#15 |
Drives: 2014 Scion FR-S
It was, but truth be told I don't know. I think it would be smart to double check the alignment as I plan to, and I'll report back with my findings.
#16 | |
![]() humfrz |
#17 |
| The Following User Says Thank You to humfrz For This Useful Post: | MCTeeJ (10-23-2018) |
#18 |
Panda Trueno
Drives: No twin now.
What is your strut to tire clearance? Do you see any black marks / rub marks anywhere?
#19 |
Drives: 2017 BRZ
That looks like wear from turning while stopped to me. Well, not so much wear as scrapes and scratches in the rubber from stones rolling / being crushed.
#20 |
Rust bucket enthusiast
Something else to consider is that if the tire is chopping,the struts may be losing their capacity and leaking. I've seen this wear on vehicles when the spring is going most of the working, causing it to hop around. You end up with strange wear like that.
Since you've had caster, camber and toe checked, and are comfortable with them, I'm not sure what else it could be aside something allowing play in the wheel/tire EDIT: The rest of the world refers to this as " cupping" |
| The Following User Says Thank You to DarkPira7e For This Useful Post: | Tristor (10-23-2018) |
#21 |
quite a bit of clearance considering I have coilovers lol
#22 | |
#23 |
Panda Trueno
I didn't look at your build thread and there is nothing in your signature. You see that kind of marking sometimes when there is shit clearance at the fender or the strut and the tire makes occasional contact. I'm guessing you have no obvious marks or residual rubber anywhere? |
| The Following User Says Thank You to Summerwolf For This Useful Post: | MCTeeJ (10-23-2018) |
#24 | |
If it's only 1 tire doing it, I would tear that side apart, wrench everything down to be sure it's tight and re-assemble. I really suspect something loose, letting the adjustment suffer through a rough ride but not enough to affect the alignment you're being given. |
#25 | |
| The Following User Says Thank You to MCTeeJ For This Useful Post: | Summerwolf (10-23-2018) |
#26 | |
#27 | |
| The Following User Says Thank You to DarkPira7e For This Useful Post: | MCTeeJ (10-23-2018) |
#28 |
They'll never get my remaining tires! I'll put them in shrink wrap for safe keeping
| The Following User Says Thank You to MCTeeJ For This Useful Post: | DarkPira7e (10-23-2018) |
| How does my tire wear look? | R_E_L | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 14 | 09-08-2018 07:34 AM |
| tire wear | oppiee | Tracking / Autocross / HPDE / Drifting | 9 | 08-29-2017 12:55 PM |
| Front Passenger Tire Cupped | shellslinger | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 08-12-2017 10:52 PM |
| Tire Wear? | Flo | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 12 | 01-10-2017 03:19 PM |
| Tire Wear Help | babykwiss | Tracking / Autocross / HPDE / Drifting | 10 | 07-14-2014 11:31 AM |
