Old 09-03-2018, 06:35 PM   #113
HeresMyMind
HeresMyMind's Avatar
Drives: 2013 WRB BRZ Limited
Originally Posted by ShadowWolf_99 View Post
Sure cant hurt
Sent from my SM-G950U using Tapatalk
Pin 30 should goto the battery with a 15amp fuse.
Pin 86 should get tapped into a stock fuse with tap. share the fuse with a illumination fuse in the dash. Put the switch you have there.
Pin 85 to ground on chassis or battery
Pin 87 to the fog lights positives (ground the fogs to the chassis).
Use this to tap into your fuse, they are found at local car part stores
-B
HeresMyMind is offline   Reply With Quote
The Following User Says Thank You to HeresMyMind For This Useful Post:
Outlander (03-17-2021)
Old 09-03-2018, 06:36 PM   #114
ShadowWolf_99
ShadowWolf_99's Avatar
Drives: 10 Series #895
Originally Posted by HeresMyMind View Post
want me to send you a schematic on a fog light harness?
Mine is wired up exactly like this except the 86 and 85 on my Bosch relay diagram swapped these two locations.
PDX86 / 86 Sessions / 86Squad / DarkSquad
ShadowWolf_99 is offline   Reply With Quote
Old 09-03-2018, 07:39 PM   #115
ShadowWolf_99
Would having a led flasher relay inside mess with this setup if I came off the side markers for power in for the switch?
Old 09-03-2018, 07:40 PM   #116
HeresMyMind
No. That is a different circuit. I would tape into a different wire though off one of the fused ones in the cabin.
-B
Old 09-03-2018, 08:21 PM   #117
ShadowWolf_99
Ok now I think they are too dim. What would cause them to seem so dark? Do they need a 40A relay. Damn service guy gave me a 30A. Letting them warm up a bit
Old 09-03-2018, 08:22 PM   #118
HeresMyMind
If those are projector style ones, they may seem dim but under the cutoff they are bright. which fog lights did you get?
-B
Old 09-03-2018, 08:34 PM   #119
ShadowWolf_99
Sylvania ....man they get hot.
Old 09-03-2018, 08:40 PM   #120
carlovestela
Drives: 2015 Firestorm FRS
What do you mean by electronic lever?
Because i have a situation. Im running now the morimoto headlights and my wiring now and pins are converted to brz
Yes. You will need to repin a few of the wires. And the electronic lever won’t work. But it’s not that hard!
-B
carlovestela is offline   Reply With Quote
Old 09-03-2018, 08:42 PM   #121
HeresMyMind
I’m asking about the fog light style not the bulb type.
-B
Old 09-03-2018, 08:44 PM   #122
ShadowWolf_99
Your electronic leveling system built into the light mount. It has a motor to adjust the beam. If I understand right. My 10 series has motor to adjust the beam
Old 09-03-2018, 08:46 PM   #123
HeresMyMind
Subaru’s have a electronic height control for the motors on the headlights. The controls are next to the brightness for the gauges. They allow you to lower or raise the headlights beam pattern height.
-B
Old 09-03-2018, 08:46 PM   #124
ShadowWolf_99
-B
It's this stupid kind I got for free. The led halo doesn't even have LEDs in it. Lame. But to check out my other pics. Headlights and turn signals are brighter than my fogs. Last pic is my hand within a foot and barely see the light.
Old 09-03-2018, 08:48 PM   #125
HeresMyMind
Those look like very cheap projector style lights without a proper shield / optic system. That stinks. When you can find a set of used dogs from a frs or brz to swap in
-B
Old 09-03-2018, 08:49 PM   #126
ShadowWolf_99
Middle switch runs the motor to adjust my beam height.
OEM foglight install question DarkSideFRS Cosmetic Modification (Interior/Exterior/Lighting) 3 06-12-2017 03:21 PM
FS Winjet Headlight/Foglight Kit - Beat sonic antenna- clear sides Verge Exterior Parts (Aero, Lighting, Etc.) 12 11-21-2014 08:56 PM
Automation Lighting offers HID xenon headlight + foglight kits jjdrivesajazz Exterior Parts - Lighting 138 01-13-2014 01:19 AM
