Old 02-25-2016, 11:45 PM   #71
Who8myrice
Drives: Ap2
Originally Posted by NyC Zn6 View Post
so you telling me if i install these door things..i will have better handling?
Best purchase I made on Frs next to otf.
Who8myrice is offline   Reply With Quote
Old 11-17-2016, 10:54 AM   #72
neilvosko
neilvosko's Avatar
Drives: Hyper Blue BRZ
does anyone have the carson toyota part number for ordering ?
Originally Posted by crustol View Post
Regular places sold these for $250, but since I found out that I could get them for ~$140 including shipping, I decided to pull the trigger.
The installation:
I also tried to use an impact driver to loosen the bolts, and was unsuccessful. To be fair, it was my first time using an impact driver so maybe I wasn't using it properly.
I was successful using a regular 3/8 ratchet with a phillips bit. It wasn't that difficult.
The most difficult operation IMO was installing the torx bolt into the striker. It was cold outside, I had no gloves, you have to hold the damn slide all the way back throughout the entire process. The instructions stated to be careful of not letting the slide go while installing the bolts since you could damage the finish on it... I chipped some of that finish off so you can see a black spot on the edge.
Result:
In my case, the driver's side door seems to require more force to close now. Passenger side, not that different. Performance wise, didn't feel a lot different, but wasn't expecting night and day difference anyway.
neilvosko is offline   Reply With Quote
Old 04-24-2017, 04:03 PM   #73
EdBoy
Driver
EdBoy's Avatar
Drives: 16 Subaru BRZ
did anyone else have a slight door misalignment? installed mine yesterday and my driver side door is slightly off than normal compared to my passenger side door.
BRZ Build Thread
See you space cowboy...
EdBoy is offline   Reply With Quote
Old 04-24-2017, 04:04 PM   #74
MurderousPandas
MurderousPandas's Avatar
Drives: 2013 Scion FRS
Carson Toyota part number? I think the part number is the same everywhere. FT86SF has them for sale, not sure how it compares to dealership prices though.
Sent from my HTC6535LVW using Tapatalk
MurderousPandas is offline   Reply With Quote
Old 04-28-2017, 05:16 PM   #75
trvth
trvth's Avatar
Drives: '15 Halo Scion FRS, 1999 Saturn SC2
My driver side door came out perfect, but my passenger door is slightly "off". I have not found a solution yet. Since it's on the passenger side I don't notice it every day, so it doesn't bother me as much. I'd be very happy to hear about a solution, though.
2015 Halo Scion FR-S 6MT new w/TRD exhaust, cold air intake, quick shifter, sway bars, lowering springs, & brake pads. Since then, TRD door braces, strut tower bar, & battery tie-down, Motul fluids in trans/diff & brakes, GrimmSpeed master cylinder brace, Stoptech stainless brakelines, OpenFlash Header 3 w/overpipe, OpenFlash Tablet on E85
trvth is offline   Reply With Quote
Old 06-01-2017, 06:03 PM   #76
mrderp
ಠ_ಠ
mrderp's Avatar
Drives: 860 SansOverspray
Didn't see it mentioned in the thread.
The Torx are T-40, if you don't already have a set you can get the right one.
mrderp is offline   Reply With Quote
Old 12-15-2017, 05:40 PM   #77
KalbiCool88
KalbiCool88's Avatar
Drives: 2005 SLK350, 2015 RS 1.0 FRS
Just got these not too long ago. Having trouble with the body side striker bolts. Have tried using 3/4" ratchet with socket bits, bits with breaker, and even a manual impact driver...But with no luck. Anyone had to use an electric impact driver to get these bolts out?
KalbiCool88 is offline   Reply With Quote
Old 07-09-2018, 10:11 PM   #78
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
I had to use an electric impact, managed to get them out but stripped one in the process, not a big deal since I won't need them again. Passenger side door is slightly off with alignment but I don't want to go through the hassle of trying to get it right.
Trueweltall is offline   Reply With Quote
Old 07-10-2018, 12:58 PM   #79
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Hardly seems worth it.
Originally Posted by humfrz
I'm old and lazy
Old 07-10-2018, 03:15 PM   #80
Impureclient
Drives: 2015 FR-S
Somebody needs to make it without the TRD logo and that will knock it's price in half. Then just say it's to make the car door close nicer/quiter
and not say it's a performance piece and that should knock it down another half. Then we will be where it should be in the first place, maybe $30-40.
I'm tempted to do like somebody else said in here and just make a DIY wedge/shim. I mean if I am reeaallly bored one day since this is really stretching it for "performance".
It's only after watching that video of the car door kind of moving a little that makes this sort of an attractive mod but in reality we all know that there is no way a human
driving inside the vehicle can detect if that thing was on the door or not. It's like getting a 5 hp bump from an air filter and saying you can feel it on your butt dyno.
Old 07-10-2018, 03:18 PM   #81
Roadcone
StreetKart
Drives: 2014 Scion FR-S Monogram
if you used an impact you did it entirely wrong. the proper sized bit on a 3/8" ratched pulled the bolts out with relative ease.
You could easily have a DIY version of the part but it's not going to be a nicely finished part that is an oem bolton replacement made by the same people who make a ton of other parts for the car.
If you do something like a real 10-point cage it's a pointless piece. I'm entirely happy with mine on my daily driver, it makes the car feel more premium and helped get rid of some creaks and pops that my poor 77k miles chassis had.
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
Roadcone is offline   Reply With Quote
Old 07-12-2018, 10:55 PM   #82
Bimble Bamble
Drives: 10 Series
Check out the YouTube videos 10 series bro, it shows the door flexing without and not with!
Bimble Bamble is offline   Reply With Quote
Old 11-01-2018, 04:13 AM   #83
yourboyvic
Drives: brz
please link to video?
yourboyvic is offline   Reply With Quote
Old 11-01-2018, 04:22 AM   #84
yourboyvic
Drives: brz
not better handling per se...
the TRD video shows us that rigidity will be increased to less flex because the doors 'become part of the chassis'
not better handling but driver input requirements will go down due to better chassis response, sort of the same thing but not really.
not better handling due to better tires or better suspension, it's an improvement at the chassis so that the chassis responds better at the driver input level, if Toyota has convinced me they've done their research and I'm at the end/beginning of my project car mod cycle and had $200 in the budget I guess I would get these; we see and know flexing does happen, these reduce that flexing.
LED Door Sill? joergasm Cosmetic Modification (Interior/Exterior/Lighting) 46 06-17-2014 07:37 PM
8's in the door cruzinbill Electronics | Audio | NAV | Infotainment 2 01-26-2013 05:10 PM
fs: TRD door stabilizers narfy Canada Classifieds 12 11-15-2012 11:57 PM
out the door pricing wallace03 BRZ First-Gen (2012+) — General Topics 6 06-12-2012 01:30 PM
