblkwrx | Engine, Exhaust, Transmission | 0 | 01-04-2015 11:12 PM |
