Old 11-14-2018, 07:27 PM   #15
Jamestl
Drives: None
For the same reason I have to deal with potential V8's in my class.
For example, a Mclaren 570S could also compete in my class, provided they met the tire requirements (and all the others), and I do believe the McLaren is the fastest theoretical car in my class.
Power mods are open, because there are other ways to regulate power artificially, e.g. with tire compound, transmission limitations, fuel, etc.
My car in its current trim would fit into TTD/PTD/TT4/ST4.
I don't think heavy/more mods is the right description. Rather, it's a different prioritization on modification.
Sorry but I'm not following. In my very limited experience reading amateur rule books it seems that equalization of competition happens through weight/power and tire sizes, and then fine tuning from there. There's also the 86 cup, which uses points for different tires for classing, which I also understand. So where I'm confused by your response is what does 300TW tires have to do with V8 competition? Is it simply like the 86 cup where the points are better used on power mods vs. tires?
Jamestl is offline   Reply With Quote
Old 11-14-2018, 07:36 PM   #16
tony_r
tony_r's Avatar
Drives: '15 STX
GTA is a program that encourages modification. Tires limit your speed quite a lot. Instead of using points systems for modifications (which they encourage), they opt to limit the available speed by tire compound.
tony_r is offline   Reply With Quote
The Following User Says Thank You to tony_r For This Useful Post:
CSG Mike (11-14-2018)
Old 11-14-2018, 11:26 PM   #17
CSG Mike
CSG Mike's Avatar
GTA is not about equalization, whereas most series are.
GTA defines what you can, and cannot do, black and white, and everything else is left open.
Icecreamtruk (11-15-2018)
Old 11-15-2018, 01:00 AM   #18
Jamestl
Drives: None
Hmm that's interesting. Not sure what to think about classification if a Mclaren and a Miata are in the same class, and the only rule is that both have same sized tires. I know I'm exaggerating b/c it's not only tires, and I have not read the CCR through and through, but you get my point.
Old 11-15-2018, 02:50 AM   #19
CSG Mike
CSG Mike's Avatar
You actually wouldn't be exaggerating; I think a 570S would be the fastest possible car for my class!
Old 11-15-2018, 11:00 AM   #20
Icecreamtruk
Drives: Track preped NA FRS
Yeah Im not a fan of such rules but it seems to be the norm more and more everywhere. Im not all in into equalizing if that means penalizing people who modify (so rather discouraging modifying), but there has to be a point where its not about pockets. Its very easy for a semi-competent driver to win if he has deep pockets.
Tire regulations work for lower classes, where you could say a viper isnt that much faster than a miata, if it cant put the power down because of all of the time it would be loosing in the corners (weight). But in the higher class, where everyone is in hoosiers, there is absolutely no space for low powered (or even mid) cars. Its all about how many ponies you put under the hood, and fit the biggest wing, diffuser, splitter you could find to your car (since power isnt a concern).
Im thrilled that you won, it shows that skill is still a very important part of the equation, but like you said, a Maclaren 570S would probably be so fast that even in the hands of a mediocre driver it would still perform well above the rest.
Sry, rant over, im a bit angry lately because of recent rules changes that have started discouraging mods in our time attack championship.
Icecreamtruk is offline   Reply With Quote
The Following User Says Thank You to Icecreamtruk For This Useful Post:
Jonsey (11-15-2018)
Old 11-15-2018, 03:12 PM   #21
CSG Mike
CSG Mike's Avatar
@949 Racing won Unlimited RWD last year with maybe 300-330whp? Not 100% sure on the hp figure, but it certainly wasn't high!
At the pace we're going, you need much more than a "mediocre driver", even in the McLaren! Remember, the class I run restricts us to 220TW or higher tires, which eliminates every EHP tire. The OEM Michelin Primacy is a great example of a tire that qualifies for the class I run. It's not easy to put down power, at all!
Icecreamtruk (11-15-2018), wparsons (11-15-2018)
Old 11-15-2018, 03:27 PM   #22
ZDan
ZDan's Avatar
Drives: '23 BRZ
Big-time congrats, man! Most impressive, indeed...
Old 11-15-2018, 03:34 PM   #23
Pat
Pat's Avatar
Drives: 2023 BRZ
Originally Posted by justinco View Post
Great stuff Mike, and congratulations!
The more I track my BRZ, the more I want to swap my e36 TT car for another twin dedicated to TT haha.
Did Baer mention Rocky Mountain 86 Cup to you? We're working on it...
The Following 3 Users Say Thank You to Pat For This Useful Post:
CSG Mike (11-15-2018), justinco (11-15-2018), whataboutbob (11-17-2018)
Old 11-15-2018, 03:53 PM   #24
justinco
btr.life
justinco's Avatar
Drives: 2022 GR86
Yea, we had lunch a few weeks ago and he just briefly mentioned it (we were working on my e36 TT5 plans). Also heard it from Abe last week after you guys met at Bruz (which I'll try to make more consistently this winter).
justinco is offline   Reply With Quote
The Following User Says Thank You to justinco For This Useful Post:
Pat (11-15-2018)
Old 11-15-2018, 03:56 PM   #25
TofuJoe
Ohne Titel
TofuJoe's Avatar
Drives: 2017 BRZ PP ISM
Do you have plans to move to the next class up? What would that open up for you mods-wise on this platform (other than tires, I assume).
TofuJoe is offline   Reply With Quote
Old 11-15-2018, 04:12 PM   #26
FirstWinter
Drives: Car
A much lighter wallet
FirstWinter is offline   Reply With Quote
The Following 2 Users Say Thank You to FirstWinter For This Useful Post:
CSG Mike (11-15-2018), wparsons (11-15-2018)
Old 11-15-2018, 10:50 PM   #27
949 Racing
FT86Club Official Vendor
949 Racing's Avatar
Drives: Miata, GT350, FR-S
The two fastest RWD cars at Super Lap we're Vegas, our 420whp, sequential trans Miata and Ryan Passey's 300whp Miata. We won Unlimited, he won Limited.
Obviously a big dollar Corvette or supercar would probably school us. But the bar in RWD is not quite that high yet.
949 Racing is offline   Reply With Quote
Old 11-15-2018, 11:10 PM   #28
CSG Mike
CSG Mike's Avatar
I don't. Next class up would allow me E85, 200TW tires, 2 way dampers, and more aero, among other things.
There's still more to accomplish in my current class.
TofuJoe (11-15-2018)
EvasiveMotorsports x Super Lap Battle 2013 Evasive Motorsports FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 13 12-04-2013 02:47 AM
More on hot version 122 86 super battle Grip Ronin FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 10 08-26-2013 11:50 AM
2013 Redline Time Attack enthusiast class winning lap CSG Mike Tracking / Autocross / HPDE / Drifting 12 12-02-2012 12:46 AM
Super Lap Battle S2KtoFT86 Other Vehicles & General Automotive Discussions 0 12-10-2009 10:46 PM
