Old 11-13-2018, 06:58 PM   #15
Qwimby1
Drives: 14 FRS Monogram, 05 Mazdasped Miata
Originally Posted by Grady View Post
My bad got my OP crossed. 99% of the time when people talk about installing LED they are buying lamp replacements with the voltage regulator build into the base. Not like you that purchased raw LED’s and yes needing to control the voltage to them with a dropping resistor or regulator.
I was going to pick up some LED backup lights at Advance Auto Parts. The local store tells me they have them. I'll have to see if it's obvious they have resistors installed.
Qwimby1 is offline   Reply With Quote
Old 11-13-2018, 08:04 PM   #16
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Most LEDs are have a forward voltage (the lowest voltage they turn on) of between 2.5 to 5 volts.
So, to make products that are Plug-&-Play, almost all companies sell automotive LED lights that have been made to work with 12 volts. This does not take into account the resistance needed for a specific 12v car circuit.
Meaning the lights will hook to a 12v car battery and work fine. But when installed on a car, they may need a resistor. (I'm talking about generic or lower priced ebay or autozone LED lights - which work, but may need some tinkering....)
There are a few vendors on this forum that sell LED lighting that has resistors and functions awesome.
I LIKE TIRES!
Old 11-13-2018, 10:08 PM   #17
jg7
Drives: 2016 Scion FR-S
This may be simple, but did you check the brake fluid level? I had a similar problem autocrossing ('95 RX-7). Once in a while if my fluid level was low and I pulled high g's. Light would come on. I just turned the car off, then back on - all good.
jg7 is offline   Reply With Quote
Traction control and ABS light on after LCA install Geese1 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 14 10-07-2024 01:03 AM
Check Engine light and Traction Control Light JeRM Issues | Warranty | Recalls / TSB 25 06-02-2023 10:00 PM
Traction control warning light Armin93 Scion FR-S / Toyota 86 GT86 General Forum 5 03-18-2017 04:50 PM
No traction control/ABS light on Hollwood_lives CANADA 6 01-13-2016 10:11 PM
Engine Check light, Traction Control light, cruise control light all on suddenly wqc3241 Software Tuning 2 01-10-2016 08:37 AM
