Old 08-31-2018, 06:04 PM   #1
wild03
Drives: Silver 2017 Limited with PP
Help installing dash cam (front and rear)
I would like to install a dash cam (Amazon has a cheap $20 cam with front and rear recording
https://www.amazon.com/Sebikam-Dashb...70_&dpSrc=srch
Coupon code "SEBIKAMUSA" knocks that to $19.55. Plus, free shipping
IS there a guide on what the best routing is and how to remove the panels on the BRZ?
Thanks in advance.
wild03 is offline   Reply With Quote
Old 09-05-2018, 01:46 PM   #2
KR-S
Sporadic Member
KR-S's Avatar
Drives: 2016 Halo FR-S M/T
Refer to this guide on how to install the front dashcam.
When I did my rear dashcam install, I followed part of the sharkfin antenna guide for removing the roof liner.
The Following User Says Thank You to KR-S For This Useful Post:
wild03 (09-06-2018)
Old 09-05-2018, 03:34 PM   #3
darko
Drives: RAVEN FRS
The front is fairly easy just route the cable from the headliner to the passenger pillar then to the glove box. For my rear cam, I loosened the panel with the logo, there's like 5 or so bolts, fished the wire beside the trunk key hole.
darko is offline   Reply With Quote
The Following User Says Thank You to darko For This Useful Post:
wild03 (09-06-2018)
Old 09-05-2018, 11:32 PM   #4
cjd
cjd's Avatar
Drives: 2017 BRZ
No need to do more than the above noted headliner removal (and it doesn't even have to come off) for the rear camera, usually. I have previously run dual singles (remote base) and now a Street Guardian SG9663DC; in both cases cable went up the a-pillar for power, and across the roof along one edge. Quite simple. Both cameras mounted at the top of the front/rear windows.
The Following User Says Thank You to cjd For This Useful Post:
wild03 (09-06-2018)
Old 09-06-2018, 04:18 PM   #5
Muchikori
Smiling
Muchikori's Avatar
Drives: BRZ 2018
For the rear, i routed it through the pillars then through the rubber of the door thrn to the floor "scuff guard" and so on. Just follow the panels until you reach the back
No need to fully route it through the head liner.
Done it this way for 3 different cars
Subaru BRZ Sport Tech RS 2018
Instagram: @jedi_shifu
BuildThread: Click Here
Muchikori is offline   Reply With Quote
The Following User Says Thank You to Muchikori For This Useful Post:
wild03 (09-06-2018)
Old 09-06-2018, 06:45 PM   #6
Twitchy313
Twitchy313's Avatar
Drives: 2014 Scion FR-S
Thanks in advance.
I’ve also installed a front dash cam, you don’t have to remove panels, you just have to hide the wire along the head liner, and plug it into the outlet in your glove compartment. That’s the best way I’ve found to install and wire. Hope this helps.
Twitchy313 is offline   Reply With Quote
The Following User Says Thank You to Twitchy313 For This Useful Post:
wild03 (09-06-2018)
Old 09-06-2018, 08:44 PM   #7
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
Check out my blog post. Feel free to ask any other questions
http://www.seriesblueadventures.com/...f770-dash-cam/
Check out my blog, read all about my BRZ adventures, and oogle my sweet cell-phone photos!
You can also find me on Instagram, and on Facebook.
Stang70Fastback is offline   Reply With Quote
The Following 2 Users Say Thank You to Stang70Fastback For This Useful Post:
SkyeHack (09-06-2018), wild03 (09-06-2018)
Old 09-06-2018, 10:04 PM   #8
jordan7831
Drives: 2016 Halo FRS
I installed my cam by tucking the wire under the headline, then under the plastic A pillar cover, then under the window weather stripping. There is a panel that can be removed so the wires can feed directly into the glove box all leading to a super stealth install.
My butt dnyo didn't like it
jordan7831 is offline   Reply With Quote
The Following User Says Thank You to jordan7831 For This Useful Post:
wild03 (09-06-2018)
Old 09-06-2018, 11:31 PM   #9
wild03
Awesome cam, nice footage. I hope my $20 cam is half as good....It probably won't last long, but will probably help in selecting something better in the future.
Old 09-08-2018, 06:14 PM   #10
jordan7831
Viafo A119 is pretty solid. It's a good balance of quality and cost. But any dashcam is better than no dashcam!
Old 09-09-2018, 12:08 AM   #11
CraigVM
Drives: Car Collector
Constant power from Dome light
I wanted to utilize my cameras parking mode and keep the glove box outlet free for other uses. I used a hardwire kit and came off of my dome light wiring which has constant power. Very easy to pull the dome light assembly down. My car sits garaged 98% of the time so I just pull the camera which has a quick disconnect bracket to not worry of draining the battery. I do not know if newer models have constant power at their dome lights or not though.
CraigVM is offline   Reply With Quote
Need help installing rear springs! flashburn Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 03-29-2014 05:51 PM
Crap lights on my dash after installing coilovers. Eelusive BRZ First-Gen (2012+) — General Topics 43 02-12-2014 02:08 PM
Dash blinker stay on after installing leds Fr-Sheila Issues | Warranty | Recalls / TSB 14 02-05-2014 03:48 PM
Door Unlocked dash light coming and going after installing subwoofer tbertran Electronics | Audio | NAV | Infotainment 0 01-01-2014 11:22 PM
DIY Thread on Installing a Front Lip ? Particularly the Downforce CF Front Lip ScionFR-S DIY (Do-It-Yourself) Guides 10 12-22-2013 09:22 PM
