Old 08-25-2018, 07:07 PM   #869
seekerof86
seekerof86's Avatar
Drives: 13' FRS
The newest ROM for a 2013 Auto from USA would be the ZA1JA02G?
I'm worried about the DI and want to update my new car to the newest version. Previous owner never went to the dealership for any kind of work. When I asked the dealer now to upgrade it's an hour of labor plus parts ($150)...
Thanks
'13 FRS ultramarina 6AT fully stock
- mods in progress
seekerof86 is offline   Reply With Quote
Old 08-26-2018, 03:29 AM   #870
steve99
Drives: FT86
Thanks
Haha there is no parts for ecu rom reflash takes 5 minutes
A02G is manual european\australian rom
For a 2013 USA auto you want a ZA1JB01D for latest rom with di seal transient retard fix.
If you buy tactrix you might as well flash a tuned rom :-)
gt7877 (09-09-2018)
Old 09-16-2018, 02:44 PM   #871
steve99
Drives: FT86
Added ZA1JN00S Australian 2018 Auto rom
Old 10-09-2018, 10:53 AM   #872
FRS2017
Enthusiast 86
FRS2017's Avatar
Drives: Toyota 86 GT
Hi Steve99
Still loving the flash you did for me, will be upgrading my header for a stage 2 tune and give it more power.
Will give you bell when the bank account hasn't taken a beating since the header is 530 AUD and then got to go to a DIY Garage and install it myself. Looking forward to making a tit of my self under my engine of my Toyota 86 GT this month.
FRS2017 is offline   Reply With Quote
The Following User Says Thank You to FRS2017 For This Useful Post:
steve99 (10-11-2018)
Old 10-31-2018, 05:17 AM   #873
steve99
Drives: FT86
Hi @micnic559 you private massaged me but i cannot reply as you have blocked private messages
Old 11-18-2018, 01:19 PM   #874
tomm.brz
Drives: brz 2017 hksv2
Does anyone have ZA1JQ00G EU MT MY18 stock rom?
OFT already released v4 tunes for it, but it s actually a K00G hacked to Q00G
but Ecutek also doesnt have it on his database and can t find the stock one
Old 11-19-2018, 08:16 PM   #875
Kodename47
Kodename47's Avatar
Drives: UK GT86
Can you not read it and send it in to them? TBH I bet there's little difference between that and the K00G.
.: Stealth 86 :.
Kodename 47 DJ:
Old 11-19-2018, 10:37 PM   #876
tomm.brz
Steve sent me a Q00G stock to me
i m watching at it, it s quite a few changes actually
for now.i found that in Q00G
-they made Calculated engine load.compensation #1 bigger again and with different values , mostly under 0.4bar of MAP, i guess for idle stability
-also changed the GDI fire angle tables: around idle now is 290, and they raised to 330-340 in high load to 4800, instead of the 300 of K00G roms
-desired overrun maf #1 #3 look in opposite order than K00G
-DI maximum quantity, they raised to 1.2ML at 2000rpm instead of 0.9ML
-they changed the Front lambda scaling to the same as K00C, now it reached 0.69 lambda instead of 0.828lambda
-they changed quite a lot PI/DI ratio tables, rising PI use quite a lot
-changed Primary open loop table, look similar to K00C, leaner until 4400 rpm, and progressively going richer untill 7400
-changed Fuel map compensation for when AM is lower than 1, made it quite richer
-changed the two IDle stability control #1 #2 maps, more similar to stock K00C
-maf correction after start tables are now bigger and with slighty different values for all rows
-throttle delta fuel comp delta and thresholds are not good defined by ecutek I think
steve99 (11-19-2018)
Old 11-20-2018, 02:30 AM   #877
JIM THEO
Drives: BRZ 2018
A lot of changes for same MY car!
JIM THEO is offline   Reply With Quote
Old 11-20-2018, 03:58 AM   #878
tomm.brz
They look to me all positive changes to a calid (k00g) that sucks a lot overall
Old 11-20-2018, 04:06 AM   #879
steve99
Drives: FT86
Might be mostly emmissions related.
Do the Q00G cars get the red manifold and better header yet in europe ?
Old 11-20-2018, 04:11 AM   #880
tomm.brz
No, still old logic and old hardware
Now i ask the people with q00G i know, if they are still "Euro 6b" on the car's paper like the my17, for emissions, or they have the newer Euro 6C/6D
Old 11-20-2018, 06:00 AM   #881
tomm.brz
Oh they changed also cam timing
from 6400 to red line, exhaust cams stay at 20 instead reducing to 0
From 6000 to red line, intake cams have +10
Closed loop min temp is now -40C instead of -12C, as steve said I guess for emissions
Delayed open loop fuel Load Threshold #1 has lower thresholds, around -20% overall
Old 11-21-2018, 05:52 AM   #882
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Quote from the latest Subaru Drive magazine:
"Der Subaru BRZ ist eine ausgewiesene Spaßmaschine und erfüllt mit dem Modelljahr 2019 die Abgasnorm Euro 6d-TEMP."
"The Subaru BRZ is a designated fun car and meets with the 2019 model year the Euro 6d-TEMP emissions."
ecuflash, tactrix, taxtrix, tuning
ECUFlash - Getting close! xjohnx Software Tuning 698 03-22-2015 01:10 PM
EcuTek Flash finished but now it shows only a Partial Flash... Cross Software Tuning 32 02-12-2014 11:55 AM
Tactrix Openport jamesm Engine, Exhaust, Bolt-Ons 1 01-28-2014 09:27 PM
Visconti Tuning - Latest BRZ Flash Info Visconti Software Tuning 6530 12-24-2013 11:18 PM
Overboost Protection With OFT/EcuFlash? FrX Software Tuning 9 10-23-2013 08:27 AM
