Old 09-29-2018, 09:53 AM   #29
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
At a gas station, next to the air pump, pull the nail out and see if it leaks air (spit on it). If not, it didn't penetrate you're good to go. If it does leak air, use the tire plug kit you have on hand (they are like $5, so you should have one in your glovebox anyway) and plug it.
Don't let a nail sit in your tire. I have changed 10's of thousands of tires (AAA guy) and what happens is that the nail sits in there sometimes for days, sometimes for months- but at some point the tire will heat up and spit the nail out, then you will have a flat in a matter of minutes, maybe hours if the hole is in a good spot and the nail is small.
Just take care of it today
guybo is offline   Reply With Quote
The Following 2 Users Say Thank You to guybo For This Useful Post:
humfrz (09-29-2018), wparsons (09-29-2018)
Old 09-29-2018, 08:54 PM   #30
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
seriously guys... go to discount tires & have it patch up for free. All you need to do is drive there.
--------------- "FREE"----------------------------
Screw / Nail in tire kpamir Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 07-03-2015 01:20 AM
Nail polish removal smell coming from vents. dOMEmE Issues | Warranty | Recalls / TSB 8 09-27-2014 05:13 PM
Got a nail! Fixable? jbravo373 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 09-03-2013 06:28 PM
Getting a BRZ tmw, worry about CEL Sniper2606 Engine, Exhaust, Transmission 25 04-22-2013 11:28 PM
Nail in the sidewall ApoNono Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 02-15-2013 08:54 PM
