Old 08-08-2017, 10:42 PM   #15
brzstiz
Drives: 2015 brz series blue
Originally Posted by carsebuco View Post
This dude has Redline shoved up so far up his bumhole it makes it feel like he's trying to sell something...
Well i wanted to share with everyone except you my experience hoping that it would help someone.
This problem bothered me for 3yrs so much so i was about to get rid of the car.
If your car shifts great good for you. But many people have this problem.
Its also coments like yours that make me wonder why bother trying to help.
People like you ruin the forum for others that genuinely want to help.
brzstiz is offline   Reply With Quote
Old 08-08-2017, 10:49 PM   #16
brzstiz
Originally Posted by qqzj View Post
It truly seems that there isn't a single wonderful fluid that will solve the problem for every one's transmission. Each has a chance with some probabilities. I guess we just need to figure out the order that one should experiment with. Unfortunately, I have bought 4 Motul. Have to start with this one. The negative comment of Motul for the diff is what bothers me a little.
I must agree there is no one solution or magic cure all oil.
I tried to give in detail my symptoms so that if someone else could relate closely to mine that at least there is some basis to take at my time and expense! at least you can see what worked and didn't for me and then make a decision.
Motul in the diff was very bad to me. i hated the slight shutter and noticed it immediately. I knew the car at that point and before the motul in the diff i did 30000kms and never had a hint of that shutter. again a change away from motul in the diff eliminated it completely!
Fwiw
Old 08-08-2017, 11:02 PM   #17
carsebuco
How do I shift?
carsebuco's Avatar
Drives: '13 GBS BRZ
Heh I see how it could have come out the wrong way. I just meant that you sounded more like someone trying to sell the product than anything else. It's good that it has worked out for yall, though.
carsebuco is offline   Reply With Quote
Old 09-27-2017, 08:27 AM   #18
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
OP is 100% right. I have been using Motul for 30,000 miles. Just switched to redline and shifting is noticeably more smooth.
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
The Following 2 Users Say Thank You to Takumi788 For This Useful Post:
Beachin86 (09-28-2017), Trust86 (09-27-2017)
Old 09-28-2017, 04:16 PM   #19
Beachin86
Beachin86's Avatar
Drives: FR-S 10 Series
Planning on trying this out in the coming week or two. I recently started using their motor oil and I love it. Will post with my feedback when done and hopefully point people to this thread as everyone seems to have issues with hard shifting when the tranny is cold.
Beachin86 is offline   Reply With Quote
Old 10-22-2018, 05:51 PM   #20
scbrz
Drives: 2015 BRZ
I hope this helps someone....
i've read every possible post regarding trans oil and the 2nd gear crunch and grind when cold problem and I've tried several oils. My car is a 2015 series blue Aozora. Anyways here is a breakdown: (last one is what SOLVED my issues!)
1. Stock fluid fill (bought car new) - JUNK! locked out when cold (gets cold in Canada/Toronto) and crunch and grinding in cold weather, until after 15mins of driving until i got a usable 2nd gear! Also even when warm, in summer, 2nd gear NEVER felt good, 2/5 shifts resulted in a clank sound or just not feeling smooth at all.
2. Amsoil (can't remember the type, but it was their GL-4 for manual trans), and used their severe gear for diff, the diff was fine with this oil! This trans fluid was MUCH WORSE that stock! lasted 5000kms and out it came!
3. Motul 300 - MEH....slight improvement over stock, but still not right. Filled with motul 300 in trans and diff, the diff developed a shutter on the first few turns in the morning, then that smoothed out, but could definitely feel the diff with motul. So far this was the best oil for the trans, and worst for the diff! If anyone tells you you don't need the SG additive in a torsen diff, i'm hesitant to believe it anymore, i could definitely feel the diff shutter.
winter shifting with motul in the trans was just a slight improvement over stock fill, learned to live with it.....tried everything like driving down the street in 2nd gear in the morning, i usually ended up skipping 2nd gear until warm or slow double clutch shifts with a huge pause from 1-2, then ram it in gear....nothing worked....
4. Red Line - OMG OMG OMG PRAISE THE LORD!
i used this in the diff: https://www.redlineoil.com/product.aspx?pid=40
and this in the trans: https://www.redlineoil.com/product.aspx?pid=46
AND EVERYTHING IS BUTTER!
This morning was the first drive to work, it was 14*deg C (little chilly), and i purposely just left and took a normal shift down my street into 2nd gear on a cold trans, it was nirvana! Blissfully perfect shifting; something i NEVER experienced in this car!!! Night and day comparison, and exactly how i thought it would feel in my dreams! 30min drive to work in stop and go traffic and every single shift was perfect. Not only did 2nd shift perfectly but i also feel all gears just feel better, and shifting is effortless!
I also had a few other symptoms with all oils except for Red Line:
- rattle sound in netural from trans at idle sitting at a light when car was partially warmed up. Would go away if i just barley touched the shifter
- when coming to a stop with AC on, occasional shutter right when comming to a stop (sounded like the engine bogging/rpm dropping just ever so slightly too much).
ALL my issues are GONE!
If anyone has this problem shifting (which i know many do) don't think, get the Red Line oil and i bet you'll be as happy as i am right now!
Hi brzstiz,
I have a 2015 BRZ with the same issues for the first 1-2 miles when engine/gearbox cold (not ambiant temps), including full blocking out of 2nd gear aswell as the snatching/baulking.
Did the RedLine oil prove to be a long term solution for you?
thanks.
scbrz is offline   Reply With Quote
Old 10-22-2018, 10:29 PM   #21
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
Originally Posted by scbrz View Post
Hi brzstiz,
I have a 2015 BRZ with the same issues, including full blocking out of 2nd gear aswell as the snatching/baulking.
thanks.
I haven't used RedLine but I've used Motul's MotylGear and I don't have any problems anymore.
Old 10-22-2018, 10:44 PM   #22
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Intersting, will try redline next time.
Been using motul the last 50k miles, since it fixe d my 2nd gear when the car was still pretty  new.
Old 10-23-2018, 12:55 AM   #23
FirstWinter
Drives: Car
Just why
FirstWinter is offline   Reply With Quote
Old 10-23-2018, 03:23 AM   #24
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Originally Posted by FirstWinter View Post
Just why
Hey, if it turns out to be even smoother why not?
It's never smooth to the point of most hondas anyway. Plus even though it's not grinding anymore, it doesn't feel good except 3rd-4th.
Old 10-23-2018, 03:31 AM   #25
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
I think he's referring to the font and font spacing you used.
The Following User Says Thank You to Bonburner For This Useful Post:
FirstWinter (10-23-2018)
Old 10-23-2018, 03:44 AM   #26
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Ah... ya didn't notice i was typing english in Japan IME input but too lazy to retype the whole thing.
Old 10-23-2018, 09:44 AM   #27
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Wanted to throw in that Motul helped smooth engagement all around for me, and made a drastic difference in temperatures down to -20f. Where the stock fluid basically was like pushing a straw through a cup of ice cubes, the Motul did not need nearly as much time to warm up
Old 10-23-2018, 01:48 PM   #28
scbrz
Drives: 2015 BRZ
Hi brzstiz,
thanks.
I should have added that I don't have stock fluid currently its Millers CRX LS 75W90, which is their motorsport version of the fluid for the BRZ.
https://www.millersoils-shop.co.uk/c...ansmission-oil
This is supposed to help but I wonder if its making it worse?
Negative Fuel Trims Under Load *Problem Solved* Neiman Issues | Warranty | Recalls / TSB 4 06-02-2018 01:30 AM
Engine/Trans noise whie in gear Madmax516 Issues | Warranty | Recalls / TSB 2 08-02-2016 08:23 PM
Problem with door handle trim (SOLVED) MikeM7 Cosmetic Modification (Interior/Exterior/Lighting) 8 02-28-2015 11:14 AM
BRZ won't start (Problem solved) Dusky BRZ First-Gen (2012+) — General Topics 6 09-01-2012 10:51 PM
how I solved my gilrfriend's problem with headrest angle alexmotrix Cosmetic Modification (Interior/Exterior/Lighting) 8 08-08-2012 09:00 AM
