Old 10-04-2018, 02:45 PM   #1
dma550
Drives: 2017 BRZ
Looking to install XAV-AX200SXM in a 2017 BRZ
Hey guys
I have some questions. I configured this on Crutchfield and so far it looks like the XAV-AX200SXM will work with the 2017 BRZ with their install kit. There are a few things I am puzzled over.
Anyone running this?
1) I want to use the stock shark fin, so I see I might be able to use this adapter Can anyone confirm?
2) Can I use the stock mic or do I need to run the mic provided which looks like hell from 1988?
3) I would love to hear feedback about reverse camera operation, etc. Also, how the HU reacts to different things. For instance, using carplay and listening to XM.
Thanks
dma550 is offline   Reply With Quote
Old 10-05-2018, 02:10 AM   #2
jflogerzi
jflogerzi's Avatar
Originally Posted by dma550 View Post
Hey guys
Thanks
1)
For Radio signal you just need this adapter: https://www.crutchfield.com/p_12040L...r.html?tp=2569
2) The stock mic will not work. But the good new its very easy to remove and run the new one to the stock location so it looks OEM.
3) I can't help you on this.
2013 Series 10 FRS #553
Old 10-05-2018, 05:21 AM   #3
Brz866
Brz866's Avatar
Drives: Series Blue WRB JRSC C38 HBP Flex
Don't know about operation, however you will be better off using the mic from your new headunit. The antenna adapter you linked to is used to retain the factory xm radio antenna. The am/fm antenna is separate from the xm. Pricey little adapter but well worth it imo for xm. Works great too.
Brz866 is offline   Reply With Quote
2017+ Vertical JDM/STI DRL Install Help TachyonBomb Cosmetic Modification (Interior/Exterior/Lighting) 12 11-29-2019 08:13 PM
2017 BRZ iDatalink ADS-RR Headunit Install Compatibility dman22 Electronics | Audio | NAV | Infotainment 7 03-13-2018 08:04 PM
Any guide for install this Badge in a new 86 2017? reynierpm Cosmetic Modification (Interior/Exterior/Lighting) 6 08-30-2017 03:05 PM
2017 BRZ Install Kenwood DNX893S 007BRZ Electronics | Audio | NAV | Infotainment 1 08-10-2017 04:40 AM
2017 BRZ and Perrin Oil Cooler Install JSube Tracking / Autocross / HPDE / Drifting 18 04-29-2017 08:49 AM
