Old 11-14-2018, 01:10 AM   #1
danielmailrs
Asphalt grinder
Drives: brz
common faults
hi fellas
im a new owner of a sub brz 15' .
i would like to know what are the common faults/known and weak spots of these cars and what to look for to avoid as possible as i can from those problems.
cheers
danielmailrs is offline   Reply With Quote
Old 11-14-2018, 01:46 AM   #2
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
Most of the major problems have been taken care of before the '15 model.
Don't worry too much.
Just keep an eye on your fluids (coolant and engine oil esp.) and for any oil stains around your engine.
Get familiar with your transmission. If you start hearing* squeeking or squeeling, replace the throwout bearing if you got a manual.
http://www.ft86club.com/forums/showthread.php?t=117440
Last edited by Bonburner; 11-14-2018 at 03:18 AM. Reason: fixed healing to hearing*
The Following 2 Users Say Thank You to Bonburner For This Useful Post:
danielmailrs (11-14-2018), humfrz (11-14-2018)
Old 11-14-2018, 01:49 AM   #3
danielmailrs
Asphalt grinder
Drives: brz
Get familiar with your transmission. If you start healing squeeking or squeeling, replace the throwout bearing if you got a manual.
Thanks.
What is this tsb noise? Got a video or a good description of how it is?
Tbh my clutch seems to be ok(not as smooth as my other manual cars but still feel healthy)
Sent from my SM-G960F using Tapatalk
Old 11-14-2018, 01:50 AM   #4
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
scroll through the thread, there's videos in there
The Following User Says Thank You to Bonburner For This Useful Post:
Old 11-14-2018, 02:09 AM   #5
Originally Posted by danielmailrs View Post
hi fellas
cheers
Welcome to our forum -
Like @Bonburner mentioned, mind the fluid levels, follow the maintenance schedule and just enjoy driving your car. If your car gets to hurting it will usually send you a signal via a dash light.
Oh yes, if the clutch starts making whining, screeching or screaming sounds, read up about the TOB (Throw Out Bearing) (release bearing). Nope there isn't anything you can do to prevent it from going bad, except to replace it.
If you want to avoid something bad from happening to your car - stay waaaay back from parking stops …
Old 11-14-2018, 02:12 AM   #6
danielmailrs
Asphalt grinder
Drives: brz
Like this ?
Old 11-14-2018, 02:14 AM   #7
danielmailrs
Asphalt grinder
Drives: brz
Parking stops?
Btw this tob doesnt look that messy job ,its like replacing a clutch job.
Old 11-14-2018, 02:31 AM   #8
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
Parking stops?
Probably even easier because its a small palm sized part swap and you don't have to worry about replacing or resurfacing the flywheel.
Old 11-14-2018, 02:36 AM   #9
danielmailrs
Asphalt grinder
Drives: brz
yeah .
did you see the video @youtube i sent ?
i think thats the noise
Old 11-14-2018, 02:48 AM   #10
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
yeah .
[ame]https://www.youtube.com/watch?v=EJZIA3Z-tiw[/ame]
Old 11-14-2018, 02:54 AM   #11
Parking stops?
Are you from the state of Illinois? If so, I would suggest you stick with a 0-w20 oil in the winter, especially if you park outside - the car will start easier -
The parking stops I'm, referring to are the concrete stops and the end of parking spaces. They are just tall enough to scrape the front lip -
I didn't mean to imply that changing a TOB is a "messy" job. Unless your car is in a gravel driveway, at night, the temperature is below 0 degrees F, your only light is a coal oil lantern and the snow is blowing under the car from both directions - then it can get messy -
Old 11-14-2018, 04:12 AM   #12
danielmailrs
Asphalt grinder
Drives: brz
thx
Old 11-14-2018, 04:14 AM   #13
danielmailrs
Asphalt grinder
Drives: brz
ohh now it make sense lol
and naa not Illinois,israel it is.
The Following User Says Thank You to danielmailrs For This Useful Post:
humfrz (11-14-2018)
Old 11-14-2018, 06:41 PM   #14
highway7
Drives: FRS 2013
TOB as stated by others
Disappearing coolant
highway7 is offline   Reply With Quote
The Following User Says Thank You to highway7 For This Useful Post:
danielmailrs (11-15-2018)
How common are 86/frs/brz where you live? Thet Scion FR-S / Toyota 86 GT86 General Forum 107 04-09-2015 11:57 AM
Article: Toyota to recall nearly 6.5 million vehicles for steering, other faults Taro Issues | Warranty | Recalls / TSB 1 04-09-2014 11:56 AM
Common Misconceptions Pegasus Scion FR-S / Toyota 86 GT86 General Forum 31 01-15-2014 11:29 PM
86 factory faults Ryan86 AFRICA 64 03-17-2013 07:47 PM
electrical faults... tibsy92 AUSTRALIA 22 08-19-2012 10:25 PM
